Old 06-08-2012, 08:39 PM   #4156
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,519
Originally Posted by traveltoad View Post
Flashy! Let's see the whole package.
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 06-08-2012, 08:51 PM   #4157
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Originally Posted by HickOnACrick View Post
You need a longer vent hose.
07 SE
PG007
Old 06-08-2012, 09:01 PM   #4158
HickOnACrick
Groovinator
Oddometer: 2,519
My wife thinks my hose is just fine...thank you very much
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 06-08-2012, 09:18 PM   #4159
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,273
I heard the hose was fine but that you have gas.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is online now   Reply With Quote
Old 06-09-2012, 07:26 AM   #4160
triplenickel
Oddometer: 2,428
Zing!
07 SE
PG007
Old 06-09-2012, 02:41 PM   #4161
max37
max37 italia
Oddometer: 37
fantastico
max37 is offline   Reply With Quote
Old 06-10-2012, 12:50 PM   #4162
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,704
I finally got my decals back from the printer:
Hick,
How do you like the SPS on the SE. I'm thinking about getting the treatment.
jimmex is offline   Reply With Quote
Old 06-10-2012, 03:16 PM   #4163
HickOnACrick
Groovinator
Oddometer: 2,519
Originally Posted by jimmex View Post
Hick,
I like it much more than stock. Much plusher than stock, and I wanted a setup that would not bounce me off the bike when I was trying to climb steep and rocky stuff. One of the fork seals started leaking after one year, which was kinda a bummer as fork seals are $$$ for these beasts.
Where are you in West Texas?
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 06-11-2012, 05:39 AM   #4164
ata
expat in the jungle
ata's Avatar
Oddometer: 2,285
and... how good is that?. you know $$$
Youth is wasted on the young
Need some help<<<<<<>>>>>>> wet wanderings
ata is offline   Reply With Quote
Old 06-12-2012, 03:15 AM   #4165
LukasM
Oddometer: 5,418
Skip those lattes for a day or three and you will be able to afford one.
You can get the newer and much better lower friction / long life SKF forks seals for $18 list price. KTM 48600969.
Old 06-12-2012, 05:55 AM   #4166
HickOnACrick
Groovinator
Oddometer: 2,519
It's not the Lattes that break me, it's the hookers
I considered the SKF, but was told (by my mechanic) that they would not last as long as stock wipers and seals. The first stock set lasted about 7K miles. The second set (put on by SPS) only lasted about 3K - and at least 2K of that was highway riding whereas the previous 7K had been almost entirely off-road.
Who knows?? A single stubborn piece of grit can destroy a set in half a mile as quickly as it can 10 thousand miles.
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 06-12-2012, 06:12 AM   #4167
LukasM
Oddometer: 5,418
Every suspension tuner and the three mechanics I talked to at the KTM factory all highly recommended the SKFs. They are not magic but they certainly perform and hold up better. It's worth a shot for <$18.
But if you want to really make sure that you don't get any more leaks, try some full length neoprene fork protectors. They should have velcro so they can be removed for cleaning every now and then so there is no grit behind them (every time after a mud bath), and you should use the open back style lower fork guards so they do not limit your travel because they are bunching up.
Beta used these on his RTW trip and didn't have a single leak, while his two buddies with no protection had to change seals 7 times riding the same route. IIRC Colebatch has about 50.000 kms on his WP 48s, lots of it off road, no leaks.
If you are a pro rider you might notice a tiny amount of stiction, but on an adventure bike I'd say the increase in reliability is worth it, and you probably won't notice it anyway.
Old 06-12-2012, 07:46 AM   #4168
ktm950se
ktm950se's Avatar
Oddometer: 1,385
I just had my forks re-valved by Factory Connection, and was planning on installing a set of fork socks when re-installing them on the bike. When I asked FC about doing this, they directed me not to do so, as they feel that dirt will eventually get past the sock and be held in place there and act as sand paper on the tubes and seals.
Perhaps this wouldn't be an issue if I cleaned the socks often, maybe even daily?
ktm950se
ktm950se is offline   Reply With Quote
Old 06-12-2012, 07:50 AM   #4169
LukasM
Oddometer: 5,418
Who now do I believe?
ktm950se
Why do you have to chose who to believe? Their experience is in line with what I said - except I gave a solution. Get full length socks (so there is no easy way for dirt to get in) and get them with velcro, so you can easily take them off for periodic cleaning.
Old 06-12-2012, 07:55 AM   #4170
ktm950se
ktm950se's Avatar
Oddometer: 1,385
I am inclined to do so, but will be sure to clean them probably more often than actually required, just to avoid the potential problems running them could cause...
ktm950se
Times are GMT -7.   It's 05:34 PM.
