Old 01-02-2012, 03:37 PM   #1651
BigT
Oddometer: 887
Originally Posted by Dblarrow View Post
And along those lines, any comparisons to something like the +4 windshields or bigger?.
Windshield heights are dependent on your height, the helmet you wear and tilt of the screen. Everyone has a different experience with them.
I'm 6'4" and I hated the +4 on the stock fairing as it caused terrible turbulence in my helmet. The noise was a maddening, tumbling, low-pitched rumble that was totally unacceptable.
Originally Posted by IDRIDR View Post
Where is a good post or thread for this wheatwhacker mod? I just looked up a bunch of pics with a wide variance in changed angle. Is there a "best" angle change? Thanks.
Are you a member of klr six fifty dot net? If so, do a search for "The Wheat Wacker Wedge fairing mod".
Getting the right angle is a personal choice and depends on the things I listed above in my reply to Dblarrow's question.
Originally Posted by dmottv View Post
I use a RAM medium length arm to raise the gps off the bars:
I'm working on an aluminum mount that will put the GPS about 5 or 6 inched higher than what you have pictured, yet still place it behind the (taller) screen.
Right now my RAM mount is attached to my brake reservoir and has a 4" arm that "perfectly" places the unit in front of my speedo and a few of my idiot lights.
BigT screwed with this post 01-02-2012 at 04:38 PM
BigT is offline   Reply With Quote
Old 01-03-2012, 08:48 AM   #1652
Dblarrow
Dblarrow's Avatar
Oddometer: 113
Understand all that - not asking how it would work for me.
What I am interested in would be something like - I did the 4" + and had buffeting that I could not stand, then I tried this and it was wonderful or it sucked or not much difference than the stock.
2006 KLR 650
1989 KLR 250 With a 330 big bore by CWR (WOW!!)
"Not by might nor by power, but by My spirit" says the LORD.
Dblarrow is offline   Reply With Quote
Old 01-03-2012, 12:56 PM   #1653
BigT
Oddometer: 887
You got it.
http://www.klr650.net/forums/showthread.php?t=14480
Old 01-03-2012, 01:55 PM   #1654
Dblarrow
Dblarrow's Avatar
Oddometer: 113
Thanks, that's not you by chance?
2006 KLR 650
Old 01-03-2012, 01:59 PM   #1655
BigT
Oddometer: 887
I didn't create the thread, but I'm in there. (Timbo)
Old 01-03-2012, 04:11 PM   #1656
Hillbillyburg
n00b forever
Hillbillyburg's Avatar
Oddometer: 40
Hi all
Just getting to know who's here.
I have a 2010 bodied 09 KLR with the following mods:
Thing already done
Engine sent to M-Tech in Oregon for a Schnitz racing 705 big bore kit with Stage II head and over-sized stainless steel valves.
Staintune exhaust and header pipe
Done the EM DOO
Wynman Winn A.I.S cover and plug
Schnitz racing carb dress up kit
Ebay Low profile magnetic oil drain plug
Aluminum choke retainer
new inner and outer gaskets
Drilled the slide
KLX needle
Jet kit
new rotor bolt
Fuel air mixture T screw
Mercedes Benz PVC Valve modification
Iridium sparkplug
Sway bar and rear suspension drilled for grease fittings, bearings re-greased and re assembled
Steering bearings greased and re torqued to proper spec
Kick stand safety taken off
Clutch safety taken off
Progressive front springs
Ricor Itiminators, Amsoil 5w oil and taller spacers.
Eibach 500 9 kg racing spring over stock rear shock
Eagle mike fork brace
Gaffer stainless steel brake lines front and rear
CBR 600 RR Front master cylinder
DOT 5 racing brake fluid, the kind that doesn't ruin paint
Rear master cylinder forged aluminum bracket
rear master cylinder guard
SW Motech engine guards
JNS engineering Skid plate
JNS rad guard
Eagle Mike sub frame bolt kit
Pro taper Contour High bend ATV 1 1/8 big bar handle bar
Roxx *anti vibration pivoting 2 "risers
Oberon clamp oblong bar end mirrors
Tusk hand guards with plastic covers, with a lot of custom work to fit
KLR Dash with Zero Gravity sport touring windshield on risers
Odyssey AGM battery with terminal kit
Electrical connection LED Voltage meter kit
Split loomed the harness and super glued any wire that could touch or rub up against anything!!!
Self cancelling turn signals with 4 way flashers.
RK EW 520 racing chain GOLD
16 tooth Sunstar front sprocket 35916
Scottoiler E- system chain oiler.
Stainless steel KLR 650 nut and bolt kit and engine kit as well
Newly upholstered seat with double bucket and memory foam
Oxford heated grips
JNS foot extension, cut down kick stand by 1/2"
Kaoke cruise control
Moose racing Onynx stainless steel foot pegs with return springs
Polisport front fender
IMS flight line shifter
Highway pegs for the engine guards
Stebel air horn 139 dbs
Uni air filter
6 circuit switchable blade fuse block with negative bus
Custom Dynamics black LED rear license plate mounted on rear fender with bullet connectors.
2 Piaa 1500 XT fogs on a custom mount attached to the skid plate.
Storm SW Motech crash bar Cordura storage bags
Trek bicycle analog clock with a 1 1/8 clip-on band
LED flashing brake light
Bought trailer, just need to fab a hitch up.
Left to doo
320 EBC front rotor with caliper relocation bracket
Eikel or Sunrise rims 19" up front when I trash the stock rubber (low end of priority)
Tubliss inner bladders, maybe
New rubber, maybe Mefo or K60's
LED turn signals
HID Headlamps
Vision X Reflex 12" 10Watt LED strip lamp with a 10 degree pattern for under the fairing
Nav system
Luggage
Packrat rack
Yeah.......that's about it for now I guess. Kinda cool being called a n00b again.
Hillbillyburg screwed with this post 01-03-2012 at 04:15 PM Reason: ARRGH tried to make picture bigger. LOL
Hillbillyburg is offline   Reply With Quote
Old 01-03-2012, 04:48 PM   #1657
2whlrider
2whlrider's Avatar
Oddometer: 925
WOW!!! That's alot of farkling!
How do you find the 705 mod. compared to stock?
On two wheels....That's my Happy Place!
2whlrider is offline   Reply With Quote
Old 01-03-2012, 09:28 PM   #1658
Hillbillyburg
n00b forever
Oddometer: 40
Stock?........What's stock?????
Most if not all of these mods were done on a bike with 1.5 kms on it.
I bought my ride home in a blizzard in January. The motor was dissasembled by Willys the next day and shipped off to M-Tech. I seriously never rode my bike stock. It's a long story but I wanted to like this bike a lot, and decided to make this bike into something that I would want to ride all the time, not to sell it after a summer because of the vibration, electrical problems, bits and pieces falling off, etc etc. The KLR isn't perfect and we all know that, so I fixed a few things. and that led to fixing a few more things.
Luckily I have a very forgiving wife who has difficulty with math, or I'd be ........
Old 01-03-2012, 09:28 PM   #1659
Dblarrow
Dblarrow's Avatar
Oddometer: 113
Kinda what I was hoping for - so when you run around with the WheatWacker you'll let us know how it compares to the other and if it accomplishes what you want?
2006 KLR 650
Old 01-03-2012, 09:41 PM   #1660
BigT
Oddometer: 887
I already have the WheatWhacker mod on my bike and don't really like it much. I've also heard from another board member who combined the WW mod with the +4 screen who said it sucked.
I'm not sure what I'm going to try now, but I'll post my results regardless.
Old 01-04-2012, 08:05 AM   #1661
2whlrider
2whlrider's Avatar
Oddometer: 925
So, how is the 705? Power? Vibs? Problems?
Old 01-04-2012, 08:34 AM   #1662
willys
willys's Avatar
Oddometer: 2,904
Hillbillyberg
Hey buddy.....good to see you here finally!
I think you have one of the longest farkle lists, glad to know I'm not the only lunatic around....lol
See you at the show......bring cash!!!
He has one of the nicest KLRs I would say in North America.....and it works very well!
willys is offline   Reply With Quote
Old 01-04-2012, 08:42 AM   #1663
Kawidad
Kawidad's Avatar
Oddometer: 4,808
I am in awe of your mods.
It would seem that you set it up for long distances on the highway? If so, did you or have you considered the 17/19" wheel combo? It would seem like about the only thing you haven't done yet. If not, then what did you set it up for and how do you like the results?
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-04-2012, 09:12 AM   #1664
PacificPT
Oddometer: 982
I had to stop halfway through the list, go get a cup of coffee, then finish reading it. Impressive!
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 01-04-2012, 12:40 PM   #1665
FMFDOC
Oddometer: 624
Awesome mods...
FMFDOC is offline   Reply With Quote
Times are GMT -7.   It's 08:42 AM.
