10-21-2008, 05:31 PM
#8131 | |
Oddometer: 5,313
10-21-2008, 05:39 PM
#8132 |
Oddometer: 935
Flashman,
I also rode part of Rincon Trail, but loaded down for a trip it was really wrestling for me. Also being out alone I try to pick and choose my battles a bit more. You could get a Chrysler up the road pictured, might lose your muffler around the corner where it gets a bit rougher. YMMV
2000 KLR650 There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn |
10-21-2008, 11:16 PM
#8133 | |
...is swedish for black
Oddometer: 302
I´m no very fast... But my bike is.
- More than one cylinder? Then you need more than one bike! - I used to be Honda but now I´m better |
10-22-2008, 03:17 AM
#8134 |
Oddometer: 173
I am loving this bike!
![]() ![]() The TE610 has loads of low power, rides light and quick in the dirt, and can make some good distance on 3.3 gallons at 60+ MPGs. ![]() So, after 750 miles and some other nonsense, I settled on a handful of minor additions to my TE610 that i'd like to pass on - as most of them were gleaned from these pages from all of you - thanks! THE NUMBER 1 most important thing I needed for this bike! A new seat - i found the stock to be literally un-ridable after 100 consecutive miles. I settled on a custom seat from Renazco Racing! I have found A** Bli**! ![]() NUMBER 2 - luggage Not sure how durable the panniers will be, but I still see them on several of 06-07s. Recommend promoto billet rack and panniers. Dirt Bagz toolkit on top. ![]() NUMBER 3 - should be standard....SKIDPLATE I got mine from Uptite - looks cool, but no true bash tests yet. I'd like to see how others have held up. Photos? ![]() I also added 1 inch risers to the bars - now i can stand very comfortably in the dirt. ![]() One thing i'd like to find is a smaller license plate and light rear assembly. Any one recommend any winners? Or any other must haves? Cheers! hope this can help someone.
2008 - TE610 1997 - XR400R My Ex's 2001 - YZ426 : 1984 - XR500R : 1982 - Original Big Wheel __________________________________________________ ________________ "YOU'RE NOT STUCK. YOU'RE JUST LAZY" ![]() |
10-22-2008, 06:35 AM
#8135 | |
Deputy Cultural Attaché
Baja Designs makes a rear LED light & fender that replaces the stock fender; I think several other owners have them and like them.
Successfully surviving motorcycling since 1976. |
10-22-2008, 08:56 AM
#8136 |
Oddometer: 935
I have been using the Baja Designs rear tailight fender assembly, LED, for the past 3,400 miles. It takes just a bit of whittling to fit the way I wanted it to but works great. I will try to post a picture later if I can uncover my camera.
10-22-2008, 10:29 AM
#8137 |
Twisted Throttle
Oddometer: 1,673
RPM question
Can you TE610 owners tell me the RPM's the engine is at when going the following speeds in 6th gear with stock factory sprockets?
55 mph 65 mph 75 mph Also, what RPM does the rev limiter kick in at? Next, with stock gearing, what rpm does the engine turn at 10 mph in 1st gear? |
10-22-2008, 12:07 PM
#8138 |
Oddometer: 46
Well I just had another battery bite the dust!! This will be the bike's (2006 te 610) third. (The first one thats died on me). I know the stock one is crappy, but how are your batteries holding up? Any good alternatives? I know batteries were recently talked about here.......I guess I can't operate the "search" function correctly.
Here we go again |
10-22-2008, 12:37 PM
#8139 |
Card carrying greeny
Oddometer: 1,015
See this battery thread:
http://www.advrider.com/forums/showthread.php?t=325322
See my pics Dave: The 610 really makes me want to ride like a punk everywhere I go. bikefrk: You now understand supermoto. Your training is complete. |
10-22-2008, 12:56 PM
#8140 |
Oddometer: 485
dont know much about the huskys. What is the service interval for the 610 bike?
It sure looks very cool |
10-22-2008, 02:20 PM
#8141 | |
Gravel Wanderer
Oddometer: 12
Speed @ various RPMs w/ stock gearing
As a reference to the following charts, I did verify the calculations at three different points, 4th, 5th, and 6th gear w/ speeds of 42, 55, 62, and RPMs of 4200, 4500, and 4200 respectively. The black numbers in white background are in MPH.
2007 Husqvarna TE610 1994 Ducati Elefant (E900) - gone Sycip 29" Rigid Steel - geared | Walt Works 29" Rigid Steel - single | Gunnar Roadie Rigid Steel - geared | Bianchi San Jose Supercommuter - single | Bianchi San Jose Supercxracer - single |
10-22-2008, 02:25 PM
#8142 |
Oddometer: 173
This may be one of your site's or already be posted here somewhere, but I just found it and thought it was worth posting again for anyone who didn't know about it. Some good info, descriptions and insight - maintenence etc.
http://rickramsey.net/TE610maintenance.htm
2008 - TE610 1997 - XR400R My Ex's 2001 - YZ426 : 1984 - XR500R : 1982 - Original Big Wheel __________________________________________________ ________________ "YOU'RE NOT STUCK. YOU'RE JUST LAZY" ![]() Longerday screwed with this post 10-22-2008 at 02:41 PM |
10-22-2008, 02:27 PM
#8143 | |
Oddometer: 85
This bike seems to be the perfect compromise. 220 lbs of me and 50 lbs of gear and it kept right up in California bay area freeway traffic. (Not saying I enjoyed it....) And now that my off-road skills are improving, it does fine in tight single track as well. (Though I'm sure a lighter bike would be better.) |
10-22-2008, 05:40 PM
#8144 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Twisted Throttle
Oddometer: 1,673
RPM vs Speed
Elefant runner
My gear chart shows similar results to what you posted
Can someone tell me what RPM the rev limiter kicks in (max rpm)? |
10-22-2008, 05:47 PM
#8145 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Twisted Throttle
Oddometer: 1,673
For comparison purposes these are the results to a TE510 with changes to the front/rear sprockets for dual sport use. RPM is limited at 10,500.
TE510
