Old 02-06-2013, 07:52 PM   #8221
renogeorge
Oddometer: 1,425
White stuff
I had a little of the white powder in my tank when bike was new. It is an '06, now with 32k miles. I have never has any fuel related problems, other than the pump. Seems to me I read in this thread and/or the Adventure forum about this being fairly common
FWIW.
renogeorge is offline   Reply With Quote
Old 02-06-2013, 08:08 PM   #8222
Thumper996
Thumper996's Avatar
Oddometer: 593
FWIW.
Don't know, mine is an 06 as well with 20k plus. Never seen that stuff you mention, still think it may be fuel additives in your area IMHO
Thumper996 is offline   Reply With Quote
Old 02-07-2013, 01:37 PM   #8223
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
I always use 100% gas, non ethanol. Just to be on the safe side, I might try using different gas station.
Also noticed some of my coolant hose connections, have tiny leaks. It may be from setting 2 weeks. Or the special ktm hose crimps. Has anyone changed there clamps out yet?
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 02-07-2013, 02:38 PM   #8224
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by Thumper996 View Post
I have mine apart now for winter maintenance and there is zero white residue. I wonder if it is a by-product of your local fuel. We have non-ethanol here that i run when i can, but i also run fuel with up to 10% ethanol
i got that stuff for the longest time. I cleaned the tanks and no change. When changing the fuel screws to flex jet i found there were no O rings in place, oops. Much better now, but i still park it without fuel in the float bowls
MookieBlaylock is offline   Reply With Quote
Old 02-07-2013, 04:58 PM   #8225
cnw126
Oddometer: 107
That is what I was thinking! I have no proof but it seems reasonable.
cnw126 is offline   Reply With Quote
Old 02-08-2013, 11:01 AM   #8226
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
My hose clamps weep at the plastic junction between the heads. Have for a while and I notice the "sweat" after long aggressive rides. I haven't messed with it since I have seen the hoses continue to leak at that joint, on other bikes, even after replacing the KTM clamps with traditional screw clamps. Replacing the hoses with a set of silicone ones will put a stop to the leakage.
I believe eSong did a set on his. I'll search this thread for his post and link it.
edit to add: cant find the post with my search fu...
snowhawk jockey screwed with this post 02-08-2013 at 11:07 AM
snowhawk jockey is offline   Reply With Quote
Old 02-08-2013, 11:09 AM   #8227
corndog67
Oddometer: 1,281
FWIW.
Years ago, in my garage, we'd cut lines of white powder on top of the gas tank of one of the bikes in the garage, and get all energized up, and work on bikes. Sorry, re-living my younger days.
corndog67 is offline   Reply With Quote
Old 02-11-2013, 02:25 PM   #8228
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,124
Corndog! You are cutting up in class again! You probably never heard that before, either...
Old 02-17-2013, 07:47 AM   #8229
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,278
Big Tank Options
Hi all--
Does anyone have a suggestion for bigger tanks for a 2007 950 SMR? What have people tried?
Thanks!!
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 02-17-2013, 09:04 AM   #8230
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,713
The Aqualine tanks made to fit the SE are a drop on. Uses the same seat too.
In fact, anything made to fit the SE will work, including the Wolfmas SE luggage racks as well as CJ Designs Tail racks.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 02-17-2013, 10:58 AM   #8231
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,278
Are you talking about this one?:
http://www.ktmtwins.com/ktm-950-supe...afari-gas-tank
Old 02-17-2013, 11:41 AM   #8232
wpbarlow OP
Oddometer: 11,281
My charging system stopped charging. Changed the RR with a new stock unit and still not charging. Any suggestions beyond a stator, and where to check to make sure?
Thanks.
wpbarlow is offline   Reply With Quote
Old 02-17-2013, 01:12 PM   #8233
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,713
Originally Posted by wiseblood View Post
Yes.
Mike -
Old 02-17-2013, 02:45 PM   #8234
awork13
Gas was made to burn
Oddometer: 313
Thanks.
Make sure your battery is still good, then check the connector coming out of the stator to see is there is an open and to see if its putting out AC voltage.
2012 Honda CB1000R
2013 Victory Cross Country
2003 Honda CR125
2009 CRF150R
awork13 is offline   Reply With Quote
Old 02-17-2013, 03:35 PM   #8235
nattyMo
Oddometer: 573
Walter,
I've had a few problems with my charging system during the past years. All resolved. I've posted a couple of times here and there on Adv. This info may help.
First you must have a known good battery to diagnose any charging system issue.
Here are my posts on the subject.
http://www.advrider.com/forums/showp...postcount=4313
http://www.advrider.com/forums/showp...postcount=4326
http://www.advrider.com/forums/showp...postcount=7116
http://www.advrider.com/forums/showp...postcount=7122
http://www.advrider.com/forums/showp...7&postcount=67
Those pretty much sum up my issues.
Let me know if you have any other questions.
NM
Thanks.
nattyMo screwed with this post 02-17-2013 at 03:48 PM
nattyMo is offline   Reply With Quote
Times are GMT -7.   It's 09:27 PM.
