Old 04-06-2011, 04:28 AM   #391
ItchyBob
ItchyBob's Avatar
Oddometer: 7
Originally Posted by Squid Division View Post
Mine was covered by warranty so I just took it in and had it fixed during normal service.
Same
I heard a rumor that your dad plays catcher.
ItchyBob is offline   Reply With Quote
Old 04-06-2011, 04:42 AM   #392
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,764
I'm not sure if I'm still under warranty (bike is an '09 that was bought "used" with 276 miles on it, don't know what original sell date was) and the dealer (the one I trust anyway) is 70 miles away.
Anyone fixed it themselves (or know what the dealer did to fix it)?
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 04-06-2011, 10:14 AM   #393
SomethingClever
sick life
SomethingClever's Avatar
Oddometer: 182
I've never seen a shed built this way. How did you come by the idea?
Basically... I had plans for a much grander garage that a structural engineer friend was going to help me build... and then I lost my job.
But I had already purchased some of the materials... so I figured I'd at least put a simple, temporary structure up for the bike in the meantime.
I got it all put together and people were like, "you should put sides on it!" And then I remembered I had some spare windows just sitting around in the basement. So I just added on. Here's how it looks now... still not quite done. There's a matching door to be installed... more trim around the other corners... and I need to add some siding above the door and paint everything.
SomethingClever is offline   Reply With Quote
Old 04-06-2011, 02:18 PM   #394
bross
Where we riding to?
bross's Avatar
Oddometer: 4,623
Jodie's was weeping so I just pulled the cam cover, cleaned both surfaces well with clean rags and brake cleaner, and applied a thin, very thin bead of RTV to the gasket and bolted it back on. Was oil tight ever since. Very easy and simple to fix yourself.
Old 04-06-2011, 02:21 PM   #395
bross
Where we riding to?
bross's Avatar
Oddometer: 4,623
Originally Posted by SomethingClever View Post
It is just sitting in the blocks, but it's also somewhat shielded from great gusts of wind as it's between two massive trees and just a few feet from a fence on the right.
I have also picked up two solid wood 40" wide doors that I'm going to mount on either front post -- they must weigh 100 lbs each.
It may not be hurricane proof, but I live in the PNW and it should be sufficient to withstand the kind of weather we get here.
You weren't hit by the winds in 2006?
http://en.wikipedia.org/wiki/Hanukka..._storm_of_2006
Old 04-07-2011, 01:44 PM   #396
hankmarx
hankmarx's Avatar
Oddometer: 81
Austin to the Salt Flats.
hankmarx is offline   Reply With Quote
Old 04-08-2011, 10:18 AM   #397
SomethingClever
sick life
Oddometer: 182
Weird, I don't remember any wind storm being that big of a deal in 2006.
I dunno. I just don't think the wind will be able to hit this shelter at the right kind of angle to generate lift once I'm done. It will be closed from all sides, and there isn't much overhang from the roof, so there's the wind can't get underneath and lift up. And the roof is just thin galvanized metal anyway -- I think it would likely rip off before it could lift the entire structure.
Plus, I don't know how I'd go about securing it to the ground. Pouring a foundation was/is out of the question. Got any other suggestions?
Old 04-08-2011, 10:19 PM   #398
DJGypsy
Ewok Taxidermist
DJGypsy's Avatar
Oddometer: 466
let's see how much hate i get for my DIY flyscreen...
-Dan
it's not the destination, it's the journey
http://i29.photobucket.com/albums/c2...3012175630.jpg
DJGypsy is offline   Reply With Quote
Old 04-08-2011, 11:01 PM   #399
Squid Division
17th Mounted Squids
Squid Division's Avatar
Oddometer: 42
I actually kind of like it. What is it made out of?
Squid Division is offline   Reply With Quote
Old 04-09-2011, 06:51 AM   #400
DJGypsy
Ewok Taxidermist
DJGypsy's Avatar
Oddometer: 466
22 ga sheetmetal from home depot. used a dremel to cut, 2x4 and a brick to make the bends straight, spray-on truck bed liner for the black portion, plain silver spray paint for the silver section
-Dan
Old 04-09-2011, 10:07 AM   #401
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,386
Hammer some beefy long metal stakes into the ground on both sides of the bottom footer at each corner next to the foot blocks. Drill a small hole through your siding aligned with each stake, just over the footer. Pass a piece of wire or wire rope or something through the hole and secure it to each stake in all four locations -- essentially you are just tying it to the ground.
Stakes should be at least 2-3 feet into the ground so you'll need a sledge to drive them. You could use re-bar and drive it at an angle (angled under the shed from both sides of the footer) so that what shows of the rebar above the ground will be angled away from the structure and suitable to tie a cable, wire or strap around.
Wouldn't want your pretty bike to get killed by a falling shed
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is online now   Reply With Quote
Old 04-12-2011, 05:18 AM   #402
Blue~Steel
Ride Free
Blue~Steel's Avatar
Oddometer: 2
bump!
Blue~Steel is offline   Reply With Quote
Old 04-12-2011, 05:37 AM   #403
teachnsurf
Bonnie Adventurer
teachnsurf's Avatar
Oddometer: 254
Pov
This is my Bonneville. There are many like it, but this one is mine. My Bonneville is my best friend. It is my life. I must master it as I must master my life. My Bonneville, without me, is useless. Without my Bonneville, I am useless. I must ride my Bonneville true. I must ride faster than my enemy who is trying to beat me. I must beat him before he beats me. I will.
1st Epic Journey
teachnsurf is offline   Reply With Quote
Old 04-12-2011, 03:42 PM   #404
Senor Siesta
Accipere Via Longa
Senor Siesta's Avatar
Oddometer: 165
I was able to stop mine by pulling and cleaning the gasket, replacing the o-rings, cleaning the channel and mating surface, and making sure the torque was correct.
From Parts Outside,
Nick
2007 990 ADV
2005 Bonneville
Senor Siesta is offline   Reply With Quote
Old 04-12-2011, 04:37 PM   #405
DCamm94
Oddometer: 7
Dude, if you can round up the scratch, you should totally put a treated deck in that bad boy and a cheap metal rollup door. You could either pour a ramp or just get a cheap ramp to get up the 4" to the floor height. That way, at least when it rains, you wouldn't be standing in water, AND you could work on your bike when it's raining. Great setup. I've actually got a pad on the back of my garage that's not used for anything except parking my 97 wrangler, and I'd love to have a similar setup for my bike rather than have to share space with the other half for the car. some 5/8" decking in that bad boy would be AWESOME. Looks good in any event. Nice work.
Deck
DCamm94 is offline   Reply With Quote
Times are GMT -7.   It's 06:08 AM.
