01-17-2010, 03:49 PM
#15136 | |
Exploring Alabama
Oddometer: 3,090
+1 me too.
Explore / Dream / Discover DeBandi Visit ExploringAlabama.net State Oval Decals Available |
01-17-2010, 04:21 PM
#15137 | ||
Oddometer: 7,755
I discovered those right after my booboo
Albert Einstein Baja trip to the tip 6:10 to Yuma trials and tribulations in the Mojave Baja Blitz Yard sale View Current Location via Spot Tracker |
01-17-2010, 06:30 PM
#15138 |
Oddometer: 108
Xymotic
Regarding the rear inner chain guide wearing out, I had the same problem. After the second one I took a good look and found out that the alignment is off which causes it to wear prematurely, one side of mine had worn through to the aluminum. I used a hammer to gently persuade the aluminum guide into the correct alignment. I think that should have been added with the things to check when you first get your bike (like fixing the clutch cable alignment).
01-17-2010, 06:36 PM
#15139 | ||
Oddometer: 7,755
01-17-2010, 07:47 PM
#15140 | |
Oddometer: 590
Hydraulic Failures
You've also got complete agreement for a lighter pull, but the pull on the hydraulic is lighter than a brand new cable and lever that I had to put on the first day I had the bike. The bike got lazy while they were loading it on the truck and it got to it's new home with a VERY short clutch lever. There is one other small thing that I kinda hinted at, but in reading what I said was not very clear. The slave cylinder could use just a little more stroke. That is why I had to do the reshimming - I got lazy and didn't do as good a job as I should have during installation. That is also why the pull is a little heavier than I would like, in hydraulics it is always a trade-off between stroke length and pressure. If the stroke length on the slave cylinder was longer, the pull would be even heavier. I've seen a couple of people quote $300 as the price. I can't talk for George, but the last time we talked about price, he was trying to hold it closer to $250 plus shipping. Last nugget for the rumor mill. The remote fuel pump for the bigger tank is almost finished. A little more work to get it vibration isolated appears to be the last hurdle. I push him every time we talk to get me a production unit on the UPS truck. I really need it to show up as that is the last MAJOR mod i need to do to the 610. Well, til something else comes up. |
01-17-2010, 07:55 PM
#15141 | ||
Oddometer: 7,755
Yeah George has good stuff, every time I think I'm ok he comes up with a new invention to make me broke again.
01-17-2010, 08:10 PM
#15142 | |
Oddometer: 590
It's only money.............
01-17-2010, 08:15 PM
#15143 | ||
Oddometer: 7,755
01-18-2010, 04:08 AM
#15144 | |
Pig Pen
Oddometer: 1,080
EDIT - guess I should have searched before asking... found OldTexan's writeup with pics on TT: http://www.thumpertalk.com/forum/sho...d.php?t=860471 Lav1200 screwed with this post 01-18-2010 at 04:35 AM |
01-18-2010, 05:55 AM
#15145 |
Oddometer: 453
Trail tech X2?
For those with the X2 light does both lights come on at the same time? Or is low one light and high another???? Thanks for the help.
01-18-2010, 05:57 AM
#15146 |
Deputy Cultural Attaché
Speedo sensor?
I broke my speedo sensor wire in Baja. So, I ordered a replacement and was swapping the two when I realized I'd removed the broken unit without first looking on the wheel side of the caliper to see if it extended any. Figures.
So, anyone want to take a peek at their speedo sensor head, and see if it pokes through the caliper or sits flush with the caliper? I'm looking for a ballpark, like "extends 2 full threads" or some such. It's item 7 in the image below. Thanks in advance.
Successfully surviving motorcycling since 1976. |
01-18-2010, 06:54 AM
#15147 | |
Dromo maniac
Oddometer: 60
Could you please load pictures of the housing ? I did the same think and I do not have any issue, hope I rotate the engine by hand before to adjust the valve clearance and no noise or restriction was observed, by this reazon I think the impeller is not touching the housing. Regards. |
01-18-2010, 07:48 AM
#15148 |
San Diegan
Oddometer: 444
Case saver pics with plastic cover installed over it
http://www.cafehusky.com/forums/show...6&postcount=12 Sure seems like a lot of $$ for a piece of metal and 2 bolts, even if it is cheaper than a new case or welding up your old one. I believe this PN, they have 2, is the clutch cable I bought to back up the factory one on my longer rides - like Baja! http://www.motionpro.com/motorcycle/partno/10-0123/ For the rear chain guide, I have a BRP block. I'm usually against plastic ones, but I had several Baja racers recommend it, so we'll see how it does. My metal ones look pretty beat on the outsides when I'm done with 'em. http://www.brpmoto.com/product_info....oducts_id=2068
Eric D 06 Husqvarna TE610 - IMS 5 gal clear tank, heated grips, Alaska Leather sheepskin, Dirt Bagz, Leo Vince slip on, JD Jetting kit, Utah skid plate, Cycra barkbusters 08 BMW K1200S - It's freakin' awesome Ride reports: - 10 Mar Baja - 08 Feb Baja - 07 Aug West coast PDX->SAN - More! |
01-18-2010, 08:13 AM
#15149 |
the darkness
Oddometer: 3,583
BRP Chain Guide
Speaking of which... I have a BRP chain guide with only a couple of hundred miles on it. If anyone is interested in it, let me know. I'll let it go for $45 shipped. I think they're about $70 + shipping new. This was for the TE510 but was modified to fit the TE610. All it needed to work was filing down the spacer about 1mm on each side.
FS: Street Legal American Trail Killer!! Rebuild threads: '92 XT600, '87 XR250R Lighten up, Francis. ![]() |
01-18-2010, 08:15 AM
#15150 | |
Card carrying greeny
Oddometer: 1,015
I have 2 finger levers and it would be nice if it were a bit easier but it's not that big of a deal. I think this angled arm is the cause of the resistance. The cable has to have dead-on aim to make it rotate smoothly, otherwise you're trying to rip it off the shaft as we've seen in a couple of broken arms. If that arm was straight I bet it would be a one finger pull.
See my pics Dave: The 610 really makes me want to ride like a punk everywhere I go. bikefrk: You now understand supermoto. Your training is complete. |
