Old 04-09-2007, 05:41 PM   #166
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 3,845
Send a message via AIM to BlueLghtning Send a message via MSN to BlueLghtning Send a message via Yahoo to BlueLghtning
Originally Posted by klxmack
It was real easy to mount.
I did some cross referencing and a 2004 drz400 is about .5 inch longer than the stock shock.
installed a 7kg spring and preloaded about 1.5 inches.
you need to remove the crappy stock tool holder, cut the tool holder tab off the frame. You need to drill out the upper mount threads on the frame and run a slightly longer bolt the opposite direction with a nut. The lower clevis has no threads , so i ran a longer bolt with a thin locknut.
the valving seems o.k. i left the stock compression setting but i increased the rebound 4 extra clicks.
This took me about 1 hour to figure out and install.
this bike has heaps of travel. i'm 6' tall with 34" inseam and i cant touch flat footed with both feet.
cheers
Hmm, thats some good info. What about front springs for our bikes? Do they make any for it?
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 01 FZ1, 08 WR250R, 98 DR650
Hers: 06 F650GS, 12 Duc 696, 13 CRF250L, 06 XT225
Smugmug Pics - Save $5: Y2l43o9LVBERU
BlueLghtning is online now   Reply With Quote
Old 04-09-2007, 06:30 PM   #167
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,691
Front springs are easy. Pick anything for a 43mm fork. KX500 had KYB 43's for awhile as did many others. They will be the wrong length. Grind them off to a sharp angle at the correct length. Place the spring in a vise near the end, heat them till they glow red with a MAP torch, and form the end with a hammer. It's easy to flatten them nearly as well as the factory. Not a tough job.
MINIMOUNT
Hard Shell Netbook Case & Mounts
R-dubb is offline   Reply With Quote
Old 04-09-2007, 07:44 PM   #168
klxmack
boss of the box
klxmack's Avatar
Oddometer: 463
pretty easy, bought some racetech springs 43mm 1992 kx250. .48kg.
very firm ride solo with no gear. but i'm sure when i load the beast down with a new acerbis 5 gallon tank and stick on three hard bags for my cross canada and U.S tour , it will be perfect. .46 kg springs would be good for reg dualsport.
cheers
Laws of the motorcycle universe.
1. Ya don't need a faster bike, just ride faster.
2. The natural state of a motorcycle is on its side.
3. My bike and its owner are faster than yours.
http://www.advrider.com/forums/showt...hlight=klxmack
klxmack is offline   Reply With Quote
Old 04-09-2007, 07:49 PM   #169
klxmack
boss of the box
klxmack's Avatar
Oddometer: 463
Originally Posted by wiggem
So I just broke the stud off That hold the Exhaust manifold to the engine on my 94 KLX-650r. Just wondering if anyone knows if it is threaded or pressed into the engine? please god let it be threaded
Its threaded and its probly gonna pull the threads out when you try to pull it out.
Make friends with a motorcycle mechanic. I will be a lot easier.
cheers
Old 04-10-2007, 12:12 PM   #170
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 311
Question Wheel bearing part numbers
Hi all,
A friend with a '95 KLX650 needs to know the bearing part number (not the Kawi#) for the front wheel bearings.
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 04-14-2007, 06:00 AM   #171
klxmack
boss of the box
klxmack's Avatar
Oddometer: 463
Originally Posted by EduardoMas
Hi all,
The Kawi is #601B6202UG all you do is take the 6202 out of the part number and that is your universal bearing #. ask for double rubber sealed bearings.
cheers
Old 04-19-2007, 08:17 PM   #172
pyro_
pyro_'s Avatar
Oddometer: 152
In case nobody has noticed one of the guys in the vendor forum would be intersted in making a rear rack for our bikes if someone near Cali could volentere their bike for him to mock it up on. Could give us another option other than happy trails for a rear rack, especially for the 650R. here is the thread: http://www.advrider.com/forums/showthread.php?t=186789
pyro_
pyro_ is offline   Reply With Quote
Old 04-21-2007, 03:14 AM   #173
andrew150
andrew150's Avatar
Oddometer: 68
94 Klx 650c
Just wanted to bump this thread back to the first page. I own a 94 C model. What a great bike. I took it to Canada last summer and had a blast with it. Range was a problem but that can be solved with an auxiliary tank from a marine supply store for a boat. Just mount it to the back rack and you have several extra gallons to get you around. You just have to stop and put it in the tank. Anyway, the trip was great.
KLX's rock!
Andrew
There are risks and costs to action. But they are far less than the long range risks of comfortable inaction.
-John F. Kennedy
andrew150 is offline   Reply With Quote
Old 04-21-2007, 09:17 AM   #174
K7NUT
K7NUT's Avatar
Oddometer: 72
WOW! YA 'all got some nice bike's and amazing mods too!
I guess there's no limits when ya' put ur mind to it!
"If you choose not to decide, you still have made a choice."
"Those who know what's best for us, must rise and save us from ourselves"
'87 KLR 650
'00 Kawasaki Voyager XII
K7NUT is offline   Reply With Quote
Old 04-22-2007, 02:05 PM   #175
Hayden#69
Oddometer: 247
Mack.
I need some front springs for my KLX 95. Is this what Im looking for??
FRSP 395146 RT FRK SPR 38.2x512mm .46kg $109.99
From Racetech.
Is there any difference between the KX250 and 250F as far as size of spring. I know the length and dia have to be the same or very close.
Hayden#69 is offline   Reply With Quote
Old 04-22-2007, 02:18 PM   #176
jmemmert
Oddometer: 33
wow, I was looking around for the same thing just two days ago.
The 250f won't work.
Here is a list of bikes that the springs will fit. ( I'm not sure what the Spring rating is stock, but since they are a little longer than the klx650, they should provide a stiffer rate than the stock klx)
91-95 kx250
91-96 kx500
9?-95 cr500
" - " Cr 250
springs from 43mm ktm forks
I'm sure there are plenty more, but that's all I got so far.
So, does anyone have any of these laying around?
Jon
jmemmert is offline   Reply With Quote
Old 04-22-2007, 02:47 PM   #177
Hayden#69
Oddometer: 247
Cool. Thanks for that. I just got my Works Performance rear shock on before winter this last year and now ready for the front over haul. Then hopefully I will be done for a while.
Old 04-22-2007, 03:03 PM   #178
jmemmert
Oddometer: 33
I've also heard that you can stiffen up the front by making some spacers out of pvc. Don't really remember where or when? Does anyone think that sounds legit?
Old 04-22-2007, 07:14 PM   #179
BlueLghtning
Oddometer: 3,845
Actually, that justh compresses the srpings and adds preload. A certain amount of preload is good, but you don't want to go too far.
You can actually increase the rate of springs by cutting them and making them shorter. There's a limit to that too, because you'd have to add larger spacers to make up for the shorter springs.
Old 04-22-2007, 07:32 PM   #180
Hayden#69
Oddometer: 247
jmemmert.
yea you can do that but my problem is, I have one spring shorter than the other. My bike sat in a storage unit for a long time. I assume this is why my kickstand side front spring is a 1/4 shorter than the other. Just a guess. It sure makes it self know when cornering. A left hander is way more unstable than a right hander. Just doesnt feel planted at all. I hope a set of new springs will do the trick
Hayden
Times are GMT -7.   It's 09:51 PM.
