Old 08-05-2006, 06:46 AM   #1
Hotspice OP
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,423
Finding by Long and Lat
Ok, this may be a simple question but for the life of me I can't figure out how, on my 276C I can find a location if someone gives me the Long and Lat..
I even tried to find it using mapsource 6.x but don't find that under the find options..
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 08-05-2006, 12:55 PM   #2
brfinley
Brooster
Oddometer: 421
I don't know the 276C specificly, but it is probably easiest to simply make a new waypoint (MARK), edit the coordinate fields to match your values before saving it. You can do the same in Mapsource, or your can just scroll around on the map with your mouse and watch the values at the bottom of the window.
You have to check two things: That whoever sent you the coordinates is using the same map datum as you (usually WGS 84 for our part of the world). And, you have Mapsource and your GPS set to the same coordinate display format (like decimal minutes, or degrees-minutes-seconds, etc.).
Maybe in the future, whoever is sending you these things could just send you a .gdb or .gpx file with the waypoint in it.
brfinley is offline   Reply With Quote
Times are GMT -7.   It's 07:10 PM.
