Old 02-22-2013, 02:30 PM   #8266
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
Oil sight tube
Last year I was looking into plugging the sight tube holes with bolts.
I did some searches for bolt sizes and finally found one post with the
bolt size. I wrote down the bolt size, problem is, I got to find we're I put
it. I will post when I find it.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 02-22-2013, 03:27 PM   #8267
MotoSteve
Functioning Motard
MotoSteve's Avatar
Oddometer: 363
Thank you.
Originally Posted by Thumper996 View Post
M8X1 Ace Hardware carries the best metric selection in the USA
KTM 950sm, Rattler 110.
MotoSteve is offline   Reply With Quote
Old 02-22-2013, 03:28 PM   #8268
MotoSteve
Functioning Motard
MotoSteve's Avatar
Oddometer: 363
Good idea. Thanks.
Originally Posted by EastSideSM View Post
You also might want to use some copper crush washers with the bolts you use to seal it off.
Old 02-22-2013, 03:33 PM   #8269
MotoSteve
Functioning Motard
MotoSteve's Avatar
Oddometer: 363
Thanks for the kind words. Glad to be back.
Originally Posted by nattyMo View Post
I see someone has posted the bolt spec already. I just wanted to say welcome back! Having gone through back surgery myself I know it's a tough road back. Glad to see you haven't given up on riding.
NM
Old 02-22-2013, 07:53 PM   #8270
Thumper996
Thumper996's Avatar
Oddometer: 592
Re: Metric hardware... Ace maybe not bad for a local source.. but for a truly massive selection you should check out these guys.. not the best web site but they sure do have selection covered.
http://mdmetric.com/index.html
Pro-Bolt usa also does a great job with moto specific hardware.
http://www.probolt-usa.com/
Cheers.
r
Thanks for info, but really Ace by far kills Lowes and Home Depot for flange and non-flange metric bolts and nuts. Hopefully you have one in your area. Same place i picked up a perfect fit o-ring in a pinch to fix my clutch slave cylinder until i bought an after marker unit.
Thumper996 is offline   Reply With Quote
Old 02-23-2013, 02:12 PM   #8271
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,827
Originally Posted by Spoke View Post
Thanks mdbr. This bike does make me feel special, I never expected the engine to run as it does Just ordered the 690 wind screen. Didn't think I would want a shield being that the GS will be my longer distance bike but it is really easy to go +80mph on the SMR and the wind blast is crazy on the body.
For cold weather . . . You may want a bigger handlebar mount screen.
I use a Slipstreamer SpitFire screen:
Motorcycles . . . my Happy medicine.
Live to ride . . . ride to Live . . . just like breathing to Live . . .
“One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure.” – Steve McQueen
mcmann is online now   Reply With Quote
Old 02-24-2013, 09:45 AM   #8272
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Originally Posted by MotoSteve View Post
Good idea. Thanks.
And you should exercise your facial muscles so you don't cramp up from grinning ear to ear while you are riding!!!
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 02-25-2013, 11:23 AM   #8273
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 12,718
What's that hose for?
Was wrenching a bit this weekend, and found a hose hanging down between the oil tank and the exhaust header. It looked like it had melted / baked pretty good there for a while. I pulled it out to take a picture:
Context (you see it down there):
I didn't have time (yet) to pull the tank and trace it. Any ideas what it is? Coolant overflow hose?
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is online now   Reply With Quote
Old 02-25-2013, 01:21 PM   #8274
karviet
Oddometer: 28
In renazzco
Someone have a renazzco seat. Do you Know why they are so confortable ?
karviet is offline   Reply With Quote
Old 02-25-2013, 01:33 PM   #8275
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 12,718
Is it because they are filled with puppies and rainbows?
Old 02-25-2013, 05:30 PM   #8276
nattyMo
Oddometer: 570
On the SMR that should be the coolant fluid overflow hose if memory serves.
NM
nattyMo is offline   Reply With Quote
Old 02-25-2013, 05:34 PM   #8277
KHVol
Oddometer: 2,453
They aren't...get a Seat Concepts seat..save yourself a few hundred dollars and short term paralysis
"Character cannot be summoned at the moment of crisis if it has been squandered by years of compromise and rationalization"
KHVol screwed with this post 02-25-2013 at 06:51 PM
KHVol is offline   Reply With Quote
Old 02-25-2013, 06:42 PM   #8278
Thumper996
Thumper996's Avatar
Oddometer: 592
It's part of the EVAP Canister system. There is suppossed to be a metal cap on the line to seal it off. It runs up under the air box and meets other lines as part of the EVAP system unless you have removed that stuff.
http://www.advrider.com/forums/showthread.php?t=132080
Thumper996 screwed with this post 02-25-2013 at 06:48 PM
Old 02-25-2013, 08:03 PM   #8279
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 12,718
Thanks for the info!!
Now... Canister has already been removed, so... .
(Also, gas venting next to a hot header? )
Old 02-26-2013, 02:45 PM   #8280
nattyMo
Oddometer: 570
I confirmed in both the parts diag and service manual. Not close to my SMR to confirm in person but I'm sure now that on a 950SMR that is the coolant overflow tube. You are not missing a cap.
Evap is routed differently from the 950 Adv shown in the link Thumper provided.
Note the color of inside the tube, looks like burnt coolant. If you were dumping raw fuel onto your header you would notice right away.
Times are GMT -7.   It's 12:20 PM.
