09-14-2006, 03:59 PM
#151 | |
09-14-2006, 07:03 PM
#152 |
Oddometer: 2,761
OK...all you guys who have drilled out the slider in the carb to 7/64ths and put the 2 shims under your needle.....what did it do to your miles per gallon rating???? and was it worth it?? Also did you mod the airbox too???
I am very interested in doing this mod but don't want to kill my mileage to the point that I have to stop at everyother gas station!! lol Can someone please chime in and help a newbie out? thanks!! |
09-14-2006, 07:17 PM
#153 |
Oddometer: 155
Yeah, I read the info about the Cycle Burro, wish they were still made. I need to fab a hitch for my KLR.
09-14-2006, 10:44 PM
#154 | |
Tazmanian devil
Oddometer: 69
the most important thing you can do is open the pilot screw. start somewhere between 1.75 and 2.0 turns out from fully seated. these simple mods will take care of any surging and lean spots in the power band. good luck.
Steve 00 KLR 650 97 Connie 02 Vstrom 1000 PTB, KTF, FTM |
09-15-2006, 04:52 AM
#155 |
CARIBBEANKLR
Oddometer: 1
Klr650 Raising Links
Hello, I'm tryng to get Raising Links for My Toy, I'm 6'2 and 240 pounds, I really need raise my Klr. May you help me with information about where to buy that links? Thanks, Robert Emeric (Caribbeanklr)
09-15-2006, 05:00 AM
#156 |
Obedient Consumer
I did just about everything I could to mine, except for that badass supermoto setup (holy crap that was bad ass!); Big Gun Exhaust, K&N, DynoJet, heated grips, and half of everything Dual-Star peddles; when I finally threw in the towel. Sold the '03 with 22,000 miles on it for $2475 on ebay.
I think I recouped only my upgrade investment. But back to the topic: Of all the crap I tweaked on the bike, the best ones were the cheapest: -TWC fuse box relocator -TWC fused outlet add-on (I am farkle-boy) -Mounting the license plate higher -Running a larger fuse for the headlights I'm on an Uglysses now, and I'm frickin' lovin' it, but the KLR was my first, and she rocked. She went to a good home. Carribeanklr: You want to RAISE it? Who do you think you are, Andre the Giant?
I'll quit before I fail. Scotty J screwed with this post 09-15-2006 at 05:06 AM |
09-15-2006, 05:23 AM
#157 | |
Go to KLR...then Suspension...you'll find them about halfway down the page. |
09-17-2006, 10:38 AM
#158 |
Tim
Oddometer: 279
Mods
Sorry to change tyhe subject, but, does anyone know where to find the small (1-2 liter) gas cans that the guys put on there bikes.
Tim Firefighter/EMT If you can read this, thank a TEACHER. If you're reading this in ENGLISH, thank a SOLDIER. God Bless us all. 88 NX 125, 99 Valkyrie, 02 KLR Pulling my homebuilt monowheel
09-17-2006, 06:00 PM
#159 | |
Girivek
D606's
"There is no vice more painful than that of luxurious habits" |
09-17-2006, 09:05 PM
#160 | |
Oddometer: 155
09-17-2006, 09:23 PM
#161 |
Oddometer: 834
Additions (not all shown).
Doohickey & spring Fuse relocator kits (blade type) Engine/Nerf Bars Heated grips Corbin seat (Red snake skin) Progressive springs SS brake line Fork brace Bar risers Bark-Busters w/guards High output headlight harness LED tail light GIVI hard bags (E-21) Aluminum skid plate & master cyl. guard Center stand Sub-frame bolt upgrade Tool tubes T-Mod Acc plug (for compressor) Clutch switch & side-stand bypass switches Monster tubes Tail box ![]() ![]() ![]() -T |
09-17-2006, 09:25 PM
#162 |
Tim
Oddometer: 279
Gas can
No, I've seen these on the back of aluminum panniers. There is a small shelf bracket and the can sits on it and the can is strapped to it with a velcro strap.
09-18-2006, 02:01 AM
#163 |
Retired, baby!
Oddometer: 1,425
My mods:
BigCee Drill-through subframe upgrade BigCee shark fin Eagle Mike's Doohickey and spring Thumb-adjustable pilot screw IMS footpegs Dual-Star (DS) shifter DS rad guard and water pump guard DS safety oil cap DS heavy duty rear brake lever bracket Rear master cylinder protector Moose bash plate Twin-Air filter Low profile magnetic oil drain plug Swingarm and Uni-Trak lube job Double sealed bearing in both wheels/hub Galfer green/black brake pads Stainless muffler heat shield Speed bleeders Carb T-mod Heavy 550# rear shock spring 1 1/2" lowering links (because there is very little sag) Corbin flat seat (I still use the OEM seat for trail riding) Tall windshield Odyssey PC545 gel battery, wiring mods Totally Wired Cycles (TWC) headlight harness TWC clutch/sidestand override kit TWC fuse upgrade kit Power line to relay-controlled fusebox behind faring, powering: Grip heaters, dual (cigarette and Powerlet) power outlets Other wiring for heated jacket, battery charger, Chatterbox, etc LED tail/brake light replacement LED light bar added Light/horn/signal control unit with highbeam flash, push-to-cancel, headlight kill Left mirror relocation bracket Relocated choke lever Handlebar risers Renthal aluminum handlebars, gel grips Throttle lock Maier Deluxe Woods Pro handguards and farings Duchin dashboard LED tri-color voltage monitor light Clear stick-on headlight protector (added first) Wire headlight protector (added much later) Progressive fork springs Braided steel front brake line Cut rear inner fender away, relocated license plate Happy-Trail (HT) highway bars HT nerf bars HT SU luggage racks Larger heavy-duty rear luggage deck Lots of various mirrors tried and broken Different turn signals tried and broken (I'm rough on the bike) Ram-Mounts for GPS, etc Various luggage options available Currently running extra heavy-duty inner tubes, D606 tires Modified mounting for the side shrouds 1" access holes for seat bolts, headlight adjust bolt (covered with 1" plastic plugs) Side panniers always mounted (they are DS tank panniers, but I strung them under the seat) Prevailing torque nut on the countershaft sprocket Lots of other small things added or changed Happy with most everything I've done to the beast. Some things weren't as useful as I had hoped, but few regrets. When I'm ready to rebuid a new KLR for RTW travel, I'll know what works and what I need. Cheers!
Did Prudhoe Bay to Ushuaia in 2008-2009! http://www.errant-ronin.com/PrudhoeBayUshuaia.htm COHVCO #6391 AMA #2800236 SgtMarty screwed with this post 09-18-2006 at 06:15 PM |
09-18-2006, 07:54 AM
#164 | |
Short, fat, bearded, slow
Oddometer: 23,807
09-19-2006, 05:02 PM
#165 | |
Girivek
