Old 02-09-2013, 05:50 PM   #2671
Knobster
Knobster's Avatar
Oddometer: 53
Your very fortunate to start with a clean, well taken care of bike. Hard to tell from the video, but the can seems pretty quite...which is not a bad thing.
Cheers,
Tom.
94' KLX650-C, 09' Tiger 1050, 74' R90/6, 73' GT550 project
ABC # 5618
Knobster is offline   Reply With Quote
Old 02-10-2013, 04:10 AM   #2672
Jura
Oddometer: 16
Cheers,
Tom.
not everything is as it seems
Uploaded with ImageShack.us
Jura is offline   Reply With Quote
Old 02-11-2013, 01:22 AM   #2673
Myway
Myway's Avatar
Oddometer: 3,202
And your spring was missing on the KACR?
Myway is offline   Reply With Quote
Old 02-13-2013, 01:05 AM   #2674
Ash-125
Oddometer: 20
hey guys, ive come to the desicion of selling the old KLX to a more desiring owner, the green machine is just too heavy for what i want to do and i hate to see it rot in the corner of the shed, if any of you blokes live in Australia and are lookin for a new project or a spare parts bike, give us a message, will upload pictures in the next fewdays
Ash-125 is offline   Reply With Quote
Old 02-17-2013, 12:20 PM   #2675
Jura
Oddometer: 16
Old 02-19-2013, 01:23 PM   #2676
Myway
Myway's Avatar
Oddometer: 3,202
http://www.flickr.com/photos/fridoni...n/photostream/
Old 03-06-2013, 06:04 PM   #2677
Knobster
Knobster's Avatar
Oddometer: 53
Yo Jura?
So?... How goes it with your build?
ABC # 5618
Old 03-06-2013, 08:18 PM   #2678
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
KLX650C engine rebuild happening
Hi guys, sending the link to my page where I am rebuilding my KLX650C engine.
http://advrider.com/forums/showthrea...850765&page=12
Cheers Fogo...
Fogo72 is offline   Reply With Quote
Old 03-10-2013, 06:35 PM   #2679
Matified
been there done that
Oddometer: 108
Matified an updated mx fender
I purchased a few updated Maier MX style rear fenders to put on the KLXs,, the fender as delivered were for a 300, I ended up cutting two inches off the rear of the subframe and then made a few cuts to the front of the fender to move it forward a little bit, about an inch, this brings the part of the fender designed for the rear of the 300 seat closer to the rear of the 650 seat, not sure but I suspect the 300 seat is just a little longer at the rear. If I bolt the fender on and use the standard holes there is a gap between the seat and fender that puts it too far back and pointed to high. Just plain looks weird.
Here are a few pictures of the 93 and 96 to compare, I also did the conversion to the 96 shortly after. I think it look pretty good and adds a better tail light.
Matified is offline   Reply With Quote
Old 03-20-2013, 01:58 PM   #2680
Matje
Matje
Matje's Avatar
Oddometer: 72
To whom it may concern (Fogo?):
On Ebay.de a new Wossner piston for sale:
(not mine; stumbled upon it)
Text:
Verkaufe hier einen Wössner Hochleistungskolben für eine Kawasaki Klx 650 R. Der Artikel ist neu und Orginalverpackt.
Rings: 1000 XSY - Durchmesser: 99.92mm
Pin: WP023 - Clip: Cw 24
Clearance: 0.08mm
Job: # 17099-17 / 18048
Matje is offline   Reply With Quote
Old 03-24-2013, 08:16 AM   #2681
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,272
KLX Rack on a KDX?
I have a 2003 KDX that needs a tail rack. I was told that the KLX650 rack can fit the KDX based on having similar frames. Is this true?
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo is offline   Reply With Quote
Old 03-24-2013, 10:45 AM   #2682
Knobster
Knobster's Avatar
Oddometer: 53
The rack from a C-model is what might work. I just looked at a 03' kdx200 frame on flea-bay and the rear cross brace is not threaded. The rack on my 94' C threads into the cross brace and two threaded tabs forward on the frame.
Hope this helps.
Cheer's,
Tom.
ABC # 5618
Old 03-24-2013, 11:13 AM   #2683
Knobster
Knobster's Avatar
Oddometer: 53
Manual on Flea-bay
This is NOT mine. I just thought somebody might need one.
Search;
Item number
150978121525
ABC # 5618
Old 03-25-2013, 04:06 AM   #2684
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,558
My bike fired into life today no probs. Bit slow winding over with no KACR and high compression.
Sounds cranky.
Old 04-12-2013, 03:14 PM   #2685
MasterMarine
Oddometer: 1,618
I have a hole in my Acerbis tank. I did the dual sport ride at the Desert 100 in Odessa, WA last weekend and near the end of the ride I noticed a smell of gas. After looking around a bit, I found there is a tiny tear in the tank where the left side wing meets up with the larger main part of the tank. Bummer! It looks like it was caused by the tank flexing over time.
Here are some pictures.
MasterMarine is offline   Reply With Quote
Times are GMT -7.   It's 11:01 PM.
