10-09-2012, 11:05 AM
#24526 |
Oddometer: 220
HI All,
New 610 owner here. It's a 2008 with 1,300 miles. I bought it used for $4,500. I've only had it for a day, but I can tell that it is going to be a strong running bike. Starts easily. Finding neutral is a chore. Seat is ok but could be better. I've already ordered a spare clutch cable. Question 1: what is the brightest aftermarket DOT approved headlight I can put on this thing without stressing the electronics too bad? I was caught out in the dark and in the rain and it was quite an adventure getting home with the Husky's pitiful headlight. I would love to put on the Baja Designs La Paz lights but I don't think they are DOT approved. Question 2: I feel tipsy when I stand up on this thing, not a stable as on other bikes like my Super Tenere. I've thought about putting on handle bar risers but I've heard that the clutch cables don't have enough slack to allow that. I've also thought about putting on lower pegs. I think what really needs to happen is the pegs need to move rearward to spread me out better, but then I would have to mess with the brake and shifter. Any suggestions? Thanks
'08 Husky 610 Previously owned: '12 Yamaha Super Tenere 1200, '01 Kawasaki KLR 650 |
10-09-2012, 04:55 PM
#24527 | |
Oddometer: 810
1 lunger screwed with this post 10-09-2012 at 05:01 PM |
10-09-2012, 06:40 PM
#24528 |
Oddometer: 220
Thanks Lunger. Thankfully I ordered the Motion pro. I didn't know the Rox could move forward like that. Sweet.
By the way, I've found some other threads on the lighting thing. Still trying to decide what to do on that issue.
10-09-2012, 07:05 PM
#24529 | |
Oddometer: 810
![]() Edit: my bad, I thought you said lightening. The trail tech X 2 is a good light. |
10-10-2012, 01:12 AM
#24530 | |
Oddometer: 7,755
My Poor bike!
My Poor abused bike. Today I had a little boo-boo where I was accelerating kinda hard, checked my 6 and when I looked up there was a semi braking hard for a barely yellow light.
I got on it pretty hard, but the rear started sliding and it was clear I was gonna thump him. I started to veer left but there was a car coming, so I had to lay'r down Lol. The rear did a near perfect slid putting the bike horizontal under the bumper and the back tire impacting the semi's tire. All-in-all pretty amazing result. I got up and got the hell out of there! OK, so later, I discovered that I'd torn the muffler mounts out of the subframe. and I got a dramatic increase in my ongoing oil leak where the shifter punched the stator cover (but to be fair there's also a crack that I think may be the cause of my previous leak) And I guess I must have been on the brake pretty hard, cuz about 1/2 hour later the footpeg popped off. OK, so sorry that was so long-winded... Who makes the bling clip-on rear brake toe thingy? Anybody got a lead on a stator cover less than $200? I slapped some quicksteel on and rode it to Portland an back. Oh and so naturally the cam chain that I've put off fixing for a year is now rubbing the reed valve. I'm gonna give it some love soon, just in time for winter. I promise.
Albert Einstein Baja trip to the tip 6:10 to Yuma trials and tribulations in the Mojave Baja Blitz Yard sale View Current Location via Spot Tracker |
10-10-2012, 03:30 AM
#24531 | |
Oddometer: 110
Kawasaki Versys**Honda CL360 Project**Honda CB 550**Husky TE610 MotoPreserve -- a blog about wrenching on bikes in Brooklyn... |
10-10-2012, 08:03 AM
#24532 | ||
Oddometer: 7,755
Yeah, hurt my pride pretty bad, which is surprising cuz really after all this time you wouldn't expect there to be much left.
10-10-2012, 09:25 AM
#24533 |
Oddometer: 147
Brake pedal
Aaron, you can get a brake pedal from Bill's for $25. Since you're up north, maybe try Tasky's. I bent mine beyond repair about 6 months ago and Bill had one in the glass case. I forgot who makes it though, but you could call him and he could tell you. It comes in red anodizing and it's not made for the TE-610 but with some finagling it'll work. I'll try and send you a pic in a few hours.
2000 Honda VFR800, 2008 Husqvarna TE-610 |
10-10-2012, 11:01 AM
#24534 | |
Oddometer: 87
For the Stator cover try Fran Bottone @ Jo-Bet cycles. I get all my parts through him and I thought he quoted me that cover for around what your are looking (this was last year though). Edit: I called Jo-Bet cycles and they are closed. Fran moved over to 6V motorsports. The number on the machine was 814-368-5500. Not sure if he will be able to help there or not, but couldn't hurt to check.
Current Bikes: 2009 Husqvarna SM610 (Fully swappable to TE) 2010 F800GS nathan8315 screwed with this post 10-10-2012 at 11:07 AM |
10-10-2012, 06:09 PM
#24535 |
When in doubt-Gas it
Oddometer: 302
Glad you're ok Aaron. Good thing he wasn't backing up!
10-12-2012, 07:12 AM
#24536 |
Oddometer: 810
Anyone have the torque spec for the rear sprocket on the 610?
10-12-2012, 07:21 AM
#24537 |
Deputy Cultural Attaché
Dado fiss. corona/ Rear wheel sprocket fastening nut/ Ecrou de fixation couronne arrière/ Befestigungsmutter Hinterkranz/ Tuerca
fijación corona trasera M8x1,25 (+LOCTITE 243) 34,3 Nm 3,5 Kgm 25.3 ft/lb
Successfully surviving motorcycling since 1976. |
10-12-2012, 03:04 PM
#24538 | |
Justa Venturer
Oddometer: 1,245
It's probably bad luck to say this, but on more than one occaision I have been surprised when somehow I've been able to lay-er down and avoid what I was sure would be really bad news. You going to make it down for The Gathering this year?
___________________________________________ So much riding-so little time |
10-12-2012, 06:33 PM
#24539 |
Oddometer: 810
10-12-2012, 06:53 PM
#24540 | ||
Oddometer: 7,755
