Go Back   ADVrider > Riding > Face plant
Old 07-27-2005, 05:10 PM   #16
MikeCont
Gelande Strasse Gebrochen
MikeCont's Avatar
Oddometer: 2,024
...how about tipping your gs into a flower bed at the DMV while practicing tight, slow turns prior to your rider test?
...riding in the cold...in jeans...until you discover, when you stop, that your legs don't work (due to the cold).
...tipping your bike over at a gas station.
Vance, you are a braggart, and a pox on you.
2006 R1200GS
1973 Honda trail 90
"All things in moderation, including moderation"-Chace
MikeCont is offline   Reply With Quote
Old 07-27-2005, 05:32 PM   #17
richard cabesa
The Mayor
richard cabesa's Avatar
Oddometer: 9,004
motorcycles are dangerous
F800GS
R1200RT
Ca Stew says "You can't teach a pig to sing. It wastes your time and annoys the pig."
richard cabesa is offline   Reply With Quote
Old 07-27-2005, 08:15 PM   #18
Makalu
Makalu's Avatar
Oddometer: 2,779
Originally Posted by svs
That list is so fucking long it depresses me. In fact, the way the list was written sounds like you have dropped the bike or crashed at least once for every example listed.
If true, You should consider a new Hobby.
I thought the same thing. At least now I will be even more cautious of the inevitable and impending bike tip over.
As for me, I've only done three on your list.
Makalu is offline   Reply With Quote
Old 07-28-2005, 02:26 AM   #19
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,141
Pissed Variations on the Theme
*Thinking* the kick stand was down when it wasn't, but next to a Petrol (gas) pump so your leg is trapped between the bike (fully loaded) and the pump so you cant get it back off you!
Rebuilding a carb on a 250 Montesa Cappra, starting it in gear with the clutch in for safety, finding the throttle stuck open, dropping the clutch to stall it, getting dragged across a car park and through a hedge wide open in second.
Forgeting to tighten that nut on the front brake drum holding the torque arm(same 250 Montesa Cappra).
Have the rear brake lining come free of the shoe and jam under the other shoe braking for a 90 degree left (got picked up by a vetinary surgeon after that one and then spent 10 days in hospital) same 250 Montesa Cappra.
Stopping at a stop light and realising that the truck broken down on the other side of the stop has dropped the entire contents of its diesel tanks.
Welshman
Welshman is offline   Reply With Quote
Old 07-28-2005, 03:16 PM   #20
notmike
notmike's Avatar
Oddometer: 243
How about when the bike instantly falls over as soon as you let out the clutch, and thinking you slipped on the wet grass, pick up the bike and do it again, only to realize the disc lock is still attached to the front disc?
notmike is offline   Reply With Quote
Old 07-28-2005, 04:33 PM   #21
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,921
How about forgetting to turn off the ABS on a muddy dirt road with Tourance tires?
Note the ABS skid marks!
Then digging a hole so deep you have to lay the bike down to get it back out.
Sorry for the blurry picture.
Second lesson learned: "Don't ride alone off road!"
Third lesson: "Get more agressive tires if you intend to ride in the mud!"
Jim
Old 07-28-2005, 06:58 PM   #22
celtic
now ale capone
Oddometer: 26
Originally Posted by wibby
the hard part is getting it up in the first place. she had no trouble helping to push it in.
celtic is offline   Reply With Quote
Old 07-31-2005, 07:10 AM   #23
DaleB
DaleB's Avatar
Oddometer: 437
Send a message via AIM to DaleB
...trying to be cool by driving off the centerstand the first day you own an 1150GS...
"When one door closes, another opens. But we often look so regretfully upon the closed door that we don't see the one that has opened for us."
- Alexander Graham Bell
'05 R12GS - in a wad
'04 LemFiddyGS - sold
'84 RM125 - sold
DaleB is offline   Reply With Quote
Old 07-31-2005, 08:27 PM   #24
Rick G
Ranger Rick
Rick G's Avatar
Oddometer: 1,636
Though I have dropped every bike I have ever owned, mostly due to dumb mistakes, my favorite drop happened as I was preparing to leave for a rally on my R80 G/S, fully packed including several bags strapped to the luggage rack behind my solo saddle. I had moved my bike out of my garage and into the alley to fire it up and warm it a bit while I suited up and closed the garage door. What I did not notice was that the sidestand was on a little hump in the asphalt, leaving the bike almost staight up. I go to mount the bike and as I am piled high in the rear, I have to step through the saddle, which I do, but the heel of my boot ever so lightly touched the saddle, which was just enough to cause it to start falling away from me ever so slowly. There I am with one leg up in the air and almost over the bike, holding the handlbars and trying, in vain, to prevent the inevitable drop to the ground, engine running and gas leaking from the float bowls.
With a mighty shrug and grunt, I righted her and had a very uneventful trip!
Rick G
Any Road Any Time!
2009 Triumph Bonneville T100 - Neo Classic Retro Tourer.
2009 Vespa GTS Super 250ie - Just for Kicks & Giggles
Rick G is offline   Reply With Quote
Old 08-03-2005, 08:32 AM   #25
PawnBroker
PawnBroker's Avatar
Oddometer: 1,808
Send a message via AIM to PawnBroker
Originally Posted by arethustra
Good lord you have way tooooo much free time!!!!!
What he just said.
PB
PawnBroker is offline   Reply With Quote
Old 08-03-2005, 10:10 AM   #26
drrider1
just running amuck
drrider1's Avatar
Oddometer: 360
Jeebs I thought you had to drop each new bike to make it truly yours .............ya mean..........I'm wrong??????????
drrider1 is offline   Reply With Quote
Old 08-03-2005, 02:28 PM   #27
TxDieHart
TxDieHart's Avatar
Location: Corpus Christi, Texas No Hills but we have a Beach
Oddometer: 147
I think you missed
Originally Posted by kehale
Posted: 02 Apr 2003 18:00 Post subject: A couple ways to drop your bike...(got any more?)
I think you missed
Riding a GS in the mud until the mud clogs up the front fender, locking it up more effectively than ABS ever could. Watching (from the ground) as the following GS's experience the same fate. Then realizing that you will have to remove the front fender if you want to get out before the mud dries. Then realizing that you have to remove the front brakes, and front wheel to get at that bolt that holds the fender on.
TxDieHart is offline   Reply With Quote
Old 08-05-2005, 11:31 AM   #28
Skyd1v
ABSRA Co-Co-Founder
Skyd1v's Avatar
Oddometer: 381
Ah, hell, I gotta reply to this.
Attempt to ride your shiny new-to-you Honda Cruiser out to your parents house in Godforsaken Nowhere, Alaska on a unimproved clay and mud road in the middle of spring breakup ........ in the rain.
Guaranteed to keep your attention.
Blue skies/
Dumb-A$$ bomb! Kinda like a water balloon but with more vulgarity!
Skyd1v is offline   Reply With Quote
Old 08-09-2005, 05:15 AM   #29
Vance
Vance's Avatar
Oddometer: 18,239
Blue skies/
Don't choo mean "Bumfuck Asia?"
Do a pop a wheelie!
"I'll leave you to tidy up the woulds and shoulds, wills and shalls, thats and whiches, etc." - Oscar Wilde
Vance is offline   Reply With Quote
Old 08-09-2005, 11:28 AM   #30
Robert in TX
Insane Genius
Robert in TX's Avatar
Oddometer: 3
Question
48. Trying to countersteer (or wheelie) your shaft dirven bike? ;-}
Don't get this one... could someone 'splain it to me?
Robert in TX is offline   Reply With Quote
Times are GMT -7.   It's 11:04 AM.
