Old 06-19-2012, 09:25 PM   #23716
Mgizler
Oddometer: 52
No problem, Glad I could help.
Originally Posted by rocky mtn nut View Post
Mark you saved me, mine broke on the way home from work I followed your lead . its on its way.thank you
Mgizler is offline   Reply With Quote
Old 06-19-2012, 10:59 PM   #23717
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,643
I noticed a few questions about engine temp in the last couple of pages. It hasn't been talked about in quite some time, but the stock hose clamps are pure garbage and eventually fail, some slowly where the bike starts running hotter without coolant loss, it just vents pressure/air until a clamp really blows apart.
larryboy is online now   Reply With Quote
Old 06-20-2012, 12:32 AM   #23718
Baroquenride
Oddometer: 820
Originally Posted by bobnoxious67 View Post
Do you have a picture of the Guts seat on your bike?
Sorry, no. I only have pics of the seat itself.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is offline   Reply With Quote
Old 06-20-2012, 09:13 AM   #23719
Rattletrap
When in doubt-Gas it
Rattletrap's Avatar
Oddometer: 302
[QUOTE=Mgizler;18936925]How did you reroute the stock cable. I was looking at it this morning and trying to figure out a better way to route it than it currently is. It just blows my mind that the cam chain was 8 clicks and the clutch cable was seconds away from breaking with less than 2000 miles on the clock.
Anyway, I would appreciate it If you could share a photo or diagram of how you had your cable run.
Thanks in advance,
Mark
Sorry for the slow post, been working way too much, but yes Larryboy got it right. I also kept it oiled or sprayed with the same teflon stuff I use for my chain. If you have a burr in the adjustment barrel, the Barnett clutch cable end won't slide in, its a tight fit.
Rattletrap is offline   Reply With Quote
Old 06-20-2012, 10:23 AM   #23720
rocky mtn nut
rocky mtn nut's Avatar
Oddometer: 165
Originally Posted by Flashman1 View Post
I hope they improved the design from 3 years ago - mine broke at the lever in 1000 miles - they "fixed" it for free - but it broke again in the same spot a 1000 miles later - went back to the OEM cable.
Do you think its our clutch lever that's the problem??
rocky mtn nut is offline   Reply With Quote
Old 06-20-2012, 12:56 PM   #23721
tlking6
tlking6's Avatar
Oddometer: 284
I had trouble early on at the lever as well. I switched to the barnett cable. The end of the cable is a little smaller than the opening in the lever. I give it a couple wraps of teflon tape to take up the slop but still allow it to pivot. I also route it so that there is always a slight pressure up on it, that way it doesnt rub. I dont know if that makes sense or not but if you study the travel on it you can see what is going on. Since I have done this I havent noticed any wear at all on the cable, guessing about 4k miles, and I take it apart and check it out alot. I do, however, carry a spare on longer rides.
08 Husky 610 TE
01 KTM 453 MXC
tlking6 is offline   Reply With Quote
Old 06-20-2012, 01:08 PM   #23722
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
I broke mine about 700 miles from home (about 7,000 miles on it). I shifted without a clutch and pushed it from stoplights and popped into first gear for awhile. Then it hit me that I had needlenose vise grips in the tool bag. I clamped that sucker onto the frayed end through the hole in the lever and that got me home easily. I don't carry a spare clutch cable, but I damm-straight carry those vice grips!
drrags is offline   Reply With Quote
Old 06-20-2012, 01:13 PM   #23723
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,643
Made it thru Utah, Nevada, Oregon and back to Sacramento on dirt:
Old 06-20-2012, 06:57 PM   #23724
gunnr
optimsm
gunnr's Avatar
Oddometer: 290
Can I get some input on whether I should replace the auto CCT with a manual one? The bike is an 08 with less than 2K miles? I haven't pulled the auto one out yet to count the "clicks". I have read the auto could overadjust causing too much pressure on the chain? Makes sense. How does one adjust the manual one? Just wondering if it might help the chain to last longer.
thanx
gunnr is offline   Reply With Quote
Old 06-20-2012, 10:20 PM   #23725
Taranis
Oddometer: 364
Here's a Guts tall seat. Cover and foam are pretty inexpensive, maybe a couple hours of work if you really take your time and are anal about getting it just right.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 06-21-2012, 02:40 AM   #23726
JonXX
Infraction Collector
JonXX's Avatar
Oddometer: 364
Originally Posted by SilverBullet View Post
Does the two hours also include mowing the grass? haha
_
My uncle mowed the grass while I was installing the racks.
Originally Posted by KIK ROX View Post
What size aux. fuel tank is that? Rotopax or Kolpin?
It's a 1.5 gallon Rotopax that came out of a Kolpin box.
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member.
"They" said we couldn't run the OBDR on supermotos...
JonXX is offline   Reply With Quote
Old 06-21-2012, 07:58 AM   #23727
toddler
Unpronouncible
toddler's Avatar
Location: Pinewood Springs, CO(between Lyons and Estes Park)
Oddometer: 2,735
That looks very nice. Thanks for sharing.
toddler is online now   Reply With Quote
Old 06-21-2012, 08:03 AM   #23728
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,633
Thanks man.
More comfort than stock? Or was it just the height that made it better for you?
PM me if you decide to sell it
Field & Forest Recreation Area
00 KTM 640 ADV
01 Girlie
09 TE450
bobnoxious67 is offline   Reply With Quote
Old 06-21-2012, 08:26 AM   #23729
1 lunger
1 lunger's Avatar
Oddometer: 1,253
thanx
That seems to be the consensus. I just got the APE manual one myself after installing a new CC. You have to pay attention to the manuals and check once and awhile. Pull your auto CCT and if you're still at a safe amount of clicks I would put it on. Make sure you remove the ACCT the proper way or you will be at 14 clicks.
Life is good!
1 lunger is offline   Reply With Quote
Old 06-21-2012, 05:50 PM   #23730
sapienwaste
gahhhhhhhhhhh.
Oddometer: 28
I'll second this. Pure. Unadulterated. Garbage. Replace them or prepare to have a bad time.
sapienwaste is offline   Reply With Quote
Times are GMT -7.   It's 10:15 AM.
