05-27-2012, 10:25 AM
#3046 | |
Adventurer Ordinaire
Oddometer: 351
turns out I've got the 700's and love em whoops learn something new every day someday i may even learn to comprehend what i read
COHVCO #7369 |
05-27-2012, 10:34 AM
#3047 | |
Oximoran
"Life comes in Words... Words become Sentences... Sentences become Experiences... Experiences become Life Lessons..." |
05-27-2012, 10:40 AM
#3048 | |
Oximoran
I looked at the 700's long and hard, repeatedly convincing myself I would ride more dirt in the future and they 700's would come in handy. Alas, reality says I will continue to ride about 90/10 and need more milage out of my tires. I even bumped up the tire size from a 130/80 to a 130/90 because I read somewhere on ADVrider that the 130/90 will get me a better cruising RPM. We shall see...
05-27-2012, 10:45 AM
#3049 | |
Oddometer: 351
COHVCO #7369 |
05-27-2012, 11:24 AM
#3050 | |
Gorilla Adventurer
Oddometer: 1,951
bikes |
05-28-2012, 06:07 AM
#3051 | |
Oddometer: 3,818
"Deeply flawed people make deeply flawed decisions." |
05-28-2012, 07:00 AM
#3052 |
Oddometer: 429
Some good info here ^ Iam about due for a new rear. I have been thinking about going to a 18" rim and tire, I will try this first as I need a tire anyway.(Iam also tall-6'5"-- can you say Monkey F-in a football). Yokomo, do you know how much taller the 130/90 is over the stocker?? Thanks
05-30-2012, 07:19 PM
#3053 | |
Oddometer: 55
Now when I was putting the headlight stuff back together I got a little confused, is the rubber boot supposed to go over the end cap/plug, or does it go on, and then the plug? The boot looks like it has an area for the wires to go out the inside (implying it goes on second), but I sure couldn't get it on properly that way. I got it over the plug once, but it certainly wan't sealing. I'll have to think about the fuses, I had to replace the glass one completely since all the wires and connectors themselves were burned. I put in an ATM fuse/waterproof holder with wire nuts as at least a short term fix. |
05-31-2012, 05:20 AM
#3054 |
49 yrs on 2 wheels
Oddometer: 315
Electricity runs on smoke. How well depends on how much smoke has leaked out.
I'm not lost...it's the rest of the world that is occasionally missplaced! 2000 KLR, 2002 KLR, 1993 BMW K100LT KLR/Mikuni VM38 Report New projects: '68 Bultaco El Bandido restore and Combat Wombat |
05-31-2012, 10:02 AM
#3055 | |
Semi-reformed Tsotsi
Oddometer: 789
They will fit, BUT are not equal! The original 07 lever is a 2 part welded part and these have a history of breaking at the weld or lobe areas! The 08+ stock part is machined out of solid material and does not have a history of breaking. Both are inferior to those made by E Mike who also changed the lobe design. Are their parts from EMike? If not, there are some pirate parts that are also suspect. All stock springs are suspect, break or are too long for proper adjustment. Tsotsie screwed with this post 05-31-2012 at 10:07 AM |
05-31-2012, 11:26 AM
#3056 |
Oddometer: 18
Thanks guys - I'll make sure they're replacing everything with E Mike parts.
Next Question: Where to install the 12 V acc plug on my '08? Thanks |
06-01-2012, 01:23 AM
#3057 |
Scott
Oddometer: 784
On my '09 I put mine in the upper left fairing by to tach but in the painted portion.
Only issue is that from the viberation the plug will lose contact and stop charging. So you may want to mount it so that the plug is virtical instead of horizontal ? Just my 2cents |
06-04-2012, 07:27 AM
#3058 |
Thumper
Oddometer: 354
Thermobob installed! Wow what a difference! Not only does the engine run the way it should, it runs way more smooth and I dont feel like I am pushing the bike to its limits to run 75-80
"the other site" will have some details about my thoughts on it within the next few days.
06-04-2012, 10:17 AM
#3059 |
Thumper
Oddometer: 354
Does anyone know of a KLR radiator guard? Not that JNS thing that you add to the OEM guard...a nice all metal radiator guard.
06-04-2012, 10:21 AM
#3060 | |
DualSport Crazy !!
Oddometer: 838
"Where ever you are, there you go..." |
