Old 11-05-2008, 04:50 PM   #8341
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
The 650 GS has a hydraulic tensioner, is a different mechanism.
Regards.[/quote]
Oaxacuzano, I stand corrected, I thought it was a constant tension, spring-type CCT.
2010 BMW R1200RT, a sweet scooter for my daily 100 mile commute.
'08 Husqvarna TE-610, sold
waiting till I retire to get a new adv bike. meanwhile........
spanker is offline   Reply With Quote
Old 11-05-2008, 05:25 PM   #8342
Olas
the darkness
Olas's Avatar
Oddometer: 4,048
510-610 skid plate compatibility
How hard would it be to adapt a 510 skid plate to a 610 frame? What are the differences in the two? I haven't had a chance to check out a 510 so i've got no idea.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 11-06-2008, 01:15 AM   #8343
rhino_343
Southern Explorer
rhino_343's Avatar
Oddometer: 2,131
Question Help!!
I am purchasing some new wheel bearings (front and rear wheels) for my 2007 TE610 and I looked up the Husky part manual... and you can call me stupid if you want ... but I can't work out what the part numbers and sizes are for the bearings and seals? Can someone who is familiar with this please help me out??
Moto Guzzi Griso 1100
Suzuki DR650SE P I G
Husaberg FE350
Tenere XT600 34L 1983 classic
rhino_343 is offline   Reply With Quote
Old 11-06-2008, 01:29 AM   #8344
bass_on_tap
bass_on_tap's Avatar
Oddometer: 2,364
Found this posted by Geek earlier.
Front Bearing Reference
(I'm posting this here for anyone searching in the future.. i.e. next time I need front bearings and I search this thread )
Microfiche is wrong.. front wheel has two bearings dimmension: 25x42x9
The bearing number is 6905-2RS and is also known as 61905
(the 2RS means 2 rubber seals).
Local bearing place has to order them: $10.95 each.
Thanks to MSU Yooper for the PMs and Indy (who has the number correct above but the dimensions incorrect).
The outer seal rings are 32x47x7... and this is what I had confused in an earlier post when I claimed there were 3 bearings.
Also see post 6199 for rear bearing info.
http://www.advrider.com/forums/showp...postcount=6199
bass_on_tap is offline   Reply With Quote
Old 11-06-2008, 02:18 AM   #8345
rhino_343
Southern Explorer
rhino_343's Avatar
Oddometer: 2,131
Thanks Bass, that was super fast mate! I hope that Geek has an 07 and not 08 or that the two bikes share the same bearing parts though?
Husaberg FE350
Old 11-06-2008, 02:33 AM   #8346
bass_on_tap
Oddometer: 2,364
Nobody else has answered yet because it 3:30 am here in the states and most all normal people are still asleep. BTW, Geek's bike is older than an 07 judging by the color. However, Mrkartoom's bike is an 08 if that matters.
bass_on_tap screwed with this post 11-06-2008 at 02:38 AM
Old 11-06-2008, 06:37 AM   #8347
Trang
... 2nd last to the Sweep
Trang's Avatar
Oddometer: 1,087
If those dimensions are correct, the bearing number is the 61905-2RS.
Atleast in Aus anyway.
Not sure where the 6905 number comes from?
"I still haven't worked out why all these people are here, but all I can think is there's a small amount of craziness left in an increasingly sanitised world and they want to be part of it"
Russ Malkin 2006
Trang is offline   Reply With Quote
Old 11-06-2008, 10:46 PM   #8348
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,601
What is the stock fork oil weight in a 2006 TE610?
Old 11-07-2008, 03:55 AM   #8349
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
Geek, I don't know but I can tell you this: get rid of it and replace with 5wt and lower oil to at least 120mm to increase air volume. I weigh 185 w/full gear and sometimes I'd like it even softer, especially for slow, stutter-type ruts and rocks.
Old 11-07-2008, 03:58 AM   #8350
spanker
bada bing, capiche?
spanker's Avatar
Oddometer: 825
Geek,
Sorry, I didn't notice you had an '06 with comp adjusters, I have an '08 w/o. I am a big believer in lowering fork oil level. It's easy to experiment with because you can add oil easily if it's too soft. When I put my comp adjusters in this month, I'm going to go as low as 160mm from the top and see how I like it.
Old 11-07-2008, 04:59 AM   #8351
Oaxacuzano
Dromo maniac
Oddometer: 61
The removal of the Copm to the front forks is tanks to the BMW, I hate those stupid cost reductions.
Other cost reduction es the removal of the cap in the left side of the generator to move the crank in order to put the piston in TDC to adjust the valves, for the 08 you need to remove all the left side cover.
Next cost reduction that i found is for the rear shock absorver, only has 2 adjusters instead of 3.
The last cost reduction is the removal of the switch to turn off the front lamp and leave on only the little light, some times called candle, I do not care this removal, but it is a cost reduction.
I think BMW should not keep making these stupid cost reductions and concentrate the efforts to fix the epidemic issue of the cam chain tensioner or the principal crank nut gear.
If you see their Xchallenge or X some think bikes are crap, they look like cheap chineese bikes.
Oaxacuzano is offline   Reply With Quote
Old 11-07-2008, 05:33 AM   #8352
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,676
What are you talking about ? BMW had not taken production over. Certainly not when the 08's were being designed. Thats Cagiva. Production cost reductions yes, but not by BMW.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 11-07-2008, 06:09 AM   #8353
Xfool
Xfool's Avatar
Oddometer: 383
Stock fork oil weight is 7.5w.
Reducing oil height beyond 4 inches is good for rocks, but I found I couldn't keep the front end up in whoops. So I am back to running a 4 inch oil level in the forks.
Tuning is definitely a personal deal. YMMV.
Xfool is offline   Reply With Quote
Old 11-07-2008, 06:13 AM   #8354
Switch Blade Sammy
Oddometer: 14
Hi guys, I'm about to buy a 01 TE-410 of a friend of a friends. This will be my first bike. Is there anything that I need to lookout for when checking the bike out? I plan on using the bike for some off road and more commuting. I understand that I'll have to learn the 4stoke shuffle kickstart.
Switch Blade Sammy is offline   Reply With Quote
Old 11-07-2008, 08:47 AM   #8355
garet55947
Oddometer: 353
Repair manual, where to get one?
I checked Clymers, Haynes, Chiltons, etc. and no one has a repair manual for the TE610. Those really came in handy over the years that I have owned bikes. Is there a good quality repair manual available for the TE610 '06/'07 model? Thanks.
garet55947 is offline   Reply With Quote
Times are GMT -7.   It's 10:05 AM.
