Old 03-09-2012, 05:20 AM   #23041
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,863
Originally Posted by Xcuvator View Post
The bearings may be too small for a single cam or they could be failing because the chain is too tight. Before I went to a manual adjuster I discovered the auto unit had overtightened itself on two occasions.
Chicken or the egg thing here maybe? Valve spring pressure will put more pressure on the cam bearings than the tensioner ever could. How about this? Worn cam bearings could be causing the cam chain to run loose and flap into the reed valve like some of us have seen. I dunno?
Old 03-09-2012, 05:42 AM   #23042
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,301
Originally Posted by gunnr View Post
Out of curiousity, how would one know know the CCT had overtightened itself? I just picked up a low mile 08 and was thinking of checking the number of clicks.
The cam chain tensioner is a HUGE debate issue for the 610, akin to oil type.
Looking at the tensioner it seems impossible that it could overtighten.
It is far more likly that the tensioner was installed incorrectly.
But if you want to check it:
Get a new gasket.
Put bike in gear and roll backwards. This puts the cam chain slack on the tensioner side.
Remove the phillips head cover screw from the tensioner.
Insert a flat blade screw driver into the tensioner and back out the center screw. When doing this count the " clicks" . Fully back out the center screw. Note the number of clicks.
The tensioner will stay at full retraction unless jared.
Remove the tensioner by removing the two bolts that hold it in place.
Insert screw driver and advance the ternsioner again counting the clicks. Full advance varies but is usually 15 clicks.
Compare that to what you got while it was in the engine. 6 to 8 is way good. 12 may mean worn cam chain giude but still ok.
To install, put the bike in gear and roll backwards. This will force the slack in the cam chain to the tensioner side. Retract the tensioner and carefully install in engine keeping it retracted. Once tightened up insert screw driver and gently release tensioner slowing its advance with screw driver till it stops. Count clicks if you want but it will be different than the first time because of the new gasket.
Here's the varmit.The plunger on right presses up against the cam chain guide. its a simple device. It must be installedI with the plunger retracted. It can be incorrectly installed fully extended but will trash the chain guide and maybe more stuff.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is offline   Reply With Quote
Old 03-09-2012, 08:09 AM   #23043
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,245
No kidding, it is doubtful we will really know the complete reason.
"The cam chain tensioner is a HUGE debate issue for the 610, akin to oil type.
It is far more likly that the tensioner was installed incorrectly."
I think my ACCT had overclicked because of what I think was chain whipping at high revs.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 03-09-2012, 08:19 AM   #23044
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,245
After I check the adjuster clicks, I put it back in and ride the bike around the block and pull it back out and see if it is the same as when I first checked it.
Old 03-09-2012, 11:35 AM   #23045
Flashman1
Flashman1's Avatar
Oddometer: 5,313
Husky agrees and put the 510 dual cam head on the 630. BMW decided Husky doesn't need the 630 anymore.
Larry - you are a great tech resource - but I remember reading one of your posts where you said you never got more than 20,000 miles out of any thumper (except a Suzy 200). I think you are harder on bikes than some of us.
I am at nearly 20,000 miles on my 610 - clutch bushing is fine, all wheel bearing fine, on 2nd clutch cable, and 2nd cam chain, all the nuts in the air cleaner cover are still good, do the valves every 4000 mils or so,.
I am not saying you are wrong and I plan on refreshing the top end this summer - but some of us get more miles out of our bikes.
Flashman1 is offline   Reply With Quote
Old 03-09-2012, 11:45 AM   #23046
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,863
Pssst: http://advrider.com/forums/showpost....ostcount=23031
I think I said that I won't go past 20,000 miles on a thumper without a full bare cases rebuild. I ride alone in remote places and don't want the machine to leave me for dead.
Perhaps you don't know how to check for wear on the things I'm telling you about? No offense. I mean, my first clutch bushing was gone at 7,000 miles. It's entirely possible that you putt around at 2500 rpm and I average 5,000 rpm and wear things out in half the time, but I've seen the same wear on a second 610 not owned by me...you're on borrowed time with your bike.
I'll shut up now, I feel like I'm beating a dead horse.
Old 03-09-2012, 02:33 PM   #23047
Flashman1
Flashman1's Avatar
Oddometer: 5,313
Not at all - I value your information. - It is just I have not had all the problems you have had - and yes I know how to tell if wheel bearings are bad - clutch cables and air cleaner cover nuts speak for themselves - I pulled my clutch apart and tried to feel the basket move but it felt good. The top end stuff is hard to see without a tear down - I will do it this summer and ask your advice on what I find.
And yes I ride like the old man I am - even though 2/3s of my 20,000 miles have been off road in southern Az and southern Colorado both of which have some pretty rough riding.
Have only hit the rev limiter a couple of times.
Old 03-09-2012, 04:09 PM   #23048
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,673
Did you purchase your TE610 new with zero miles or was it used when you acquired it?
11 Husqvarna TE630
11 Husqvarna SM630
08 Husqvarna TE510- sold
10 Yamaha FJR 1300
Fast1 is online now   Reply With Quote
Old 03-10-2012, 12:06 AM   #23049
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,863
New, zero miles...man, I loved that bike.
Old 03-10-2012, 10:16 AM   #23050
1 lunger
1 lunger's Avatar
Oddometer: 806
Anyone know if the CCT on a 2000 tc 610 is a manual adjuster??
I am here: http://tapatalk.com/map.php?pem4v1
Life is good!
1 lunger is offline   Reply With Quote
Old 03-10-2012, 07:55 PM   #23051
larryboy
Paint it black.
larryboy's Avatar
Oddometer: 12,863
It's an auto.
Old 03-11-2012, 04:00 AM   #23052
1 lunger
1 lunger's Avatar
Oddometer: 806
It's an auto.
Thanks, I'm on the hunt of a manual one to fit on a 09
I am here: http://tapatalk.com/map.php?fllq10
Life is good!
Old 03-11-2012, 04:27 AM   #23053
955616846
Oddometer: 1,690
http://www.bigborethumpers.com/tensioners.html
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 03-11-2012, 07:35 AM   #23054
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 889
just put in the ape cct
So put in gear did 6th on a stand rolled backwards. Spun in finger tight till it stopped then set jamb nut. Cool? Ape says find tdc then back off a 1/4 turn after turning in... Thoughts
ebrew is offline   Reply With Quote
Old 03-11-2012, 09:27 AM   #23055
955616846
Oddometer: 1,690
The APE method sounds alright for initial set up. I set these things by ear with the engine running...
Cheers, Numbers
Times are GMT -7.   It's 11:48 AM.
