Old 09-27-2008, 04:28 PM   #871
aeronaut
Oddometer: 420
Anyone know where I can order jets for the 950sm? Not a jet kit, just random main and pilot jets.
aeronaut is offline   Reply With Quote
Old 09-27-2008, 06:08 PM   #872
never2old4fun
never2old4fun's Avatar
Oddometer: 462
Which jets( mains or others) and which sizes? I have some extras.
never2old4fun is offline   Reply With Quote
Old 09-27-2008, 06:42 PM   #873
aeronaut
Oddometer: 420
Never2old4fun,
I think I answered you on another forum!
But, 2 175 mains would be good. 2 175, and 1 180 main would be great.
Very considerate of you for considering!
aeronaut screwed with this post 09-27-2008 at 07:24 PM
Old 09-27-2008, 07:16 PM   #874
wpbarlow OP
Oddometer: 10,458
Originally Posted by ABADV
The blacked out pipe looks really good. As stock, it disrupts the visual of the motor and the whole center of the bike.
wpbarlow is offline   Reply With Quote
Old 09-27-2008, 08:26 PM   #875
wsdbikes
New Max is Mad
wsdbikes's Avatar
Oddometer: 1,281
Originally Posted by Garry
I was never able to get the dots to pull apart. The glue that held the dots to the headlight mask started letting go on the bottom dots (the ones with the most leverage from wind on them). They've also been on there for about 10K miles.
The screen came with an extra set of dots (4 per side) that I used to install it tonight for my trip this weekend. I will probably drill holes and bolt it on over the winter. Laminar Lip says they will send you the bolts/etc if you ask.
Dzus
easy on, easy off
Wsdbikes
"I only wish I had video running when WSD did a no footed can-can over some boulders on mainline....two feet of air easy..." -Abdelhub
Yeah, on the GS http://vimeo.com/3232838
Notable Past-'01 KLR 250, 95 R1100GS, 06 KTM 950 SM, 69 Bridgestone 90
wsdbikes is offline   Reply With Quote
Old 09-28-2008, 06:17 AM   #876
aeronaut
Oddometer: 420
Originally Posted by wsdbikes
Dzus
easy on, easy off
I haven't been able to find Dzus receptacles that would work all that well.
Old 09-28-2008, 10:48 AM   #877
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,133
So Walter, seein's how you have both bikes, what do you think it would take to fit the SE exhaust pipe to the SM?
If I could get those parts to fit my SM, I could fit a skid plate and more easily justify some spoked 19/18 wheels for my SM and not worry about the exposed undercarriage.
Cause I really wish they would have stuck with this exhaust:
And I TOTALLY dig this:
Thanks for the pic of your bike, Brent!
2005.5 KTM 950 Adventure
2005 Ducati ST3
Chuckracer screwed with this post 09-28-2008 at 11:08 AM
Chuckracer is offline   Reply With Quote
Old 09-28-2008, 06:55 PM   #878
wpbarlow OP
Oddometer: 10,458
Too much work to make it fit. Besides, as I posted earlier in the thread (iirc)- a KTM representative said they fitted the pipe on the SM to get more and better hp/torque; more fitting for the street bike (as well as being more passenger-friendly/. The power difference between the two is noticeable- not that the SE is slow by any means: but I like the feel from the SM more.
Otoh, if we didn't have a the current SM setup as reference, we probably wouldn't think the SM was slow with the SE pipe.
I'm convinced that the SE is a better/wider use "twofer" base than the SM- but that the SM would always be a better streetbike because it's suspension and geometry is better suited for pavement use. But if I was reduced to having just one, it would be the SM because of that and the fact that I could still have fun on unpaved roads.
PS: Brents' setup did indeed look great!
Old 09-28-2008, 07:05 PM   #879
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,133
Well, I'd bet if/when I bottom this thing out and flatten the exhaust, it's gonna be a LOT slower than a non-smushed SE pipe! I'm not concerned with top HP numbers. I am concerned with a little added versatility, and there's no new bike on my horizon, so I'd like to mod what I have to suit me.
Sometime when you're taking pics, could you shoot some close up pics of that side of the motor and oil tank, etc? I'd like to see the differences up close and make some plans. Is that an SE oil tank on the high pipe prototype? Thanks for the info!
2005 Ducati ST3
Old 09-28-2008, 08:30 PM   #880
wpbarlow OP
Oddometer: 10,458
... I'm not concerned with top HP numbers. ...Sometime when you're taking pics, could you shoot some close up pics of that side of the motor and oil tank, etc?...
The hp/torque improvement was in the midrange, from what I recall them saying.
I'll try to take some detail pics the next day or two.
Old 09-30-2008, 11:08 AM   #881
wpbarlow OP
Oddometer: 10,458
Pipe swap might be doable...
Here are the pictures-- will require about $700 worth of pipes if you use KTM pieces (or the aftermarket 2 into 1 header; which would be good if it works, and no more expensive)
Old 09-30-2008, 06:52 PM   #882
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,133
Awesome!! Thank you very much Walter, this is very cool of you to do!
As I thought...totally do-able. I'd want to change the oil tank as well so I can put the skid plate on it...hmm...how about that cool inner fender on the SE? Would that bolt up to the SM as well?
Know of anybody parting an SE? He he he...doubt it!
Thanks again!
*edit* BTW, I've saved the pics, so if you want to dump them off your server, feel free.
2005 Ducati ST3
Chuckracer screwed with this post 09-30-2008 at 07:02 PM
Old 10-02-2008, 08:37 PM   #883
aeronaut
Oddometer: 420
FYI, I found main jets here for a good price:
http://www.jetsrus.com/main_page.htm
Under Jet & Jet kits -> Dirt Bikes -> KTM -> 950 SuperMoto
Old 10-06-2008, 12:01 AM   #884
flashash
Oddometer: 15
Hi guys this is my first post!
I have had my 950sm for a week and already damaged the pipes!!
I'm suessing there isn't an off the shelf high pipe available nor a bash plate!
I guess I'll have to try and fabricate something!
Cheers
flashash is offline   Reply With Quote
Old 10-06-2008, 05:59 AM   #885
docgonzo
Old Gadfly
docgonzo's Avatar
Location: within 20 miles of the Center of the Universe
Oddometer: 13,391
with all due respect
Really, folks, the SM is a street bike, so you don't need a high pipe or a bash plate. Yes, it rides well on graded dirt roads, but basically any bike will if you don't mind it getting dirty.
If you want to ride in the woods, do what Walter did and get a bike with some clearance, some suspension travel, and a decent bash plate.
And if you can only afford one bike, and want to have a real dual sport, then the modern version of the TransAlp is the bike for you. The SE.
Then all you need to convert from street to dirt is to put a true knobby on the front. The SE keeps up with singles in the woods with a knobby on the front.
Just saying. Seems silly to spend $700 on exhaust and oil tank modifications to bash your street bike on some rocks!
Sorry for the interruption. I'll slide back into the SE threads!
later, *
docgonzo is offline   Reply With Quote
Times are GMT -7.   It's 04:18 AM.
