Old 07-27-2006, 08:45 AM   #16
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by Carlos M
Nice "creepinformation" (as ususal)!
I didn't want to be without a replacement and the original diaphragm looked worn. I ended up shelling out for a complete new pump as I couldn't find a rebuilding kit.
Somehow related... I have a recurrent problem with the fuel pump that looks unrelated to the state of the diaphragm: most of the times, when the bike goes into reserve (2001 640) the pump refuses to prime after I switch the fuel manifold into reserve. I found out that I can make it prime by blowing into the tank's breathing pipe.
That trick is so old... I'm pretty sure I'd forgotten about it for at least 20 years. Thanks for the reminder of a good, quick and "clean" alternative to the messier, clumsier methods of priming Carlos.
So... how's tricks?
creeper is offline   Reply With Quote
Old 07-29-2006, 07:58 AM   #17
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Was able to find the 2 outlet version of the Adventures fuel pump thru Heeters Performance Centre at 1/3 the cost of the OEM unit. Also the rebuild kit for $10. I had a feeling that the KTM price was a little out there, kinda like there spin on filter VS the Hi- Flo, both made in a factory in Thailand and Hi-Flos can be had at 1/3 the cost.
gunnerbuck is online now   Reply With Quote
Old 08-02-2006, 12:56 AM   #18
bmwktmbill
Traveler
Oddometer: 5,218
Gunner,
Was the correct part # 11-7903 for their rebuild kit for the square pump.
Just trying to pin down what to order as a spare kit for traveling.
Bill in Tomahawk, WI
bmwktmbill is offline   Reply With Quote
Old 08-02-2006, 07:11 PM   #19
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Bill, I believe Heeters part# for the rebuild kit was ET-79-1103, close to your #.
Old 08-20-2006, 09:47 PM   #20
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Took the new pump apart for comparison to the oem unit, I noticed a couple of differences. The KTM pump has a helper plunger spring on the main diaphram and a spring and ball bearing stopper on the inlet, also the main diaphram is a rubber material as where the two outlet pump has a clearview plastic diaphram. I installed the rebuild kit to see how it would work in the oem pump:I reused the rubber grommits for the check valve diaphrams because the ones supplied in the kit are longer. Put the clearview main diaphram in place of the stocker and put the pump back together. I hooked up my remote tank and fired up the bike, it ran fine with gravity so I set the tank on the floor below the skidplate, no noticeable change. When I reved the engine I could see the fuel speed up in the clear line but the pump could easily keep up. So it looks like the kit works fine but I don't know if the clear plastic diaphram will be as durable as the stock rubber unit when the spring loaded plunger is pushing on it.
Old 08-20-2006, 10:16 PM   #21
Powerslave
n00by tires that would be
Oddometer: 316
Fuel Pump Rebuild Kit
Another option is to have your local dealer order the kit from Parts Unlimited. You'll pay tax but no shipping. They don't sell directly to public.
These pumps are also used on various ATV's and while the PU website is not too helpful, if you're dealer calls they will gladly help out. (Even my crappy local worthless Albuquerque KTM dealer/mechanic could handle this task........only after I gave them the part number of course.)
Mikuni part #: MK-DF52 (is whole rebuild kit)
http://www.mikuni.com/c-fuel_pumps.html
(also lists individual part #'s if you need a specific gasket, valve, etc.)
Price was < $13.00
Cheers,
Sunset_Z
Powerslave is offline   Reply With Quote
Old 01-06-2007, 10:41 PM   #22
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
A bump for old dog.....
Old 04-07-2009, 09:41 PM   #23
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
I'll update this a bit... The rebuild kit I installed over 2.5 years ago is still going strong.... I was wondering if the clear plastic diaphragm would hold up but many miles {flexes} later it's still moving the fuel with no noticeable change... I carry a spare rebuild kit on longer trips just in case....
Old 04-02-2010, 05:40 PM   #24
bmwktmbill
Traveler
Oddometer: 5,218
640a fuel pump rebuild kit
Gunner, anyone...
Which pump repair kit here??
http://www.heeters.com/snbpa.shtml#fuelpumprepairkits
Is his the best source?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
Old 04-02-2010, 08:04 PM   #25
gunnerbuck OP
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Hi Bill,
I used the parts from kit # ml-11-1844... Not quite the same but I combined old and new to make them work... It's been over 3 years with no problems....
Fuel pump rebuild kit (#ML-11-1844)-----$15.99
Kits on this page:http://www.heeters.com/snbpa.shtml#fuelpumprepairkits
gunnerbuck screwed with this post 06-01-2012 at 09:25 AM
Old 04-02-2010, 10:53 PM   #26
bmwktmbill
Traveler
Oddometer: 5,218
Originally Posted by gunnerbuck
Hi Bill,
Got the kit in my sights, thanks for the quick reply.
b
Bill Shockley
Old 04-03-2010, 05:14 AM   #27
overlandr
Dystopist
Oddometer: 5,908
Bit O/T but what's the nominal ID of all the fuel pipe on the 640? Looking at getting some filters from parts unlimited...
overlandr is offline   Reply With Quote
Old 06-21-2011, 12:24 AM   #28
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
KTM 640 Mikuni Fuel Pump
after my original fuel pump stopped working. I purchased this pump:
http://www.aircraftspruce.com/catalo...ifuelpump1.php
which is 14L/H while the original is 32L/H
however, since then the CARB is pouring fuel. when I connect the fuel line directly to the fuel tank it works fine. I even replaced the needle of the CARB float and it didn't solve the problem.
Any Thoughts?
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh is offline   Reply With Quote
Old 06-22-2011, 12:42 AM   #29
bmwktmbill
Traveler
Oddometer: 5,218
Any Thoughts?
ERD,
Not sure I understand what you are describing, anyway, did you replace the O-ring on the float needle seat.
bill
Bill Shockley
Old 02-18-2015, 06:41 PM   #30
LukasM
Oddometer: 5,426
Originally Posted by gunnerbuck View Post
Hi Bill,
Hi Gunner,
Another 5 years later... is your pump still working? Since Lyndon's OEM pump has just crapped out I'd like to get a rebuild kit to carry with me.
Still not sure if I should get the #ML-11-1844 or MK-DF52 kits, I've got the newer style square pump on my Rally.
Cheers,
Lukas
Times are GMT -7.   It's 09:54 PM.
