02-14-2013, 03:54 PM
#24886 |
Balding Gloriously
Oddometer: 571
I thought I read somewhere that the Huskys had a weird angle on the spokes, and that there was a special rim to align with the hub and that a simple spoke count would not reveal which rim to use.
Don't have a front hub, but my stock rim is pretty beat up....
What a lovely bunch of coconuts. Better to be a fast mule than a slow race horse. |
02-14-2013, 03:58 PM
#24887 |
Oddometer: 113
I was one of the folks who turned a small piece on a lathe for the fix - but I think any shim (or coke can - Pepsi of that's your preference!) would wok just fine. The difference was definitely/immediately noticeable.
Also, the replacement clutch cable (by barnett???) that Hall's will send has a ferrule that seems to be the correct size - I measured it with a caliper and it matched the size of the piece I made.
Kawasaki Versys**Honda CL360 Project**Honda CB 550**Husky TE610 MotoPreserve -- a blog about wrenching on bikes in Brooklyn... |
02-15-2013, 07:42 AM
#24888 | |
Oddometer: 298
Apparently, the 2000-2005 models may take a different rim than the '06+ models. Buchanan also has all that stuff dialed.
DIRT BIKES ARE FUN AND INTERESTING |
02-15-2013, 08:34 AM
#24889 | |
Enjoying my last V8
Oddometer: 5,415
I also have a complete rear wheel for a 91 model Husky. Check out Halls parts list to learn if the rim or whole wheel would work on your bike. This wheel is a solid hub, no cush drive but is the same width as my 2000 610's rear wheel that has cush drive. I think the wierd spoke angle refers to the old drum brake wheels because the drum is large and the spokes on the brake side are short. Soory to be confussing.
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, Google: TX7 |
02-15-2013, 01:24 PM
#24890 |
Balding Gloriously
Oddometer: 571
Thanks..
For your replies, I will email RK first, and failing that, I will prolly send it to Buchanans or Woody's.
02-15-2013, 01:36 PM
#24891 | |
Enjoying my last V8
Oddometer: 5,415
This guy is close to you: Dave Moore Wheel Service (760) 240-3543 9383 Buena Vista Street Apple Vally, Calf. 92308 Dave has done several wheels, solid and spoke, for me and always done a stellar job.
02-17-2013, 03:43 AM
#24892 |
Oddometer: 24
In need of new clutch perch/lever and cable
Hey guy's i'm looking for a new clutch perch/lever and cable for my 08 610. Is there any aftermarket setup's available that y'all might recomend or am i better off going for genuine items?. Hav'nt had much luck finding any aftermarket perch/levers as yet but found some cables. Thought i better get some feedback on what to use before i go ordering genuine parts. Please help, my baby is in hybernation with a broken cable and i'm having withdrawalls.
02-17-2013, 09:06 AM
#24893 |
Oddometer: 224
I used Motion Pro b/c slightly longer and braid slides relatively well through the tight bends required. Guy who did my clutch spring washers said the Barnett was his favorite. THE laziest way to oil a new cable is to cut a small hole in corner of a Ziploc. Use rubber bands to seal it well. Find the heaviest gear oil you can. Fill the bag and hang it in the sun. Heating the oil can speed the process, but hours in the sun work. You shouldn't need to pull the inner cable up; the oil will find it's way. Once oil is dripping the bottom, you're done.
Sent from my DROID RAZR using Tapatalk 2 |
02-17-2013, 09:13 AM
#24894 | |
Oddometer: 298
02-17-2013, 04:35 PM
#24895 |
Thunderbirds Are Go
Oddometer: 282
What are you guys using for engine oil? The only 10W60 I can find locally is Motorex at $20 a liter. I talked to Spectro rep at IMS in NYC and they have it, but local dealers dont carry it. THX
08 Husqvarna TE 610 04 Ducati ST3 |
02-17-2013, 06:28 PM
#24896 |
Enjoying my last V8
Oddometer: 5,415
Shell 5W-40 Syn Rotella. $20 a gallon at Wall World
02-18-2013, 07:35 AM
#24897 |
Oddometer: 54
I have a set of black radiator guards that I got with my bike when I bought it. They are not the Unibiker (?), any idea's of what brand they may be?
Singletrak |
02-18-2013, 07:47 AM
#24898 |
Deputy Cultural Attaché
How about a photo?
Successfully surviving motorcycling since 1976. |
02-18-2013, 08:42 AM
#24899 |
Oddometer: 54
02-18-2013, 08:46 AM
#24900 | |
