Old 08-07-2006, 12:27 AM   #1
Countdown OP
Oddometer: 3,971
2 failed 76C's
My first 76C failed. Batteries seamed to loose contact. I could just tap it and it would go off. Tried to bend battery contact and it broke. Shoved a wire behind it and added tape to batteries to keep them from moving and it is now working on bike.
Bought 2nd unit for backup while I send in first unit form repair. Used 2nd unit this weekend. On 2nd day it started shutting down. Could not get it to stay on. Traded it with a guy in our group as I was leading. That night it would stay on with hard hits? However it now has a rattle.
My old e-map did the same thing and the repair note from Garmin said that the "super cap" had come loose. I think they need some epoxy on the heavy parts with only two leads.
Jerry Counts
Countdown is offline   Reply With Quote
Old 08-07-2006, 03:23 AM   #2
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 11,654
Do a search - more than a couple threads on the battery powered units shutting down due to vibration breaking the connections - and some effective fixes.
Dave
[quote=Countdown]My first 76C failed. Batteries seamed to loose contact. I could just tap it and it would go off. Tried to bend battery contact and it broke. Shoved a wire behind it and added tape to batteries to keep them from moving and it is now working on bike.
quote]
dunno.....
Old 08-07-2006, 06:31 AM   #3
SteveAZ
SteveAZ's Avatar
Oddometer: 800
It is very well known that battery contacts go south if you leave the batteries in the unit in vibration conditions; whether on external power or not.
The choice is simple; either remove the batteries when the unit is on the moto (or whatever else vibrates) or send the unit back to have the contacts repaired every so often....
SteveAZ is offline   Reply With Quote
Old 08-07-2006, 09:11 PM   #4
Countdown OP
Oddometer: 3,971
The rattle kind of tells me that there is a problem other than the contacts.
Some tape on the batteries so they will not move helps with the contacts.
Jerry Counts
Times are GMT -7.   It's 08:36 AM.
