Old 05-25-2010, 11:54 PM   #16966
xymotic
xymotic's Avatar
Oddometer: 8,367
Ffaaaaaaawwwwwkkkkkkk!!!!!
Just got my top end buttoned up after changing the cam chain. Adjusting the valves, got to the last one... dropped the gauge, and it dropped all the way in to the cover resting atop the valve.
AS IF that weren't bad enough, when I try to take a picture of it for you FF's this capital F spider comes crawling out of my engine!
Just on of them dang days
Bah, I'm sure the last valve is fine, and the tool is just aluminum and a little stainless foil... I think I'll just leave it in cuz I don't wanna buy a new water pump gasket What's the worst that could possibly happen it'll rattle around and might kill the spiders!?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 05-26-2010, 12:51 AM   #16967
K7MDL
TE450, TE610
Oddometer: 1,552
Are you sure it is stainless? Might be something magnetic, at least the rivets/hinges, pivots for example. You should be able to take the cover off without destroying the new gasket. After all, I did reuse my 7K old one :-). The filters and oil temps will take care of the wildlife.
K7MDL is offline   Reply With Quote
Old 05-26-2010, 03:57 AM   #16968
"A"
numbum
"A"'s Avatar
Oddometer: 373
IMS Tank
Putting aside the fuel pump for a minute - does anybody know if the large IMS tank will actually fit on a fuel injected TE-610 or is there other stuff in the way? The thought is then to build a small sub-tank from aluminium and mount the fuel pump in that. Possible or not?
I am asking on behalf of my brother who has just purchased a new 610- it's still in the crate.
"A" is offline   Reply With Quote
Old 05-26-2010, 06:09 AM   #16969
xymotic
xymotic's Avatar
Oddometer: 8,367
Turns out the arm is actually steel, and I got it out fairly easily with a magnetic probe, so no taking the cover back off
I have not physically tried it, however George (Up-Tite) says it's possible, and well, he's a freakin genius so I believe him.
Albert Einstein
6:10 to Yuma
Old 05-26-2010, 07:17 AM   #16970
miketv
miketv's Avatar
Oddometer: 332
+1 get a hold of George he'll know.
miketv is offline   Reply With Quote
Old 05-26-2010, 08:33 AM   #16971
carternick79
Cami's Dad
carternick79's Avatar
Oddometer: 266
Originally Posted by Doormandan
The tail light is a Baja Designs as for the turns they are LED but I do not recall the place I bought them. What I need now is a way to put a drop down on George's pipe it;s overheating my left turn signal
Really?? I will hopefully be getting his pipe back from the ceramic coaters this friday. I took my whole system off and had them ceramic coat the whole thing in a color that looks like titanium. Kinda worried about the turn signal now. Thanks for all the info guys.
I'm not fat, I'm HUSKY!!!!
carternick79 is offline   Reply With Quote
Old 05-26-2010, 08:40 AM   #16972
carternick79
Cami's Dad
Oddometer: 266
Originally Posted by DeBandi
Hey carternick79.
Its a bajadesigns Racelight, M/C Single 8 Inch Halogen
details at https://www.bajadesigns.com/NET/P-61...8+Inch+Halogen
Man I would love to see this beast in person. How was it to convert over to the 8" BD? What kind of wiring and mounting had to be done? Also how did you mount your GPS? I've gotr the 550 and am wanting to do the same thing.
Old 05-26-2010, 09:09 AM   #16973
xymotic
xymotic's Avatar
Oddometer: 8,367
anybody know what size the swingarm nut is? looks like maybe 22mm?
Albert Einstein
6:10 to Yuma
Old 05-26-2010, 09:16 AM   #16974
DeBandi
Exploring Alabama
DeBandi's Avatar
Oddometer: 3,100
The install is easy. The only thing I had to do was remove the horn. Many guys simply relocate it.
I have a small plate mounted on the BD frame with a couple of ram balls.
This "mounting experiment" will get tested this weekend in Hot Springs, NC.
If all goes well, I'll have it welded....
Explore / Dream / Discover
DeBandi
Visit ExploringAlabama.net
State Oval Decals Available
DeBandi is offline   Reply With Quote
Old 05-26-2010, 09:21 AM   #16975
oregonsage
oregonsage's Avatar
Oddometer: 1,039
George says it can be done, so does Bill in Salem. Someone just has to make up the subtank and mount ... which no one seems to have done. Bill has drafted plans for this, but as of yet it hasnt been made AFAIK
Husqvarna'13 TXC310R & '84 250 CR,'93 XR650L
Multi-functional Itinerant Nomad
oregonsage is offline   Reply With Quote
Old 05-26-2010, 09:22 AM   #16976
oregonsage
oregonsage's Avatar
Oddometer: 1,039
I would give a magnet a try .. it might work.
Old 05-26-2010, 10:29 AM   #16977
BrandonR
BrandonR's Avatar
Oddometer: 861
If I was doing it I'd seriously consider using a Honda Rancher fuel pump, I think it would be easier to do that than to fab and mount a housing for the stock pump.
Brandon Reed
2009 Husqvarna TE610
BrandonR is offline   Reply With Quote
Old 05-26-2010, 11:05 AM   #16978
carternick79
Cami's Dad
Oddometer: 266
You didn't have to use the AC wiring kit they talk about on the website?
Just a direct wire splice?
Old 05-26-2010, 11:06 AM   #16979
xymotic
xymotic's Avatar
Oddometer: 8,367
This is pretty much my plan as well.
Albert Einstein
6:10 to Yuma
Old 05-26-2010, 12:02 PM   #16980
oregonsage
oregonsage's Avatar
Oddometer: 1,039
What is special about the Rancher fuel pump in this situation? Pics?
Times are GMT -7.   It's 11:02 AM.
