Old 09-05-2007, 07:17 PM   #1621
Magus
Never grew up...
Magus's Avatar
Oddometer: 96
Buell lights for 610
Originally Posted by Ed@Ford
Just got back from the Buell store (Detroit MI). M0645.1ADA, M1600.1ACMW & Y0421.1ADA came to $211.47. The headlight assembly (Y0421.1ADA) was $116. That's a long way form some of the prices quoted on this thread. A little price gouging maybe?
These are off of the Surdyke site:
Shopping Cart Items Qty. Price
HEADLIGHT GRILLE - $32.71 remove
WINDSCREEN KIT W/DECAL, MIDNIGHT BLACK - . $49.00 remove
HDLIGHT ASSY. RH TRAFFIC - . $46.80 remove
MOUNT, HEADLAMP - . $18.84 remove
Total: $147.35
'13 Honda CBR500
'09 Aprilia RS 125
'06 Ducati Sport Classic
Magus is offline   Reply With Quote
Old 09-05-2007, 08:11 PM   #1622
irnbru
irnbru's Avatar
Oddometer: 65
Thanks Magus, that's more like it.
Cheers.
irnbru is offline   Reply With Quote
Old 09-06-2007, 05:40 AM   #1623
motometal
i like motorcycles
motometal's Avatar
Oddometer: 3,598
i'm thinking about taking out my seat foam and drilling some 1/2" holes from the underside, to soften it up some...this is a temporary measure as it might be several months before I get a Renazco.
anybody out there tried this? Good mod or waste of time?
motometal is offline   Reply With Quote
Old 09-06-2007, 10:35 AM   #1624
parkolay
Oddometer: 6
MT90 life span
Originally Posted by buffallodan
I think tire pressure makes the difference...what psi did you run?
I have less than 1,000 miles on em at this point...I have been running ED78R and MT21F recently but got frustrated with the MT21 cupping. It was my fault they cupped however as I didn't check my tire pressures and ran them too hard on the twisties ...hence back to the MT90's hoping they can take more abuse .
Dan
low 30's though sidewall says 38 max... Maybe I should ease up on the gas and break?
parkolay is offline   Reply With Quote
Old 09-06-2007, 10:59 AM   #1625
levity
nano-Adventurer
levity's Avatar
Oddometer: 1,088
MT90 tire pressure!
Those numbers seem really high for a 330 lb bike!
20-24 psi seems like it would be plenty for the street, 15-16 psi on dirt.
Ride and handling will improve significantly.
Why do you expect/need more than 3k miles out of tires on this bike?
Afterall, using the gas and brakes is the reason we ride!
levity is offline   Reply With Quote
Old 09-06-2007, 11:08 AM   #1626
parkolay
Oddometer: 6
GPS sensor
Has anyone done anything with the "electronic unit GPS" wire(white wire with red stripe behind head light)? It goes to the ECU but looks like an output from the alternator.
Old 09-06-2007, 11:15 AM   #1627
parkolay
Oddometer: 6
tire psi
I was running low 20's for mud and trail which worked out pretty well considering the tread, looking at the max I assumed low 30's would sufice for street and country back road.
I am open to suggestion.
Old 09-06-2007, 11:37 AM   #1628
ra2bach
drive-by poster
ra2bach's Avatar
Oddometer: 4,814
Total: $147.35
so, did you order this? the HDLIGHT ASSY says "RH Traffic". is there a "LH"???
"having dreams to look forward to slows time..."
-- Freeflow
ra2bach is offline   Reply With Quote
Old 09-06-2007, 06:38 PM   #1629
motometal
i like motorcycles
motometal's Avatar
Oddometer: 3,598
I would be careful with that. I heard of at least one guy frying the ECU by hooking up a GPS, don't know all the details...I'd feel better either getting a blessing from the dealer, or just hooking the GPS to a lead that's always hot and is fused properly.
Old 09-06-2007, 09:19 PM   #1630
Magus
Never grew up...
Magus's Avatar
Oddometer: 96
You raise an excellent point:
WINDSCREEN KIT, ARCTIC WHITE, W/DECAL - $48.69 remove
HDLIGHT ASSY. LH. TRAFFIC - . $46.80 remove
Total: $193.84
Seems there is a LH as well and I'm guessing you need the matched pair This might explain the high dollars mentioned in an earlier thread though this does include the optional grill cover. No, I haven't made the plunge and ordered yet. I love the look of the Buell lights, but need to get geared up for the install...
'13 Honda CBR500
'09 Aprilia RS 125
Magus screwed with this post 09-06-2007 at 09:37 PM
Old 09-06-2007, 09:35 PM   #1631
PowerT
PowerT's Avatar
Oddometer: 1,065
You know, there IS a HDLIGHT ASSY LH Traffic as well (#
Y0426.1AD)
My guess is this indicates the direction of the beam dip. It would dip to the right for those that drive on the right, as oppose to the left side of the road.
That’s the thing about traveling. If you’re looking for something, you can almost never find it. But if you are just open to what is there, it’s almost always awesome - Neduro
In spite of illness, In spite even of the archenemy sorrow, One can remain alive long past usual date of disintegration if one is unafraid of change, insatiable in intellectual curiosity, interested in big things and happy in small ways. - Edith Wharton
Need a smugmug coupon? Well here you go z0g48s072w1kE
PowerT is offline   Reply With Quote
Old 09-06-2007, 09:44 PM   #1632
Watercat
. . . gravity sucks
Watercat's Avatar
Oddometer: 1,550
Wink
Check with Chris at Renazco before doing this as I believe they need to use some of your original seat foam when they are reconfiguring your seat.
Get your motor runin' . . . . . "Seek an erection for medical help lasting longer than four hours"
" . . . discovery channel has been shit for over a decade . . . this (ADVrider) is actually good." - OldAndBusted
Expect the unexpected! - Skunked & DfunkD
2006 Husky TE 610
2005 Big Strom
2010 THRUXTON
Watercat is offline   Reply With Quote
Old 09-07-2007, 03:53 PM   #1633
Countdown
Oddometer: 5,323
Got the pig ready to ride
I finally got the last mod done so I am reasonably happy with my TE610. I could not ride the stock bike because of seat height and suspension that would not move. I now have 4,000 miles with no serious problems except several missing bolts. Sprocket nuts are crap, use nylocks and/or locktight. Modifications in order of importance are
Dunlop 606 Rear, 739FA Front
Renazco Saddle "leather"
Softer Damping 2 1/2" lowered by ESP
Utah Skid Plate
Cyrca Guards
WER Damper
ICO Odometer with bike power
76C on RAM mount with bike power
Countdown Roll Chart Holder
Baja Designs H4 Headlight
Chase Harper Number Plate Bag
UFO Tail Light
Heated Grips
Leo Vince Slip On
JD Jetkit
1 less tooth on CS
MSR Fender Tube Bag
Blue Front Fender
Jerry Counts
Countdown is offline   Reply With Quote
Old 09-07-2007, 03:54 PM   #1634
Countdown
Oddometer: 5,323
Front
More Pics
Jerry Counts
Old 09-07-2007, 03:55 PM   #1635
Countdown
Oddometer: 5,323
Dash
Bars
Jerry Counts
Times are GMT -7.   It's 08:25 AM.
