Old 10-26-2012, 10:36 AM   #3781
CA Stu
CA Stu's Avatar
Oddometer: 42,779
Originally Posted by FJracer View Post
Thanks for the advice BUT I don't remember telling anyone that was the original chain. In fact it was reasonably new EK as well as the sprockets. I bought the Bike in Aug. with 22K on it. Previous owner stated chain fairly new. And that was verified when the front sprocket was swapped out. The 15T I put back on was the original and it looked good to me ........... at the time. In retrospect, I may replace that one..................or both. I recovered the Chain just a moment ago when I came back for Dr. appointment. One link just broke.
Master link?
CA Stu is offline   Reply With Quote
Old 10-26-2012, 12:04 PM   #3782
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 1,975
I bought a DR650 that the PO said the brakes were new, "Just put them on prior to the previous ride". Well I don't know how long the previous ride was but they were toast. ie. The PO word might not mean anything.
Regardless, at least you can fix the problem easy.
bikes
Yokomo is offline   Reply With Quote
Old 10-26-2012, 03:13 PM   #3783
Jettn Jim
This is Liv'n!!!
Jettn Jim's Avatar
Location: Northeast PA, Some... On HIGH ADVENTURE Most!
Oddometer: 1,263
Coulda picked up a rock and c racked/stressed a link then on said day Kapowie! As it was, easy fix and glad it wasn't more.
Jettn Jim is offline   Reply With Quote
Old 10-27-2012, 07:07 AM   #3784
GO_OUTSIDE!
dirty hippie
GO_OUTSIDE!'s Avatar
Oddometer: 196
Im still stumped at running a steep hill in 4th gear.
Im happy to hear it was something simple and you didnt bust a case when the chain came off.
Thank you!
Now Go Outside!
GO_OUTSIDE! is offline   Reply With Quote
Old 10-28-2012, 05:43 PM   #3785
PacificPT
Oddometer: 942
Earlier this year tried the Jardines RT4 exhaust on the bike but was unhappy with the volume even with the quiet insert. Rode it one time then took it off and put the stock unit back on. Had a chance this weekend to look at it with the idea of making it quieter. Took one steel wool pad and pushed it into the spark arrestor then took multiple pieces of fine mesh wire fencing and filled the rest and used it to hold the steel wool in place. Sound is now acceptable to me, much deeper than the stock but not loud. Jetting seems spot on with the .22 cent mod. I tried it with three steel wool pads but that was too much, backed up sounding, tried two but one was the magic number. Will keep checking to see if the steel wool holds together or not. With the new exhaust and the Li-ion battery you deduct about 17 pounds from the pig. Now I need to do my part and deduct 17 pounds from me!
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 10-30-2012, 11:15 AM   #3786
Grinnin
Forever N00b
Oddometer: 1,609
Originally Posted by Aprilia View Post
While the clutch is pretty robust on the KLR it can get glazed/burned if abused too much. If your level adjustment suddenly changes while slipping its time to back off...
My throttle/speed control issues are fortunately not the clutch. It's the trail. And the carb. And the operator. The spruce/fir duff changes texture constantly and the bike floats on parts then sinks into a sponge that takes a good bit of power. And it's all covered in needles and leaves so it's impossible to tell what kind of power is needed just ahead.
At the same time the exhaust was popping a bit on closed throttle (on the road) so I richened up the idle mixture.
EDIT: I'm not sure why the spruce/fir duff is more difficult for me than a rocky, murky water crossing. For water I can usually maintain the same moderate pace no matter what I hit below the surface. For duff, bogging in a hole and powering out then flings me forward. Both situations are about unseen obstacles. The 16t countersprocket isn't a problem on rocks. It's great on the highway. I'll see how the trail firms up in the next month or so.
Motorcycles are magical.
Grinnin screwed with this post 10-30-2012 at 12:21 PM
Grinnin is offline   Reply With Quote
Old 10-30-2012, 07:09 PM   #3787
lexluther11
Ride,Eat,Rest-Repeat
lexluther11's Avatar
Oddometer: 688
Anyone running a 16t front sprocket with a 44t rear and if so how do you like it?
Thanks......
lexluther11 is offline   Reply With Quote
Old 10-30-2012, 07:24 PM   #3788
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 1,975
Stock rear sprocket, larger diameter rear tire, 16t front and I really like it.
bikes
Old 10-31-2012, 08:31 AM   #3789
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 1,924
16/45, because I couldn't get a 46. It's a little too tall, but not bad. At least it's an easy swap to a 14t. I tried 16/43 once before, and thought it a complete waste of time.
The taller gearing might be okay with clubman bars, or even a Triumph Euro bend, but the aerodynamic profile of this bike is all wrong for tall gearing.
You flatter yourself, Madam. It's hanging out.
judjonzz is offline   Reply With Quote
Old 10-31-2012, 10:30 AM   #3790
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,089
That's why you can only take what's stated here...
at face value and why I advocate people try things for themselves. 16/43 works great for me. I commute 110 miles round trip on my bike but it's still functional off road as long as it doesn't get to technical. That's my ride and what works for me doesn't neccesarily work for everyone else. You have to experiment for yourselve to find what REALLY works for you.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 10-31-2012, 11:04 AM   #3791
DirtyDog
Lust for dust...
DirtyDog's Avatar
Oddometer: 6,121
Jud, you realize that the stock setup is 15/43 (2.87), right?
Your gearing of 16/45 is 2.81, whereas 16/43 is 2.69. I'm not sure why you were aiming for 16/46 (2.88) because that is basically equivalent to stock. But, if you're like me and swap in the 14T for dirt duty, then I agree it's probably a good choice.
One thing I've found with doing this with a 14,16/48 combo is that I can't remove/install the 16T counter sprocket without taking out the rear axle. Complicates things and adds time. I even have a 110 link (IIRC) chain. Can you do this swap with stock chain (106 links) and without removing the axle?
And I agree with your aerodynamic statement.
Check out PBI for numerous options for KLR sprockets. They are aluminum, but I've had good results with them. Hard to find those odd sizes in steel. http://shop.pbisprockets.com/product.sc?productId=281
... grease, grit, and mud are runnin' in my blood.
DirtyDog is offline   Reply With Quote
Old 10-31-2012, 11:20 AM   #3792
judjonzz
Beastly
judjonzz's Avatar
Oddometer: 1,924
You are right on the money for shooting for 16/46: almost the same as stock, and an easy 2-tooth drop with a 14t chainwheel. I use 108 links with 16/45, and don't have to pull the rear axle.
I use only steel sprockets. My KTM came with aluminum: Gone in Sixty Seconds. I won't go that route again.
Old 10-31-2012, 04:07 PM   #3793
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 1,975
16/43 works good for me. If I plan on doing anything aggressive I slip on this.
bikes
Old 11-03-2012, 02:58 PM   #3794
FJracer
FJracer's Avatar
Oddometer: 50
Good point! Be stumped no more; it was 3rd gear.
FJracer is offline   Reply With Quote
Old 11-24-2012, 09:08 PM   #3795
rhino_adv
rhino_adv's Avatar
Oddometer: 601
Originally Posted by Aron31 View Post
Who out there has thoroughly tested their crash bars? Just wondering what everyone's experiences have been. Seems like the 2 big ones are the sw motechs and the happy trails pd kit. I think givi also released some as well. They all look great brand new but what about after a couple offs? Any bending? Tweaking? Fitment issues? I just don't want to waste the money on something that's going to go to crap the first nap it takes.
I have been down twice with the SW Motech crash bars on my 2011 and not sustained any damage to either the bars or plastics. The crash bars fit very well and were easily installed in a short afternoon with help from a friend who had installed a set on his KLR last year.
Brad
Old Bridges Thread
Riding the TWAT
475+ Bridges in Illinois,
985+ Old Bridges in Missouri
PAVED ROADS...... ANOTHER PERFECT EXAMPLE OF NEEDLESS, SPENDING BY THE GOVERNMENT"
rhino_adv is offline   Reply With Quote
Times are GMT -7.   It's 05:12 AM.
