Old 03-17-2012, 10:43 AM   #23011
xymotic
xymotic's Avatar
Oddometer: 8,367
Originally Posted by ebrew View Post
Does the ims tank not fit very well in the 06 te. I can get the rear pins to drop in but then the front will not slide in ( 4/5 mm off) Also plastic side panels fit poorly....thoughts.
I heard that 'they all do that"
I think the solution is to put it out in the sun and warm it up.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 03-17-2012, 10:49 AM   #23012
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,630
Warming it up really does help, match up the front mount first then it'll drop onto the pins.
Old 03-17-2012, 07:44 PM   #23013
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,654
Originally Posted by nathan8315 View Post
Quick battery question*
Does the YTX14-BS fit a 2009 610? I can't seem to find the answer, but seen it mentioned earlier in this thread where batteries are discussed. Not sure if they changed the battery in 2008 or 09.
Yuasa YTZ14S is the one you want. It is about an inch shorter than the stock unit.
Old 03-18-2012, 12:00 AM   #23014
nathan8315
Oddometer: 84
Thanks, I was hoping there was a cheaper option to hold me for a bit. I am wanting to switch to a lithium, but just short on cash right now. My dad put a lithium in his bike and it seems to be working out really good. And its a ton lighter.
Current Bikes:
2009 Husqvarna SM610 (Fully swappable to TE)
2010 F800GS
nathan8315 is offline   Reply With Quote
Old 03-18-2012, 05:35 AM   #23015
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
gave it a shot...
Did not work. If every time u have to pull the tank it has to sit in the sun to put it back on I will return the Pos.
Originally Posted by larryboy View Post
Warming it up really does help, match up the front mount f]irst then it'll drop onto the pins.
ebrew is online now   Reply With Quote
Old 03-18-2012, 10:51 AM   #23016
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,630
I'm with you, getting it to fit on that first time was very frustrating, but I had to have the fuel range and the tank was only $200.
Old 03-18-2012, 02:10 PM   #23017
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,402
does it fit now?
Can you get it on and off now without " heat"
Old 03-18-2012, 03:37 PM   #23018
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,630
Yeah, after the first fitting I never had another problem. The shape gets messed up when the tank sits empty on a shelf.
Old 03-18-2012, 04:47 PM   #23019
K7MDL
TE450, TE610
Oddometer: 1,552
IMS 2006/7 tank fit
With the weight of the fuel and the engine and radiator heat, it will shape itself well enough. Mine has taken a serious beating and keeps on ticking as well. You should see the gouges and scrapes on the lowers. Using it as a trail bike for a bit did not help. Have over 15K miles on that tank in 2.5 years now.
The only issue with fitting the OEM plastics I had is the screw on each side, very front over the radiator. Hole is somewhat oval, and I put a rubber washer under the screw head to help hold the piece from slipping outward away from the tank.
K7MDL is offline   Reply With Quote
Old 03-19-2012, 06:40 PM   #23020
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Originally Posted by poppy View Post
Sooo, where is the pic of the light in action?
here you go. My neighbors think I'm crazy!
FYI, the bottom light is on high beam. Not bad for a $50 set up.
I am here: http://tapatalk.com/map.php?51f3a0
Life is good!
1 lunger screwed with this post 03-19-2012 at 07:58 PM
1 lunger is offline   Reply With Quote
Old 03-19-2012, 11:09 PM   #23021
awshouse
Downwardly mobile
awshouse's Avatar
Oddometer: 435
Hey 1lunger, I am curious about how you mounted it. A semi-permanent mount, yes? As you know I followed your lead with the light, but want to put it on the bike for certain occasions. i modified a RAM mount for that purpose. Can you share how you mounted yours?
It is extremely bright -- going to look into some night exploration!
Andy
2008 Husky TE 610, 2008 KTM 250 XCF-W, 2004 KTM 950 ADV
awshouse is offline   Reply With Quote
Old 03-20-2012, 01:39 AM   #23022
JonXX
Infraction Collector
JonXX's Avatar
Oddometer: 364
We had ourselves a little tech day on St. Patrick's day. Ridealot, R6Jon, Little David and I did some fiddling with our 610's (three SM and one TE). In all we wound up with three valve adjustments (mine were way out, Ridealot and Jon's were pretty good), checked the cam chain tensioners (all good, one's gonna need a chain this summer I think) and I replaced my front and rear wheel bearings and seals as part of my annual.
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member.
"They" said we couldn't run the OBDR on supermotos...
JonXX is offline   Reply With Quote
Old 03-20-2012, 03:42 AM   #23023
1 lunger
1 lunger's Avatar
Oddometer: 1,253
What's was the mileage on these? Had the valves been checked before (600 mile check up)?
I am here: http://tapatalk.com/map.php?bbphok
Life is good!
Old 03-20-2012, 03:56 AM   #23024
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Andy
the zip-ties held it in place while I put hose clamps on. I also put some black duct tape around that part of the bar so it won't get messed up. I have 2" Rox risers which help the light clear the head light shroud. I assume the ram mount will do the same if you're at stock height. Did you get the spot or flood light? I got the flood and I like it. It lights 20' or more each side of the bike. I also have a 45 or 50w head light that's a bit better than the 35w stock one. The LED works with the head light and seems to send the high beam further and stronger. I know that sound weird, but it does. All in all, I like it! $50 was worth the chance and it ended up working really well! I know the high end lights are very lightweight, bright, smaller and look cool, but you just can't beat this for the money!
I am here: http://tapatalk.com/map.php?l4gwcs
Life is good!
1 lunger screwed with this post 03-20-2012 at 05:46 AM
Old 03-20-2012, 06:40 AM   #23025
k47k
k47k's Avatar
Oddometer: 165
does anyone have a picture of the 610 with the tank off? im putting her back together and the left side radiator hose routing is giving me trouble, seems no matter where i put it, its twisted and squashed.
does it go inside or outside of the wiring harness?
k47k is offline   Reply With Quote
Times are GMT -7.   It's 02:08 AM.
