Old 12-27-2012, 05:12 AM   #24631
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
StolenFant Yesterday 08:28 PM
Clutches from 2000 to 2007 have changed.
Sent from my DROID RAZR using Tapatalk 2
Yes they sure have. The 07 clutch has 07 springs, 07 plates, 07 cable, and an 07 lever. The 2000 model has the same items but they were made in 2000.
Try a good cleanning, lubracation, and adjustment before condeming.
Originally Posted by JonXX View Post
Yeah, and? My 07 clutch is buttery smooth and has just the right amount of resistance. I've seen a lot of people wanting to go to a hydro clutch, never understood why, those things are horrible, spongy and no feel to them.
But maybe that's just because I've only ever had one bike with a hydro clutch (which I changed to a cable LOL)
Isn't it funny how some folk just want to change for the sake of change?
They always rip on and want to change the easy stuff like side stands and seats. Instead of servicing the steerhead bearings they add a steering dampner.
A hyd. clutch is great! Hey, less moving parts. But of course the master and slave cylinders take alot of wear as a result of use. The clutch is used much mpore than brakes. The seals and cylinder bores wear. My K1200 has a hyd. clutch and at 64K miles it is still working smoothly.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-27-2012, 07:00 AM   #24632
Taranis
Oddometer: 375
Getting the cable aligned properly at both ends so it doesn't rub against the end of the housing making a corner when it's under tension, and cleaning and lubricating the lever and cable makes a huge difference. Mine is buttery smooth, and I'm not worried about wearing it out. The effort is on par with, or lower than, the hydro clutches on new bikes at the dealer.
DIRT BIKES ARE FUN AND INTERESTING
Taranis screwed with this post 06-09-2013 at 03:20 PM
Taranis is offline   Reply With Quote
Old 12-27-2012, 09:09 AM   #24633
Flashman1
Flashman1's Avatar
Oddometer: 5,361
Originally Posted by Taranis View Post
Getting the cable aligned properly at both ends so it doesn't rub against the end of the housing making a corner when it's under tension, and cleaning and lubricating the lever and cable makes a huge difference. Mine is buttery smooth, and I'm not worried about wearing it out. The effort is on par with, or lower than, the KTM hydro clutches on new bikes at the dealer.
I lube mine all the time and the pull is fine - how do you align the cable and keep it so?
Flashman1 is offline   Reply With Quote
Old 12-27-2012, 01:43 PM   #24634
1 lunger
1 lunger's Avatar
Oddometer: 1,286
Originally Posted by fritzcoinc View Post
Harley had these back in the 50's. They reduce pull effort but increase pull length. Not to mention additional weight.
If you think the clutch pull is excessive on your Husky, something is wrong.
I say that because the clutch on my 2000 model has a super easy clutch pull, best ever!
Y'all must have a rotten cable, lever in need of cleaning and lube or bad shaft bearing.
That thing must work like a block and tackle. I too have no trouble with clutch pull on the 610. My OEM cable broke at 2k, but the motion pro +2" I replaced it with has been great for 5k+ and I also haven't had any trouble finding -N- ever! I think it's important the cables routed proper (a zip tie) near the lever to keep the cable from bowing helps.
Edit: with the pad and risers I don't have it zip tied anymore. It lines up very nice by itself now. I think like most of us, I too run the cable up through the top bar clamp. I did spend some time fiddling with the bottom cable mount when I installed it, marketing sure it wasn't rubbing on the cable housing. FWIW, don't spend the money on one of those fancy cable lube things. They make as much of a mess as spraying the lube in with a straw. this stuff works good! I use it for almost everything.
1 lunger screwed with this post 12-27-2012 at 02:01 PM
1 lunger is offline   Reply With Quote
Old 12-27-2012, 03:27 PM   #24635
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
This is how the cable should mbe routed.
Regards
Fritzcoinc
Old 12-27-2012, 05:20 PM   #24636
shootis
shootis's Avatar
Oddometer: 114
Does the cable run inside the radiator next to the frame or to the outside?
I bought my bike used and its on the outside of the radiator,,,
shootis is online now   Reply With Quote
Old 12-27-2012, 06:48 PM   #24637
1 lunger
1 lunger's Avatar
Oddometer: 1,286
It should run inside by the frame and up over the rad if I remember correctly. I zip tie it to the rad fan housing to keep it off the head and then up, but DON'T pinch it between the the rad and frame. I got mine back from the shop once like that and had to take everything off down to the right rad to reroute it.
Old 12-27-2012, 06:56 PM   #24638
1 lunger
1 lunger's Avatar
Oddometer: 1,286
That's a clean bike!! I'm mean that in a good sense. It's cold here so I'm not washing mine and it looks like the "red headed step kid in the corner".
Old 12-28-2012, 01:42 PM   #24639
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,076
Thank You! But it's not always clean!
You can also see in this photo that the cable route is behind the right radiator. But not between rad. and frame.
The bike cleans up well:
Regards
Fritzcoinc
Old 12-29-2012, 10:11 AM   #24640
Taranis
Oddometer: 375
Handlebar lever end
Lower end
Old 01-01-2013, 11:10 AM   #24641
tlking6
tlking6's Avatar
Oddometer: 287
Got in a little 4 day trip to Baja with my son after Christmas. The 610 is a worthy dual sport mount for Baja that I wouldnt trade for anything.
08 Husky 610 TE
01 KTM 453 MXC
tlking6 is offline   Reply With Quote
Old 01-01-2013, 02:33 PM   #24642
Flashman1
Flashman1's Avatar
Oddometer: 5,361
Lower end is easy - but the upper needs a machine shop??
Old 01-01-2013, 03:27 PM   #24643
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 760
New Owner issues
Hello guys. I am joining the group. I just traded one of my street bikes for a 2006 TE610 with and extra set of sumo wheels, dirtbag setup, spare parts and almost an entire spare engine. Of course I have inherited the subframe issues.
The exhaust mount seems to have been broken and repaired with a homemade metal bracket. The battery mount seems to have had metal added with screws to strengthen it. I will have to look at it closer later. The brake light did not work when I got it. I found a lot of dirt in the space behind the light. I cleaned the connections and put a thick layer of dielectric grease on them and got it working again. There is a chance I might change the whole light out in the future. The left mirror mount is broken. It should be an easy fix. One of the mounting points of the front left header cover is broken. I guess that I will have to have that welded. Is the exhaust pipe stainless?
The main problem that I have found is that the subframe is broken on the left side on the extension that sticks out past the seat in the rear and holds the rear fender and rack. I guess that my only option is to take it apart and have it welded. Is that the best course of action? What should I have to tell the welder for the aluminum for the subframe?
Thank you for any directions and ideas.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 01-02-2013, 07:17 AM   #24644
Taranis
Oddometer: 375
It's a super-easy part to knock out if someone has access to a lathe. I did, so I did.
Old 01-02-2013, 07:41 AM   #24645
1 lunger
1 lunger's Avatar
Oddometer: 1,286
I'm selling one!
Times are GMT -7.   It's 04:52 AM.
