Old 09-24-2006, 02:10 AM   #121
squids leap
Wanabe Adventurer
Oddometer: 110
thanks a lot buffalodan I'll try that before I think about lowering the bike.
squids leap is offline   Reply With Quote
Old 09-24-2006, 12:46 PM   #122
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 565
Originally Posted by squids leap
I can't get the bike off the kickstand, I'm still kicking the idea around to lower the bike a little/I have a 29 inch inseam /the rear shock doesn't even compress when I try to sit on it due to the angle. Any other shorties out there on the 610?
I agree with what BuffalloDan said about your suspension setup to get you going.
I weigh about 230 pounds, with a 30 inch inseam. When I bought the bike, they told me they would lower it a couple of inches for free with the purchase. I changed my mind at the last minute because I just didn't want to lose any of the suspension travel. When trying to decide which dualsport to get, wasn't the excellent suspension travel one of the reasons you picked the Husky? It was, for me, part of that decision to get the most capable off road dualsport instead of a dualsport more in tune with pavement travel. I ws thrilled with the new purchase, but intimidated to say the least at this taut suspension that wouldn't even budge under my (quite heavy) weight.
Here is the point of my post ; Don't worry about it.
Set it up like Dan said to get it going, and realize that for like 2 or 3 thousand miles, the more you ride it, the better it is going to get. It will soften up, and it will lower itself slightly. Don't forget about the compression and rebound damping settings, these help a lot to make it feel less harsh(so does going really really fast!!oops I forgot, its your first dirtbike- don't go really really fast.)
I just did an almost 1300 mile trip on my TE, with me and about 40 pounds of gear including boots and jacket and helmet. I knowingly overloaded the bike, just to see if it could handle it. I was looking for a confidence booster in my bike, and boy did I get it. I crashed it in the mud probably 6 times, bent both the shift and the brake foot levers, broke the mirrors, broke the turnsignals, pushed it with the engine going through rushing floodwater that was over my knees. Through all this abuse, THE BIKE PERFORMED FLAWLESSLY.
I set the preload to the max before the trip, and guess what, I had 4 inches of sag with all that damn gear!!! (Note; I should have listened to what BigDog said about the trail, and taken less gear, it would have been more fun.)
For me, the front and rear suspension has proven very adjustable, stout, and thoroughly impressive. I don't ride much motocross stuff-mainly rocky trails and hillclimbs, gravel roads, and probably 40 percent highway getting to and from "my spots."
Sorry for the long post, I just wanted to build your confidence up as you are making your purchase. I bought mine last March, and can still remember feeling like I was getting in over my head with the tall suspension. I almost knocked the bike over at the dealer when I first tried to straddle it. There were 3 salesmen watching and the bike was in a long line of new bikes. If I were to have fallen, it would have been like dominos falling down.
"It's not a death machine, Mom, it's a LIFE machine" - a motorcyclist
Chadleys1 is offline   Reply With Quote
Old 09-24-2006, 04:24 PM   #123
buffallodan OP
buffallodan's Avatar
Oddometer: 1,709
I have to post to comment on the Throttle Cam Rayhttp://www.cycle-analyst.com/DSR-100.htm is going to carry. I have been having trouble on the trails I ride because I need to ride in first gear often (second is too fast), and trying to control the throttle is really herky jerky. I have pretty good hand control but it has so much response that I was getting worn out having to be so precise. Today I install the G2 http://www.g2ergo.com/ - and I could tell right away it is going to be so much easier to ride the tight stuff. If you find yourself in first gear and getting jerked around you might want to get one of these...btw I got the 200(7%) 300 and 400 and installed the 400 which is 20% reduced throttle initially. I think the standard kit comes with 100(stock) 200 and 300...
Dan
buffallodan is offline   Reply With Quote
Old 09-24-2006, 05:56 PM   #124
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 565
Thumb Yep
I need that too, for the really tight stuff.
Old 09-24-2006, 05:58 PM   #125
Chadleys1
working on it
Chadleys1's Avatar
Oddometer: 565
Laugh soon
Along with the smoother low end throttle control, soon we get dirtbagz and big giant fuel tanks. I can't wait.
Old 09-24-2006, 06:07 PM   #126
buffallodan OP
Oddometer: 1,709
Wooooot, I am so stoked to get the bags and tank I can't wait to get in a multi-day camping trip with full gear...hotdamn.
Hey BTW is anyone thinking of adding a screen for some cold weather protection? I am thinking of the F650 Dakar Screen with the Baja Light...
Dan
P.S. On installing the throttle with cam it might be a good idea to use O-rings that would fit between the tube and bar to minimize vibration. I used a shim made of plastic as I didn't have any o-rings but plan on trying them if I ever change grips...there will be light friction that will act like a cruise control so keep that in mind.
buffallodan screwed with this post 09-24-2006 at 06:15 PM
Old 09-25-2006, 07:38 AM   #127
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
Is that a Baja Tecate with a chopped up Dakar screen? Looks pretty good. Have you priced one of those screens?
On another note where's that drill bit you had for the bar ends? Looks like there may be a couple of guys wanting to use it. I just broke both my Cycras at the bar end (the screws broke) any of you guys know where to get replacement parts?
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 09-25-2006, 09:35 AM   #128
Dualsport
Maker of Sweet Cheek
Dualsport's Avatar
Location: Cincinnati the best riding in the area, aint here
Oddometer: 885
The kit I carry comes with the 100,200 and 400 cams. $90 plus $5 shipping
I also carry an adjustable thumb screw for idle mixture, it helps when you need to soften the bottom end also. $24.95
You can easily adjust the idle mixture a little richer or leaner depending on your needs.
Brian from Unabiker has my bike and I will have radiator guards before the weekend
CAM 100Y -
Best choice for tracks with perfect traction - from wet sand to loam. When traction is optimal, try CAM100.
CAM 200Y - Perfect for intermediate conditions. From mixed sand to hard terrain, this is the most versatile cam available. For intermediate traction, try CAM200.
CAM 400Y -
The best choice for slippery, technical and/or tight woods conditions. From hardpack to rocky, technical terrain to all types of mud. When traction is elusive, try CAM400
Ray Pope
Dual Sport'n in Cincinnati
Dualsport is offline   Reply With Quote
Old 09-25-2006, 09:44 AM   #129
Dualsport
Dualsport's Avatar
Oddometer: 885
Dan that slight gap can be greased or left dry. Anything added to "shim", could cause the throttle to not spring back.
Ray Pope
Old 09-25-2006, 02:43 PM   #130
buffallodan OP
Oddometer: 1,709
Thanks Ray,
Upon further consideration(I fall alot) I will be removing the shim and finding something that will allow the throttle to return but hopefully I can minimize the play...
Hoder, I think the screen is around 100.00 but I haven't found the specific info yet as per part number...as to the Tecate that'd be a yes.
I broke the bolt too on the handguards. I think the bend is creating stress as the guard doesn't sit flush against the end of bar so upon impact there is shear stress. Your local hardware store should have the screw. It is M8 X 1.5 X 50mm. I think a longer screw would be better as the 50mm doesn't fully engage the threads of the nipple.
Dan
P.S. I still have the bit if someone needs it...
Old 09-25-2006, 03:43 PM   #131
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,706
You mean the throttle tube is too large for your bar end? I had a small bit of that on my KTM. The aluminum tube kinda rattled a bit. Seems to be better with my new bars though. It doesn't bother me any more.
Are the Husky bars weirdly sized or something. Is there a lot of play? I have some fairly rigid adhesive PTFE which is about 1/32" thick I was planning on using on my bars, but it was too tight so I couldn't.
BTW, don't try wrapping your bar end in regular teflon tape. I did and it worked fantastic, but before too long it will begin to wad up and it will become unsafe. That's why I ordered something rigid which would hopefully stay put.
For throttle tube lube I use a dry film PTFE spray.
potatoho screwed with this post 09-25-2006 at 03:48 PM
potatoho is offline   Reply With Quote
Old 09-25-2006, 05:39 PM   #132
buffallodan OP
Oddometer: 1,709
Hey Potatoho,
The tube is larger and it could be that the Husky Stock bar is smaller than normal? I think I am going to try the PTFE(water bottle) material next hopefully it is thin enough. O-rings are 1/16" which is too big...I don't want it to vibrate and it probably needs to be free to retract so the thickness must be just right. Too bad there isn't something like a nylon bushing that would be the right size but I have looked everywhere...
Dan
Old 09-25-2006, 07:39 PM   #133
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,706
Hey Potatoho,
I'll show you what I bought. Sorry, I was wrong, it was UHMW tape. Part #CPSTRIP is $3.45/ft and 2" wide. About 0.025" thick.
http://www.apsltd.com/Tree/d3000/e2141.asp
It's the glide stuff they put on the bottom of computer mice.
You might want to try some stacked papers in there, and measure what fits, to make sure that 0.025" won't be too thick.
potatoho screwed with this post 09-25-2006 at 07:44 PM
Old 09-25-2006, 10:19 PM   #134
Hoder
Hoder's Avatar
Oddometer: 1,019
Thanks Ray,
I think you're right. I'm going to pre-form them before re-installing so they fit perfect. After 3 dealers I found one to order the bar end kits (I lost the alum. wedges on one side)
See my pics
Dave:
bikefrk:
Old 09-30-2006, 07:10 PM   #135
buffallodan OP
Oddometer: 1,709
Hoder tell us how you plan to form the Cyrca's as I put them in a vise and couldn't get them to move...
I need someone to post a pic of the dogbones and other pivots as I think I may have put my links back together wrong. I removed two bolts to rotate the bottom of the shock so I could get to the damping screw but am afraid I lost a washer. There were two spacers and a washer and I need to make sure I put the washer on the correct side. I placed the washer on the nut side not the bolt side, is that correct? TIA
btw the bolt is slotted to clear the swingarm and I didn't remember there being a washer on that side...
Dan
Times are GMT -7.   It's 10:47 PM.
