12-03-2007, 09:21 AM
#2341 | |
Oddometer: 1,702
Dan |
12-03-2007, 09:44 AM
#2342 | |
Oddometer: 1,702
My first thought was to make a flippable piece but didn't think about pulling the axle. If we removed the pull arm(if it is used just to pull axle and not for safety) that design would work without removing the axle. The other idea I had was to make a spacer that would in effect be a cap for the adjuster. It would be machined to fit over the hex head of the adjuster if there is enough clearance. |
12-03-2007, 09:54 AM
#2343 | |
Oddometer: 1,702
![]() Scotts website shows this to work on the Husky. Might be worth a call for you guys. Dan |
12-03-2007, 10:41 AM
#2344 |
Oddometer: 1,702
Here is the preliminary sketch showing sprocket and chain allowances. Using CAD I think I can get the numbers we need but want to check this against real world measurements. I will have some numbers tonight...
![]() ![]() Corrected sketch Dan buffallodan screwed with this post 12-03-2007 at 10:38 PM Reason: Corrected sketch |
12-03-2007, 12:14 PM
#2345 | |
Card carrying greeny
Oddometer: 1,015
Dan, do you realize you just proved a longer arm will work fine? Somebody at Scotts is talking
.Quote:
See my pics Dave: The 610 really makes me want to ride like a punk everywhere I go. bikefrk: You now understand supermoto. Your training is complete. |
12-03-2007, 12:53 PM
#2346 | |
Oddometer: 1,015
Edit: Oops, I meant adjust for your largest CS & shim as you go smaller.
See my pics Dave: The 610 really makes me want to ride like a punk everywhere I go. bikefrk: You now understand supermoto. Your training is complete. Hoder screwed with this post 12-03-2007 at 01:08 PM |
12-03-2007, 01:11 PM
#2347 | |
Guns are for pussies
Oddometer: 13,783
Just say'IN |
12-03-2007, 03:23 PM
#2348 | |
Oddometer: 1,702
![]() Dan p.s. If you guys want to try using a longer Arm I think Colin at Stenhouse Racing would be willing to mill you a custom Arm. Scotts is not going to have one that long. It should be pretty straight forward for Colin to make a tank bolt that would work as a Tower Pin as well. I personally would go the route of fabricating something like in the picture above, but come up with a solution to make it more stable to handle the torque that will be placed on it. For instance I just thought of an idea..."drawing would be so much easier "I can't describe it, I will have to draw it, but it could very well be a solution we have looking for to make the piece above better...when I get in from Poker tonight I will post the sketch... buffallodan screwed with this post 12-03-2007 at 03:34 PM |
12-03-2007, 07:17 PM
#2349 |
i like motorcycles
Oddometer: 3,288
more steering damper talk....grooooaaaaan....
.. just kidding! Hey Dan, you might try replacing your fork oil with 5, or even 2.5 wt., starting on the low level side then bumping it up 10 to 20 ccs (per leg) at a time until you get the bottoming resistance you want. Don't forget, with thinner oil you will need to turn your rebound adjuster in somewhat, and maybe the comp too depending on what you are after. Tuning with oil is nice because it allows you to alter damping characteristics that are otherwise not accessable without messing with the shim stacks/valving. |
12-03-2007, 09:06 PM
#2350 |
Oddometer: 1,702
![]() Man each time I think about this I see a new angle. Why does it matter where the Arm is terminated? Does the leverage actually change depending on how long the Dampers Arm is? I am not so sure now...On the one hand I understand that a longer lever applies more force but I may be mistaken in this instance as to where the force is actually applied. I may be wrong in thinking the force is applied from the Arm. If the arm extended to the Tank Bolt, would it make a difference?...Anyone a Structural or Mechanical Engineer? |
12-03-2007, 09:24 PM
#2351 |
Oddometer: 352
Was just about to write how right I thought HODER was about the xtended arm damper. Because a long arm that pivots on a fixed piont is in the same arm no matter what place on that arm you grab. But then I thought well why does a breaker bar turn a lugnut easier than a ratchet. . . . . . . and now my brain hurts..
But his chain adjstr. shims are brilliant but if the damper lever does'nt pivot exactly above the center of the steering tube the longer lever will definetly not work. Because now you have two pivot points on two independant objects instead of one pivot and one fixed point. Aey dubya screwed with this post 12-03-2007 at 09:39 PM |
12-03-2007, 10:04 PM
#2352 | |
Oddometer: 1,702
Dan buffallodan screwed with this post 12-03-2007 at 10:51 PM |
12-03-2007, 10:17 PM
#2353 |
Oddometer: 352
Crankshaft
Saw some BMW pics in your gallery. Did you know that BMW now owns Husqvarna as of july 07'. |
12-03-2007, 10:37 PM
#2354 |
Oddometer: 1,702
12-04-2007, 06:35 AM
#2355 | |
n00b-ish
Oddometer: 485
I think it comes down to which part (system) is passive and which one is active. I'm guessing there is a pin at the end of the bar that mates to the damping assembly. This pin is passive and the arm is just a means of mounting the pin rigid. The most important criteria for this pin is to stay as rigid and static as possible to resist the influence of the active damping assembly mounted to the handlebars. The longer the [pin] bar, the greater the leverage and so the greater the influence the damping assembly has on it. Or restated, the longer the bar the more it flexes and the more the (passive) pin moves relative to the (active) damping assembly. This flex reduces the performance by a percentage. Sorry if I wasted your time with this, slow start today at work.
-Ted West '06 Husqvarna TE250 '82 Husqvarna 430WR '81 Husqvarna 250XC |
