Old 02-16-2010, 11:15 AM   #886
Ridin'nFishin
Oddometer: 486
Originally Posted by je2000
I've got a DRZ400 shock and new hypercoil spring waiting to be put in. I'm worried about how low I'll sit so I'm trying to research getting a shorter link installed to raise things back up to normal.
Go ahead and install the shock, it will be just fine.
I just finished installing the same shock on mine and it is perfect.
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin screwed with this post 02-16-2010 at 04:32 PM
Ridin'nFishin is offline   Reply With Quote
Old 02-16-2010, 12:15 PM   #887
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,825
No...if it's been sitting a few days then I will drain it before I even bother trying to start her up. I am usually so glad to be back home and parked and too tired to mess around draining the carb. I don't know what's up with this but it's not unique to this bike. KLX250s owners report the same thing.
Mine flooded pretty quick, within 10 minutes of stopping. The seal in the petcock was tore and the dealer said no longer available after 10 years. Where are you draining it at? From the bowl?
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
http://www.rollthebonesrally.com/
ghostrider1964 is offline   Reply With Quote
Old 02-16-2010, 04:16 PM   #888
je2000
je2000's Avatar
Oddometer: 67
Hmm, I think it's possible a KLX300 kit works. Pretty sure that's what was installed in my bike just before I bought it. Check RonAyers and part #'s and their reverse lookup. I'm at work right now, I'll check out availability and price of the 300 kit and post up later tonight.
10 years is not that old. You can order tons of stuff for really old bikes. If you're sitting on the bike, on the right side is a allen wrench hole with a hose off the bottom. Turn that a bit and the gas will drain out the bottom by the shock.
"wind tunnel cat is watching you reduce drag...."
je2000 is offline   Reply With Quote
Old 02-16-2010, 07:28 PM   #889
ghostrider1964
Edumacated Red Neck
Oddometer: 6,825
Reckon this is Green friendly fuel
Old 02-17-2010, 07:51 AM   #890
Myway
Myway's Avatar
Oddometer: 3,103
hi, it is a 4 stroke not a 2 stroke with mixed fuel.
for a c
cvk40
http://www.gadgetjq.com/keihin_carb.htm
Myway is offline   Reply With Quote
Old 02-17-2010, 07:58 AM   #891
ghostrider1964
Edumacated Red Neck
Oddometer: 6,825
for a c
cvk40
It almost looked like a mix, but it had a layer of water sitting in it too. All the brass jets and seats were all corroded green
Old 02-17-2010, 09:47 AM   #892
Myway
Myway's Avatar
Oddometer: 3,103
too tired to mess around draining the carb. I don't know what's up with this but it's not unique to this bike. .
just let the bike run one minut, while you rest sitting ont the bike with a closed petcock.
tyre michelin t63
Old 02-17-2010, 10:00 AM   #893
ghostrider1964
Edumacated Red Neck
Oddometer: 6,825
tyre michelin t63
Where is the closed position??? Mine has On, Res, and PRI....Fuel flows as long as bike is running Tried all 3 positions and bike did not die
Old 02-17-2010, 10:57 AM   #894
VStromNC
DNS/DNF
VStromNC's Avatar
Oddometer: 848
WTF Local dealer told me he cannot get the parts for the KLX petcock
You drain the carb everytime you ride?
You might want to search ebay as you can still get tons of parts for the KLX 650.
Here is one vendor with a petcock kit.
http://cgi.ebay.com/ebaymotors/FUEL-...item439d28c09c
Your dealer is full of BS as my local dealer is still able to order parts although it takes him about a week or two since he told me that it comes from japan. Recently, I broke my taillight lens when some idiot rear ended me at a DS Rally while I pulled over to help someone. No real damage other than my tailight lens was cracked. The local Kawasaki dealer had it for me in a week.
Jon
14 TR650 (Terra)
06 DL1000K6 (Vee)
VStromNC is online now   Reply With Quote
Old 02-17-2010, 11:04 AM   #895
ghostrider1964
Edumacated Red Neck
Oddometer: 6,825
Jon
Thanks, Jon...I don't doubt it. The dealer here in Waco is not the best...they prefer you buy the new one Kept trying to sell me a KLR before I found the KLX That kit won't work, I have the Cali Petcock with the vacuum valves. I am gonna try to find replacement non California style.
Old 02-17-2010, 11:09 AM   #896
Myway
Myway's Avatar
Oddometer: 3,103
my fuel tap on my bike says
down is ON
left horizontal is OFF ( no fuel to cab)( arrow to the left)
up is res reserve
there is no mention of a PRI standing
also in th MOM motorcycle owners manual
2.0 l as reserve 0.53 US gallon
perhaps you have a (CA) model California.
there are two kinds of fuel taps on the C.
CA model have 4 points to connect the tubes to.
others 3, two from the tank and one to the carb.
sound like the fueltap is not working correct.
Myway screwed with this post 02-17-2010 at 11:15 AM
Old 02-17-2010, 11:58 AM   #897
freewheeler
Oddometer: 110
The petcock is vacuume operated ... meaning if the engine is running ... the fuel will flow in all positions ... when the engine is not running ... on and res positions will not flow fuel ... pri ... by passes the diaphram ... and will allow fuel to flow with the engine not running
freewheeler is offline   Reply With Quote
Old 02-17-2010, 12:27 PM   #898
VStromNC
DNS/DNF
VStromNC's Avatar
Oddometer: 848
My 95 KLX650C3 is non CA model and it also has the vacuum petcock. Unless yours is different, I think they are all operated off vacuum in on and reserve position with prime position just opening the valve w/o vacuum or with motor off.
Good luck.
Jon
14 TR650 (Terra)
06 DL1000K6 (Vee)
Old 02-17-2010, 12:49 PM   #899
ghostrider1964
Edumacated Red Neck
Oddometer: 6,825
Good luck.
Jon
In the ON position, my bike would leave a puddle of gas on the ground within a couple of minutes The rubber for the valve itself has a tear which I think is allowing the gas to free flow.
Old 02-19-2010, 06:49 AM   #900
xkaspars
Oddometer: 3
Hi. Have any of you have tried to install the rear shock from the Husqvarna 610 to the KLX 650?
xkaspars is offline   Reply With Quote
Times are GMT -7.   It's 03:49 AM.
