Old 03-16-2013, 04:30 PM   #8341
k-moe
Oddometer: 2,588
Originally Posted by 900rider View Post
Creative, but don't all these bikes have an idle adjust knob OEM?
My SMR does.
Originally Posted by JohnE65c View Post
I wanted to do a check on the idle mixture screw
900rider, I think you're thinking of the idle speed adjustment knob.
k-moe is offline   Reply With Quote
Old 03-16-2013, 04:34 PM   #8342
900rider
Oddometer: 644
Of course I was
That was a test.
You passed
900rider is offline   Reply With Quote
Old 03-16-2013, 11:18 PM   #8343
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
Motorex Oil
In my bike, I have always used Motul because in the past it was hard to find the recommended Motorex oil. I finally found a local shop that started carrying it, so I thought I would give it a try. I almost changed my mind when I seen the price, it must have gold in it. After doing the oil change, I fired the monster up and took it for a short ride. Motorex may be a good oil but i have noticed the bike does not shift as smooth as it did with the Motul oil.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 03-17-2013, 06:46 AM   #8344
900rider
Oddometer: 644
I had the same experience with the price of motorex.
Ive run Mobil 1 synthetic car oil for 15,000 miles and like it. I think Garry has run it for like 40,000!
Old 03-17-2013, 07:15 AM   #8345
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,219
50K+ miles and counting. The Mobil 1 15W-50 is the only weight that is NOT energy-conserving, so it's safe for use on wet clutches. Ran it for 40K+ miles on my Sprint RS too. Obviously I ride a lot which means lots of oil/filter changes. I can't see paying close to $20 for a liter of liquid black gold.
2007 KTM 950 SM-R
2009 KTM 530 EXC
http://www.MotoRoads.net
Garry is offline   Reply With Quote
Old 03-17-2013, 08:12 AM   #8346
900rider
Oddometer: 644
Garry, how often do you change your oil and filter?
Old 03-17-2013, 10:16 AM   #8347
Garry
Old and In The Way
Garry's Avatar
Oddometer: 1,219
Every 3000 miles, religiously. Always with a new OEM filter.
2007 KTM 950 SM-R
2009 KTM 530 EXC
Old 03-17-2013, 02:46 PM   #8348
angustoyou
Oddometer: 25
Originally Posted by Sevv View Post
Doing that now. Thanks. Will report back.
That's worked for me in the past. But if you're getting air appearing in there, it may be that you have a slightly leaky seal. Fluid out = air in.
angustoyou is offline   Reply With Quote
Old 03-18-2013, 11:02 AM   #8349
karviet
Oddometer: 28
Tool
Good job !!!!
My SMR does.
karviet is offline   Reply With Quote
Old 03-18-2013, 03:00 PM   #8350
corndog67
Oddometer: 1,281
I suppose you guys saw my thread about my gas tank changing shape when it was off the bike for 3+ weeks. A sit in the sun for half a day and it went right back on.
I just installed a CPRFab airfilter and airbox removal kit. And a Factory Jetting, Jet Kit. 175/180, 45 pilots, needle in the middle position. 2 1/2 turns on the idle mixture screws. Bike runs strong and makes good noises, big time honk from the carbs when you get on it. Pulls the front off in 3rd gear now, with a 16 tooth c/s front on it.
I don't know if it picked up 8-10% in power as claimed, but I do like the way it runs now.
corndog67 is offline   Reply With Quote
Old 03-18-2013, 04:47 PM   #8351
mrdirtbikerider
Husaberg rider
Oddometer: 271
What did the CPRFab airfilter cost?
06 KTM 950 Sm
10 Husaberg FE 390
Old 03-18-2013, 05:10 PM   #8352
corndog67
Oddometer: 1,281
$300.
Old 03-18-2013, 05:23 PM   #8353
mousitsas
mousitsas's Avatar
Oddometer: 2,728
These filters are made and can be supplied by UK based ITG at a fraction of that cost. Member Sportingwood can sort you out with filter and base plate for about half that money if I remember well. Check the vendors subforum.
Old 03-18-2013, 05:27 PM   #8354
JohnE65c
Oddometer: 40
I had the same problem with mine last week. I should have read the posts about this first. Instead, I removed the top-front rubber mount from the frame, and trimmed down the back section of the diameter so the tank would slide farther forward. Then I ground a big chamfer on the rear mounting bolt to get it started. It was still a fight to the finish.
JohnE65c is offline   Reply With Quote
Old 03-19-2013, 06:35 AM   #8355
Smilin' Dave
I am smiling
Oddometer: 121
I was going to do that myself but there was a clearance issue with something. Can't remember what. Maybe tank to rad.? If you have not already looked at this, check that the leading edge of the tank has not come into contact with anything it shouldn't have.
Dave
'06 950 SM
'01 1150 GS
'96 KLR 650
'88 ZX-10
Smilin' Dave is offline   Reply With Quote
Times are GMT -7.   It's 06:17 PM.
