Old 07-30-2012, 04:49 PM   #24001
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Rear shock removal on a 2008
I followed the directions specified in the manual for removing the rear shock. Heck, I even removed one of the linkage bolts. The shock is now free inside the rear subframe/swingarm... however, I'm beginning to suspect that the manual has lied to me and that more work will be required... so... Is there a way to take out the rear shock w/o removing either the rear subframe or the swingarm?
huzar is offline   Reply With Quote
Old 07-30-2012, 05:04 PM   #24002
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Originally Posted by 1 lunger View Post
CH has a member making them for the 610 and 630, you can miss the thread, it's always up on 1st page.
Life is good!
I'm guessing this is the one?
http://www.cafehusky.com/threads/cus...s-ready.23282/
Seems like $145, but I PMd the guy to make sure.
Old 07-30-2012, 05:08 PM   #24003
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,824
It's kinda like a puzzle - IIRC you twist the shock as you drop it through the swingarm hole. Kinda like unscrewing it (gawd, I hope I'm remembering the right bike) No need to remove any linkage.
drrags is offline   Reply With Quote
Old 07-30-2012, 05:17 PM   #24004
1 lunger
1 lunger's Avatar
Oddometer: 1,341
Originally Posted by drrags View Post
I'm missing it. 1st page where? Vendors?
610/630 thread
Look for the Ken Webb thread.
Life is good!
1 lunger screwed with this post 07-30-2012 at 05:25 PM
1 lunger is online now   Reply With Quote
Old 07-30-2012, 05:19 PM   #24005
1 lunger
1 lunger's Avatar
Oddometer: 1,341
Yes, pay a suspension tech the extra $25 to do it;)
Life is good!
Old 07-30-2012, 05:32 PM   #24006
1 lunger
1 lunger's Avatar
Oddometer: 1,341
That's the one.
Life is good!
Old 07-30-2012, 05:37 PM   #24007
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,284
Remov the front bolt from the lower linkage. Swing the link down and rearward. Lower the shock into the link area. Lean to the left side of the bike and pull out of the left side. Mine is an 2000 model so the shock clears the exhaust. You may need to remove your exhaust.
Regards
Fritzcoinc
fritzcoinc is offline   Reply With Quote
Old 07-30-2012, 06:29 PM   #24008
K7MDL
TE450, Jeep
Oddometer: 1,567
Pulling the subframe bolts out is easy, then just pull back on the subframe as required just enough to get it out. Replace stock subframe bolts with high rade bolts. Might have to clip a few tie wraps. I left my muffler in place. I did pull the linkage bolts at the end though, becuase they should be cleaned and greased. I use waterproof bearing grease. Make sure to reinstall the shock so the lower adjustment screw faces the left side for easy access.
If you are also pulling your front forks and choose to get fork bleeders drilled and recessed in the caps (leaving the vent holes there with screws, make sure to place the new holes where your handle bar cables won't drape across them and vent on the trail.
K7MDL is offline   Reply With Quote
Old 07-30-2012, 06:30 PM   #24009
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Life is good!
Not helpful
Old 07-30-2012, 06:33 PM   #24010
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Thanks Mike, I'll give pulling the lower subframe bolts out. I was hoping to avoid this, as I think I'll have to drain and remove the big Safari tank to get at them, but the amount of effort I have put into removing the shock without removing the bolts far exceeds the effort it would just have taken to pivot the rear subframe out of the way...
Probably a good idea to replace the bolts with something made of steel rather than cheese
Old 07-30-2012, 06:40 PM   #24011
1 lunger
1 lunger's Avatar
Oddometer: 1,341
Not helpful
I was only trying to save you the frustration of doing it yourself ;)
I'll make it up to you by PM you Ken Webb's email. He's the custom side stand guy.
Life is good!
Old 07-30-2012, 06:44 PM   #24012
1 lunger
1 lunger's Avatar
Oddometer: 1,341
PM sent
Life is good!
Old 07-30-2012, 08:13 PM   #24013
MasterChief
MasterChief's Avatar
Oddometer: 1,178
What's the part # on that one? The one that Jeff put on for me is 8000H0192, which appears to be one for the 250 and 310. I looked at where the magnet goes past the pickup, and there is practically no overlap, so that's the most likely culprit for why I have no speedo. And yeah, it looks like there's no room to drill elsewhere to move the magnet...
Same part number, "Braking" brand.
MasterChief
13 TE310 08 TE610, 96 XT 225, 86 SRX 600
MasterChief is offline   Reply With Quote
Old 07-30-2012, 08:18 PM   #24014
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
06 610 front rotor
Can anyone give me a part number for a nice floating front rotor " braking or galfer " I can't stand the singing stock front one.
ebrew is online now   Reply With Quote
Old 07-30-2012, 09:52 PM   #24015
huzar
Pastor of Muppets
huzar's Avatar
Oddometer: 2,273
Hmmm... yeah, I have the same brand. Weird. Maybe if I take the pickup wire off the pickup and screw the sensor in a little more, so it is closer to the rotor?
Times are GMT -7.   It's 12:19 PM.
