Old 05-19-2012, 06:49 AM   #2956
Aron31
Aron31's Avatar
Oddometer: 113
Question for everyone running the happy trails pd engine guards. Recently went for an offroad excursion. Slipped a couple times in the mud and dropped it at a stand still. No speed at all. Just a step off. After the second one I seen my engine guard was pushed in pretty good and the inner bar was really bent. Just wondering if this is normal. The engine guards did their job and protected everything. So are they concidered sacrificial or what? Maybe I just assumed that they would hold up to some light drops. Here's some photos.
I took it off last night and bent it back straight again but am pretty sure another job to the left will yield similar results. Any ideas?
Aron31 is offline   Reply With Quote
Old 05-19-2012, 07:26 AM   #2957
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,168
Love the look of the PDs, but this is the reason I went with the SW Motechs ..
.. either set, though, is ultimately sacrificial as long as they protect the bike when they are in use .. lol ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill is offline   Reply With Quote
Old 05-19-2012, 07:37 AM   #2958
Aprilia
Oddometer: 791
Originally Posted by Kawidad View Post
I like what you've done. Very similar to what I've done to mine.
Can you give us more details about the carb and set up?
Also, the bog might also be cured by changing the air bleed jet. My WR400 with a newer style 450 carb had a horrible bog that I cured by putting in a bigger air jet. (The jet next to the pilot jet, in case my terminology is incorrect)
Actually, if you want additional fuel you need to go with a smaller "leak jet". Smaller the jet the less fuel gets transferred back to the carb bowl and more fuel is forced out through the pump nozzle. Leak jet is located after the nozzle. Accelerater pumps have 3 basic adjustments...amount of fuel, start of squirt and length of squirt.
Aprilia is offline   Reply With Quote
Old 05-19-2012, 09:58 AM   #2959
Aarono2
Oddometer: 76
Originally Posted by Yokomo View Post
Putting the o-ring around the AP was the original way, now the best way is to wire tie them together. Made a big difference on my 2 past pumpers.
Cool bike!
I have already done the o-ring around the AP. Though about wiring them together but its impossible. The throttle turns much further that the AP lever turns, it needs the stretch of the o-ring.
Aarono2 is offline   Reply With Quote
Old 05-19-2012, 09:59 AM   #2960
Aarono2
Oddometer: 76
Since I have an adjustable leak jet, I think messing with it will be my best bet. Hopefully I'll have some time this weekend.
Old 05-19-2012, 10:34 AM   #2961
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,341
You can also cut the stopper on the plunger so it will squirt more when it squirts.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 05-20-2012, 08:35 AM   #2962
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: NE PA Some... PNW Some... On HIGH ADVENTURE Most!
Oddometer: 1,820
Thumb
EXCELLENT set up Aaron!!!
I'm getting closer to this pumper mod
JJ
Jettn Jim screwed with this post 05-21-2012 at 12:54 AM
Jettn Jim is offline   Reply With Quote
Old 05-20-2012, 06:07 PM   #2963
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,356
Just mounted some LED lights. Wired them up temp-like to just to see them work. Need to pickup a switch tomorrow and wire them up for real..
John
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 05-20-2012, 06:24 PM   #2964
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,168
.. those the black ones off eBay?? .. put some on mine this past week and they are BRIGHT ..
.. not a ton of light out front, but they do get you noticed ..
My '06 KLR
Old 05-20-2012, 06:30 PM   #2965
scarysharkface
30-125
Oddometer: 13,356
Yep, it's those.
yBr7OofIPuOP6
Old 05-20-2012, 07:21 PM   #2966
scarysharkface
30-125
Oddometer: 13,356
Here's where I mounted them, with a large washer on the back side..
Not much throw to them, but the sure do fill-in the low-beam nicely. I'm using the Euro beam that they came with, which is a wide and flat beam.
I went for a short scoot tonight, just down the road a bit, and found it almost disconcerting being able to see for a change.
John
yBr7OofIPuOP6
Old 05-20-2012, 07:49 PM   #2967
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,168
Well dangit .. those are not the ones I got .. I like those better ..
Sent from my Kindle Fire using Tapatalk 2
My '06 KLR
Old 05-20-2012, 11:39 PM   #2968
schaffer40
I look lived in.....
schaffer40's Avatar
Oddometer: 413
Hello all,
I have an 09 and I am wondering at what point on the temp gauge will the fan will come on when it starts heating up. Mine is not overheating but it does warm up stopped in traffic. I have read posts about guys hearing the fan come on and I have not ever heard it. Just wondering.
The massive Raider Nation is beyond doubt the sleaziest and rudest and most sinister mob of thugs and wackos ever assembled. Hunter S. Thompson
Punk Rock Changed My Life- The Minutemen
schaffer40 is offline   Reply With Quote
Old 05-21-2012, 07:12 AM   #2969
Doorguy1979
Dreamridin'
Doorguy1979's Avatar
Oddometer: 627
My 08, steel skidplate, highway pegs, welding rod tube for tools, Wal-Mart driving lights, reinforced factory hand guards, custom engine guards (mount inside plastics), different front fender (KTM), raised about 1 1/2" in rear with custom dog bones, Stearns seat pad, solar battery charger, action packer top box, custom DeWalt case panniers (not pictured) 12v outlet, thermo-bob, and Eagle Mike's doohickey, probably a thousand little things I'm forgetting.
The older I get the more I realize how few people I actually need in my life.
08 KLR 650
82 Suzuki GS850
7? Sachs Moped Basket Case
Doorguy1979 is offline   Reply With Quote
Old 05-21-2012, 10:11 AM   #2970
Tsotsie
Semi-reformed Tsotsi
Oddometer: 1,952
Originally Posted by schaffer40 View Post
Hello all,
About 2/3 of the way up the white line.
Tsotsie is offline   Reply With Quote
Times are GMT -7.   It's 11:51 AM.
