Old 09-12-2012, 12:21 AM   #4351
LaBree
Oddometer: 24
Originally Posted by MP5 View Post
If that hill is as steep as it looks, (and pics usually don't do justise to depth and perception), than I am impressed man!! That looks STEEP. Nice
I was there when he drove it uphill, it actually is that steep or even steper at the top.
I did not dare to drive my SE up there, but then again I am not 6'5" to walk it up there
LaBree is offline   Reply With Quote
Old 09-15-2012, 11:05 AM   #4352
wilso122
Oddometer: 184
Rally Designs face lift
Gave her a nice face lift
wilso122 is offline   Reply With Quote
Old 09-16-2012, 08:27 AM   #4353
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,597
Looks fantastic!
Yellow Pig is online now   Reply With Quote
Old 09-16-2012, 02:36 PM   #4354
Grayspeed
Grayspeed's Avatar
Oddometer: 15
Oh yes, very nice. I look at their website every few days and each time it gets closer and closer to buying one of those kits!
Grayspeed is offline   Reply With Quote
Old 09-17-2012, 01:20 AM   #4355
wilso122
Oddometer: 184
Thanks guys, it looks fantastic, really happy with the kit, well made, light and looks the biz! Only problem is I messed up the graphics putting them on so dont look closely!
Also fitted up the GPR full 2-1 system, it doesnt come with the correct brackets so need to make some up this weekend to finish the job off. Couple of thoughts, looks great, would need to remove the system for an oil change to get at the oil filter and need to shop out the GiT bash plate to fit around it. Also not sure if it will run hotter, seems to run very close to the Rad and clutch cover which might increase the overall temp.
Work in progress...
Old 09-17-2012, 02:25 AM   #4356
Dan950ser
NW Shredder
Oddometer: 492
Nice build can't wait to hear more about the gpr 2-1.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Old 09-17-2012, 12:37 PM   #4357
Trogg
Trogg's Avatar
Oddometer: 8
Just a quick heads up!!!! just remember to wrap some exhaust cloth tape around the exhaust from the small carbon heat shield to the bottom of the exhaust springs; otherwise you will burn/melt a lovely hole in your rallye pants!! expensive and it hurts. Don't ask how I know. Brilliant system, I have mine fitted with akro tail titanium pipe, on my 950 adventure, with SE back end (swingarm/shock). So I kind of half belong here!! VBR trogg.
GO!!!!!!!!!!!!!!!!!!
Trogg is offline   Reply With Quote
Old 09-17-2012, 02:01 PM   #4358
wilso122
Oddometer: 184
Cool good tip, was thinking about a ceramic wrap but don't know enough about them to do it.
Old 09-17-2012, 02:25 PM   #4359
Trogg
Trogg's Avatar
Oddometer: 8
Go onto ebay and have a look for 2" exhaust tape/cloth ( I went for white as the heat eventually turns it the same colour as exhaust). Choose one with the stainless metal cable ties. You need to buy 1 metre length. When you cut the cloth , fold end slightly back (1/2") on it's self and place this bit face down on exhaust. Then wrap around over it's self once tightly and then overlap along the pipe. Use the first metal tie to secure the beginning lap in middle. On reaching the end cut cloth, half inch longer and fold back as in beginning and secure with tie. Tightly wounding will secure the rest in place. Problem solved. This exhaust really gets hot here and will also loosen the carbob shild. You can even lose it!!. I used copper grease and really tighten - check after riding or pre - riding, as you always check your bike over !!! trogg
Old 09-18-2012, 06:34 AM   #4360
wilso122
Oddometer: 184
Top man cheers Trogg, never used this stuff before, do you have a picture you can load up?
This the stuff you mean? guessing it is...
http://www.ebay.co.uk/itm/White-10mt-Thermal-Heat-Wrap-Shield-Ties-for-Exhaust-Manifold-Downpipe-Tape-/250877040121?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a696fd5f9
Thanks for your help.
Old 09-18-2012, 08:21 AM   #4361
SE Steve
Super Noob
SE Steve's Avatar
Oddometer: 242
Work in progress...
More pictures! Looks good
SE Steve is offline   Reply With Quote
Old 09-18-2012, 10:15 AM   #4362
GSingWI
GSingWI's Avatar
Oddometer: 586
SE with a Trail Tech 8"
Added a windshield and headlight cover
http://pjm1.smugmug.com/Motorcycles/.../IMG0337-L.jpg
GSingWI is offline   Reply With Quote
Old 09-20-2012, 09:41 AM   #4363
Trogg
Trogg's Avatar
Oddometer: 8
Hi, that's the correct cloth and metal tie's you need - Never uploaded a picture so I will have a try!!!
Old 09-22-2012, 02:21 PM   #4364
wilso122
Oddometer: 184
Talking GPR 2-1 rally designs kit
Not wrapped the system as yet but got round to fitting it up making some support hangers.
The GPR system is fantastic, seems to make a difference when riding as it feels like the power delivery is a lot smoother through the range. Bizarrely seems quieter than the twin akras, might have to whip out the rear baffle and then see No idea if there is any difference in the ADV one or not as this came with the ADV hanger and nothing for the SE, so either the same or got sent the wrong one that fits...... Anyway very very happy with the look, sound and performance so far..
Also fitted up the low fender, and had a tidy up of the tail but completly messed up the plate.. never mind
Needed to cut out the bash plate to make it fit round the GPR
Overall pretty happy with the result
wilso122 screwed with this post 09-22-2012 at 02:25 PM Reason: forgot piccy....
Old 09-22-2012, 02:30 PM   #4365
Balsta
Oddometer: 400
Cool2
Looks great!!! Is the diameter the same as original? I'm looking for a fatter version to fit my SE with a 990 SDR motor, which has larger exhausts. Do you have a photo also of the exhaust pipe out of the rear cylinder?
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Times are GMT -7.   It's 09:24 AM.
