Old 08-21-2006, 09:05 AM   #1
Andrek OP
Oddometer: 2
Engine overheating slow moving
Hi, r1200gs 2006, 700km still running it in, my first BMW motorcycle.
Traveling home I got stuck in heavy traffic, the motor overheated and low oil pressure indicator. After leaving the motorway and picking up some speed again all return to normal.
Now my question: is this normal for the GS to overheat when standing still or slow moving in heavy traffic, is this because of the air cooled motor?
Thank, Andre
Andrek is offline   Reply With Quote
Old 08-21-2006, 09:22 AM   #2
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,053
Send a message via Skype™ to walrond
Thank, Andre
It is normal. Just learn the fine art of filtering, then explain to the police that due to the fact you have a air cooled bike, you must do this. If you can't filter then pull over and let it cool down and join traffic again. It doesn't take all that long for it to cool down. If your low oil pressure light is coming on you might want to consider a thicker viscosity oil to help maintain oil pressure.
Save $5 when you open a SmugMug account. Use the following coupon: 7ztkgApOHBurY
walrond is offline   Reply With Quote
Old 08-21-2006, 10:41 AM   #3
bobcopro
Oddometer: 228
I have never had my 1200GS overheat, even in standing Boston Traffic at 98 degrees (I overheated though!) I have also never had my oil warning light come on. Your bike is both air and oil cooled. These things consume vast quantities of oil when they're new. Make sure you check your oil level very frequently as you can't cool the engine oil if it doesn't have any. If it happened again, I would have the dealer make sure your oil cooler under the headlight is not blocked in any way.
05 1200GS with everything I can buy or build for it, ridden in places it was never meant to go!
bobcopro is offline   Reply With Quote
Old 08-21-2006, 10:54 AM   #4
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 2,690
I have had my R1200GS in stop and go traffic in over 100 degree temperatures and the temp guage never got higher than its normal (about 1/3 of the way up) reading.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 08-21-2006, 10:54 AM   #5
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,494
Same here. Very hot days, and an hour of standing traffic, and my 12GS has not gone past 3/4 high. Just 2 bars up from normal.
Jim
Old 08-21-2006, 10:55 AM   #6
rideLD
The further the better!
rideLD's Avatar
Oddometer: 5,252
I'm not so sure if that is normal for the new 1200. Many have reported the 11xx's over heating but I have yet to read one report of a 1200 over heating. Myself personally I have ridden my bike through Kansas City in 110 degree heat. The traffic was stop and go for over 50 miles and it took 3 hours to cover that distance. My RID never even moved from the normal heat measurement.
Karl
2007 BMW R1200GS Adventure
2009 BMW G450x
IBA 9231
http://karlmarsh.smugmug.com
Smugmug rules! Use this coupon to get $5 off your own Smugmug account T3cUNv3ktrGFQ
rideLD is offline   Reply With Quote
Old 08-21-2006, 10:55 AM   #7
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,148
I have to agree with bobcopro on this one. It is NOT normal for a 1200GS to overheat. Even in the hottest weather and slowest traffic, I have never seen my temp guage go more than half way up. Get the bike to your dealer and have it checked out.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 08-21-2006, 11:19 AM   #8
walrond
Earth Wanderer
walrond's Avatar
Oddometer: 1,053
I should have read his post better, but it was kind of hard since the lettering was in black. Since I have a 1150 GS I assumed he had one to. (Being the better model and all that).
Old 08-21-2006, 11:26 AM   #9
Happnin
Happnin's Avatar
Oddometer: 169
If it *ucks, flies, or floats...rent it!
--my dad
Happnin is offline   Reply With Quote
Old 08-21-2006, 11:27 AM   #10
srosa
Oddometer: 178
I'll chime in and concur that this is not normal for an R1200GS. I really had to watch this with my old 1100's but my 1200 seems to run much cooler for some reason. I also found with my 1100's that any movement, even 5-10 MPH helped to avoid overheating.
srosa is offline   Reply With Quote
Old 09-26-2009, 09:02 PM   #11
dc1
Oddometer: 21
Send a message via Skype™ to dc1
overheating GS 1150
Lets hear some REAL answers from the "proffessionals" and save a bike and calm down a rider
dc1 is offline   Reply With Quote
Old 06-20-2010, 07:07 AM   #12
TK421
Rehab is the new black
TK421's Avatar
Oddometer: 46
Question
I was stuck on I-80 (stop and go traffic for about 1/2 hour) in 80 degree heat and riding thru NYC in same temps. Temp indicator started climbing ('08 R12GS) but never got into the "red" (past the little hash mark near the top) - normally at 4 bars but went to 5 for much of the ride then up to 7 as I got lost in Manhattan. Crossing the the Brooklyn Bridge brought the temp down a bit. Does this sound normal? I usually ride where I am free of traffic and my commute is only 10 miles or so. Taking the bike on a long tour of EU - Am I just being paranoid or is my bike telling me something?
TK421 is offline   Reply With Quote
Old 06-20-2010, 08:41 AM   #13
Crilly
Oddometer: 596
I would think they have a thermostat in the oil system.
Crilly is online now   Reply With Quote
Old 06-20-2010, 09:02 AM   #14
GeorgeinVA
Beemers Uber Alles
GeorgeinVA's Avatar
Oddometer: 603
I'll give it a try. Not normal but not unheard of. I had an R12GS land on my bench that would over heat anytime the temps were above 85f. The motor was a golden brown. The customer stated the bike had always run hot. I too thought the thermostat might have been bad or improperly installed. When I removed the thermostat it was dry . Looking further the oil cooler was dry also. As it turns out BMW did not drill an oil passage in the block for the oil to go to the cooler. Since the bike was still in warranty (35500 miles on it) we ordered a new short block.
To check you thermostat get a digital laser temp probe and read the oil cooler lines when the bike hits "normal" operating temp the lines should begin to warm. If they stay only a few deg above ambient temp. you have found your problem.
Hope this helps.
Beemers Uber Alles
9248 Mike Garcia Drive
Manassas Va 20109
(571) 318 2472
Indie BMW Maintenance
www.beemersuberalles.com
GeorgeinVA is offline   Reply With Quote
Old 06-20-2010, 02:24 PM   #15
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,135
Send a message via Skype™ to tagesk
Thumb
Hope this helps.
Or, if your fingers aren't completely severed from your sensory system: Touch it with your hand.
If should be hot as in "ooops". It will not be hot as in "funny smell - is that black thing my hand?".
I don't know on the 12GS, but on the 1150 (best model and all that) the oil starts to flow at three or four bars.
How hot the oil is? That is, in fact, a rather frequently asked question. And, luckily, you will find the
answer in the "GSpot FAQ".
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Times are GMT -7.   It's 06:08 AM.
