Old 02-13-2013, 06:05 AM   #24766
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,678
Originally Posted by His Pistolship View Post
Hi All,
My speedo quit working today. Everything else works fine; rpm, gas light, blinkers...
Is there a quick fix to this?
If the 3 minute disconnect does not fix it, it's likely a break in the wire that leads from your rotor sensor to the display unit.
Old 02-13-2013, 08:17 AM   #24767
tlking6
tlking6's Avatar
Oddometer: 287
Yup, happened to me too. Right where the wire dives behind the shroud.
08 Husky 610 TE
01 KTM 453 MXC
tlking6 is offline   Reply With Quote
Old 02-14-2013, 01:59 PM   #24768
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 633
Which Excel rim?
Bought a spare rear hub on fleabay, does anyone remember what type of Takasago rim it takes? I don't seen any id info on my rims. RK website does not list a model number for huskys.
What a lovely bunch of coconuts.
Better to be a fast mule than a slow race horse.
hahmule is offline   Reply With Quote
Old 02-14-2013, 02:33 PM   #24769
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
Check your Owners Manual.
Mine has a 1.60" x 21".
I have a brand new, never laced, Excel rim this size I would like to sell.
PM if any interest.
Count the number of spokes to be sure the one I have is correct.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 02-14-2013, 03:54 PM   #24770
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 633
I thought I read somewhere that the Huskys had a weird angle on the spokes, and that there was a special rim to align with the hub and that a simple spoke count would not reveal which rim to use.
Don't have a front hub, but my stock rim is pretty beat up....
Old 02-14-2013, 03:58 PM   #24771
motopreserve
Oddometer: 128
Originally Posted by Flashman1 View Post
I will try it.
I was one of the folks who turned a small piece on a lathe for the fix - but I think any shim (or coke can - Pepsi of that's your preference!) would wok just fine. The difference was definitely/immediately noticeable.
Also, the replacement clutch cable (by barnett???) that Hall's will send has a ferrule that seems to be the correct size - I measured it with a caliper and it matched the size of the piece I made.
Kawasaki Versys**CL360 Project**Honda CB 550**Husky TE610**'72 XL250 for the lady
MotoPreserve -- a blog about wrenching on bikes in Barre, VT...
motopreserve is offline   Reply With Quote
Old 02-15-2013, 07:42 AM   #24772
Taranis
Oddometer: 375
Email the tech support guys on the RK site. Very helpful to me.
Apparently, the 2000-2005 models may take a different rim than the '06+ models.
Buchanan also has all that stuff dialed.
DIRT BIKES ARE FUN AND INTERESTING
Taranis is offline   Reply With Quote
Old 02-15-2013, 08:34 AM   #24773
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
Sorry, I mis read your post.
I also have a complete rear wheel for a 91 model Husky. Check out Halls parts list to learn if the rim or whole wheel would work on your bike. This wheel is a solid hub, no cush drive but is the same width as my 2000 610's rear wheel that has cush drive.
I think the wierd spoke angle refers to the old drum brake wheels because the drum is large and the spokes on the brake side are short.
Soory to be confussing.
Regards
Fritzcoinc
Old 02-15-2013, 01:24 PM   #24774
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 633
Thanks..
For your replies, I will email RK first, and failing that, I will prolly send it to Buchanans or Woody's.
Old 02-15-2013, 01:36 PM   #24775
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
This guy is close to you:
Dave Moore Wheel Service
(760) 240-3543
9383 Buena Vista Street
Apple Vally, Calf. 92308
Dave has done several wheels, solid and spoke, for me and always done a stellar job.
Regards
Fritzcoinc
Old 02-17-2013, 03:43 AM   #24776
Not2Sure
Not2Sure's Avatar
Oddometer: 39
In need of new clutch perch/lever and cable
Hey guy's i'm looking for a new clutch perch/lever and cable for my 08 610. Is there any aftermarket setup's available that y'all might recomend or am i better off going for genuine items?. Hav'nt had much luck finding any aftermarket perch/levers as yet but found some cables. Thought i better get some feedback on what to use before i go ordering genuine parts. Please help, my baby is in hybernation with a broken cable and i'm having withdrawalls.
Not2Sure is offline   Reply With Quote
Old 02-17-2013, 09:06 AM   #24777
StolenFant
Oddometer: 244
I used Motion Pro b/c slightly longer and braid slides relatively well through the tight bends required. Guy who did my clutch spring washers said the Barnett was his favorite. THE laziest way to oil a new cable is to cut a small hole in corner of a Ziploc. Use rubber bands to seal it well. Find the heaviest gear oil you can. Fill the bag and hang it in the sun. Heating the oil can speed the process, but hours in the sun work. You shouldn't need to pull the inner cable up; the oil will find it's way. Once oil is dripping the bottom, you're done.
Sent from my DROID RAZR using Tapatalk 2
StolenFant is offline   Reply With Quote
Old 02-17-2013, 09:13 AM   #24778
Taranis
Oddometer: 375
If I was using this method, I would not use gear oil. It has additives that are good for gears, but it's super stinky. The viscosity is actually not that different than motor oil, which is what I'd use instead. Much less stinky. And with this method, it's going to continue to leak oil out the bottom of the cable for some time, so you'd be better off not having that be the stinky stuff.
Old 02-17-2013, 04:35 PM   #24779
Drewha
Thunderbirds Are Go
Drewha's Avatar
Oddometer: 604
What are you guys using for engine oil? The only 10W60 I can find locally is Motorex at $20 a liter. I talked to Spectro rep at IMS in NYC and they have it, but local dealers dont carry it. THX
08 Husqvarna TE 610
04 Ducati ST3
Drewha is offline   Reply With Quote
Old 02-17-2013, 06:28 PM   #24780
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,113
Shell 5W-40 Syn Rotella. $20 a gallon at Wall World
Regards
Fritzcoinc
Times are GMT -7.   It's 05:53 PM.
