04-07-2007, 08:49 AM
#151 | |
Dirt Newbie
Oddometer: 36
Winter Sucks |
04-07-2007, 03:27 PM
#152 |
Oddometer: 247
Work.
PM sent on manual. Hayden |
04-08-2007, 01:27 PM
#153 |
boss of the box
Oddometer: 463
pretty much all done
I have to install handgaurds, tooltube and aluminum chain gaurd. I have about a hundred klicks on the fresh motor. 102mm bore,fresh valves and chains. suspension is now kickass courtesy Mr ohlins and Mr racetech.
Laws of the motorcycle universe. 1. Ya don't need a faster bike, just ride faster. 2. The natural state of a motorcycle is on its side. 3. My bike and its owner are faster than yours. http://www.advrider.com/forums/showt...hlight=klxmack |
04-08-2007, 01:28 PM
#154 |
boss of the box
Oddometer: 463
pic2
more pics.
04-08-2007, 01:29 PM
#155 |
boss of the box
Oddometer: 463
pic3
and more...
04-08-2007, 01:31 PM
#156 |
boss of the box
Oddometer: 463
pic4
and more...
04-08-2007, 03:02 PM
#157 |
Oddometer: 2,017
Anybody can tell how good actually are these klx650 bikes?
major problems etc..? |
04-08-2007, 03:50 PM
#158 | |
greetings from Wa state
Oddometer: 4,094
Stunning! one of the trickest, wag this SOB in front of some Kawasaki exec's etc... better yet in front of honda, suzuki VIPS , tell its a 08' prototype, let em get real nervous.
was it a pain to mount the ohlins w/ the res.? Quote:
“I would rather wake up in the middle of nowhere than in any city on earth.” .....Steve McQueen |
04-08-2007, 03:55 PM
#159 | |
Oddometer: 4,094
the biggest problem is that they arent made anymore. take a KLR, add better suspension, brakes, frame ( =handling) , excellent part availablilty, cheap to buy...... biggest issue for me was small tank ( I'm in on the 5 gal purchase, so that solved) and a seat that could use improvement, working on that. there is some reports of a cam chain issue or something like that, I am l looking in to that.
04-08-2007, 04:08 PM
#160 |
Oddometer: 152
Well i just picked up a 93 650R last weekend. Working on getting it street legal right now.
04-09-2007, 09:32 AM
#161 |
Oddometer: 152
Just wondering if anyone has added a battery to their 650R and if so where did you put it?
Thanks Pyro_ |
04-09-2007, 10:57 AM
#162 | |
Riding is my passion
BTW, I really like that light setup on yours.
BlueLghtning - Follow me on my SPOT Messenger Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650 Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225 Smugmug Pics - Save $5: Y2l43o9LVBERU |
04-09-2007, 11:15 AM
#163 |
Oddometer: 152
The lights are the Acerbis Cyclops. What i am considering doing is putting on a smaller overflow resevoir and getting a friend to weld up a stronger steele hanger where the overflow bottle is. Then put a battery there. Still trying to work things out tho cause i would like to get a full size motorcycle battery on it.
04-09-2007, 04:14 PM
#164 | |
boss of the box
Oddometer: 463
I did some cross referencing and a 2004 drz400 is about .5 inch longer than the stock shock. installed a 7kg spring and preloaded about 1.5 inches. you need to remove the crappy stock tool holder, cut the tool holder tab off the frame. You need to drill out the upper mount threads on the frame and run a slightly longer bolt the opposite direction with a nut. The lower clevis has no threads , so i ran a longer bolt with a thin locknut. the valving seems o.k. i left the stock compression setting but i increased the rebound 4 extra clicks. This took me about 1 hour to figure out and install. this bike has heaps of travel. i'm 6' tall with 34" inseam and i cant touch flat footed with both feet. cheers
04-09-2007, 04:31 PM
#165 |
wiggem
Oddometer: 3
KLx woes
So I just broke the stud off That hold the Exhaust manifold to the engine on my 94 KLX-650r.
Just wondering if anyone knows if it is threaded or pressed into the engine? please god let it be threaded
