Old 01-18-2010, 08:19 AM   #15151
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,161
Originally Posted by Oaxacuzano
Could you please load pictures of the housing ?
I did the same think and I do not have any issue, hope
I rotate the engine by hand before to adjust the valve clearance and no noise or restriction was observed, by this reazon I think the impeller is not touching the housing.
Regards.
After I saw this photo I torn down my 86 400 XCE pump to check clearance as I had resurfaced the housing. I used the old engine builders trick of putting modeling clay on the impeller vanes then assemble the housing on the motor. I had plenty of clearance.
Kinda sounds like there may have been another problem causing the impeller to contact the housing.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 01-18-2010, 08:27 AM   #15152
LostRider
Motorcycle Addict
LostRider's Avatar
Oddometer: 237
Regards.
Hope your luck is better than mine.
Some things are just to much fun to stop doing.
LostRider is offline   Reply With Quote
Old 01-18-2010, 08:43 AM   #15153
Olas
the darkness
Olas's Avatar
Oddometer: 4,064
The water pump gasket is what, 1 or 2 mm thick? Even if the gasket is missing you should be able to have some clearance between the impellers and the housing. My guess is the nut that holds the impeller was not on tight enough.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 01-18-2010, 09:03 AM   #15154
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,837
Originally Posted by Hoder
What's up with that chain?
Old 01-18-2010, 09:08 AM   #15155
edeslaur
San Diegan
edeslaur's Avatar
Oddometer: 445
Chain looks fine to me...
Read backwards, it's all in the last few pages.
Eric D
06 Husqvarna TE610 - IMS 5 gal clear tank, heated grips, Alaska Leather sheepskin, Dirt Bagz, Leo Vince slip on, JD Jetting kit, Utah skid plate, Cycra barkbusters
08 BMW K1200S - It's freakin' awesome
Ride reports:
- 10 Mar Baja
- 08 Feb Baja
- 07 Aug West coast PDX->SAN
- More!
edeslaur is offline   Reply With Quote
Old 01-18-2010, 09:11 AM   #15156
Stroker Ace
Oddometer: 123
Good question!!!! I wonder what the best lube to use is????
Stroker Ace is offline   Reply With Quote
Old 01-18-2010, 09:12 AM   #15157
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,841
Originally Posted by Olas
Speaking of which... I have a BRP chain guide with only a couple of hundred miles on it. If anyone is interested in it, let me know. I'll let it go for $45 shipped. I think they're about $70 + shipping new. This was for the TE510 but was modified to fit the TE610. All it needed to work was filing down the spacer about 1mm on each side.
Um...they're $42.95 plus $5.55 shipping. That's $48.50 new to my door
'00 640 ADV, '01 Girlie, '09 TE450
bobnoxious67 is offline   Reply With Quote
Old 01-18-2010, 09:14 AM   #15158
edeslaur
San Diegan
edeslaur's Avatar
Oddometer: 445
BTW, anyone have pics of that case-saver working?
I'm worried it'll break out the bolts at the case mounts.
Eric D
Ride reports:
- 10 Mar Baja
- 08 Feb Baja
- More!
Old 01-18-2010, 09:17 AM   #15159
Olas
the darkness
Olas's Avatar
Oddometer: 4,064
Really? Where? Damn, I got ripped off if this is true.
Edit: just did a search and could not find anything cheaper than $64.95 + shipping and none were for the Husky. Please show me the link for a new BRP chain guide that is $48.50 shipped.
Rebuild threads:
Old 01-18-2010, 09:22 AM   #15160
bobnoxious67
Baby steps...
Oddometer: 2,841
Just ordered one:
http://cgi.ebay.com/ebaymotors/Husqv...Q5fAccessories
Old 01-18-2010, 09:23 AM   #15161
Olas
the darkness
Olas's Avatar
Oddometer: 4,064
That's a case saver, not a chain guide. Big difference there, buddy.
Rebuild threads:
Old 01-18-2010, 09:25 AM   #15162
bobnoxious67
Baby steps...
Oddometer: 2,841
My bad
Old 01-18-2010, 09:28 AM   #15163
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,041
I don't understand the point? We all know the stock chain is junk..throw it away and put a good chain on the bike..no need for a case saver IMHO.
larryboy is online now   Reply With Quote
Old 01-18-2010, 09:28 AM   #15164
Olas
the darkness
Olas's Avatar
Oddometer: 4,064
I'll buy it if it's cheaper than the ones on Ebay....save me some time making one
Let me know!
Rebuild threads:
Old 01-18-2010, 09:29 AM   #15165
PirateJohn
PirateJohn's Avatar
Oddometer: 22,219
PirateJohn is offline   Reply With Quote
Times are GMT -7.   It's 09:58 PM.
