Old 07-21-2013, 01:35 PM   #8776
950smr
Oddometer: 24
just picked up my new to me supermoto
950smr is offline   Reply With Quote
Old 07-21-2013, 01:40 PM   #8777
geoffh
Oddometer: 64
Welcome to the fold, and to advrider.
The bike looks clean! A lot cleaner than mine at least
geoffh is offline   Reply With Quote
Old 07-21-2013, 02:52 PM   #8778
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,088
Nice! Congrats!
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 07-21-2013, 03:29 PM   #8779
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
Very nice. I'll find out tomorrow if the deal on the one I was looking at will go through.
How much does an 06 SM go for in States right now?
Originally Posted by An Appalachian mudsquid
Why do we always hurt the ones we hit?
Cos is offline   Reply With Quote
Old 07-22-2013, 04:42 AM   #8780
wiseblood
Hall Monitor
wiseblood's Avatar
Oddometer: 13,088
Originally Posted by atk_nut View Post
Hello, new (2007 SM) 950 owner here. Does the SM have a low octane plug under the seat like the adv?
Any issues with running a couple of tanks of 87? (That's all there was.) Do you guys always go for 91 (95RON)?
Just a note about octane: The consequence of using a lower octane number from what is recommended in the manual is premature detonation. That can cause some serious problems in a motor -- essentially causing the fuel in the cylinder to ignite at the wrong part of the cycle. This can damage pistons and valves.
The higher the octane value, the more resistant the fuel is to igniting. The octane requirements of the engine are based on the design of the engine -- including the internal temperatures. Octane isn't an indication of "power" of the fuel, and your engine won't run with "less" or "more" power depending on the octane value.
You may never have a problem running 87 in an engine designed for 89 or 91 or 93. But, if you DO blow a piston or break a valve, you will kick yourself, wondering if the savings was worth it.
Sorry if this is remedial stuff for all of you. Just... been there, done that!
Old 07-22-2013, 08:50 AM   #8781
wpbarlow OP
Oddometer: 11,069
Holy cow! 7 Years
and 39,996 (s)miles after yesterday's high fun/twisty NJ/PA ride.
I neglected to take a good bike pic, so here's one at the start
The "set" button on the console went inop. Don't know what happened, but depressing the rubber button with a finger doesn't work, but it does pressing it with a pen. Anyone ever take the console apart?
wpbarlow is offline   Reply With Quote
Old 07-22-2013, 10:17 AM   #8782
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
Thanks.
I too have wondered if the SM has a low octane plug.
I have had to run low octane fuel several times on long
trips were that's all I could find. I try to use high octane
when I can.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 07-22-2013, 11:37 AM   #8783
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Walter, our bikes must be in cahoots. My set button stopped working properly just this weekend. I have to really mash it in to get it to rest the trip odo. My guess is that there is something in there (dust, dirt etc) causing it to act like that.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 07-22-2013, 12:40 PM   #8784
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,690
The set "button" is a small switch. You can probably clean it out with contact cleaner.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 07-22-2013, 04:16 PM   #8785
JohnE65c
Oddometer: 46
I did a carb sync for the first time this weekend @ around 15k miles. The bike previously started easily, but wasn't as smooth as it used to be, lost a couple mpg, and had that unburned exhaust gas smell. After the sync, my only question is, why the heck did I wait so long ? The engine now runs smoother, has better response and is even more fun to ride !
Oh yeah, 15k miles. That means a new fuel pump is next on the list.
JohnE65c is offline   Reply With Quote
Old 07-22-2013, 04:37 PM   #8786
mrdirtbikerider
Husaberg rider
Oddometer: 271
My bike is about due for a carb sync. I don't have any experience syncing carbs, so I will have to find the easiest and most simple sync tool.
06 KTM 950 Sm
10 Husaberg FE 390
Old 07-22-2013, 08:48 PM   #8787
Kurlee
2009: A Bike Odyssey
Kurlee's Avatar
Oddometer: 1,928
Hey all! Just picked up a 2007 KTM 950 SMR. I have been having an absolute blast with it. I'll be doing the weekend fun stuff with her and bumping the GS to daily commute/ travel bike duty full time. Any new owner tips?
Kurlee is offline   Reply With Quote
Old 07-22-2013, 09:52 PM   #8788
Cos
Re-Greekified
Cos's Avatar
Oddometer: 10,431
So a fuel pump failure is just kinda taken for granted?
What's the cost of repair?
Old 07-23-2013, 02:16 AM   #8789
900rider
Oddometer: 644
I had the dealer do it and it was $150 ish.
Its really not a hard job. The pump was about $130 for another one from ktm.
900rider is offline   Reply With Quote
Old 07-23-2013, 06:30 AM   #8790
wpbarlow OP
Oddometer: 11,069
As little as ~$35 for a replacement set of points and about an hour or so of labor on the low end to the ~$150 for a replacement pump done by a dealer.
In between that range are a couple of common alternatives: Bean pointless conversion, vacuum pump, Facet electric pump.
BTW-- if you have the dealer replace your pump-- don't toss it, sell it here cheaply so that someone who prefers to repair can have a spare. 900Rider-- did you save yours?
Times are GMT -7.   It's 07:58 PM.
