Old 02-25-2013, 07:32 AM   #4081
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,049
Originally Posted by GO_OUTSIDE! View Post
Dont forget heated grips, do forget those heated filaments that go under the grips, the bars will suck all the heat away, get the kind where the filament is molded into the grip.
With an average yearly temp of 67 degrees I need cooling grips and jacket....
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 02-25-2013, 07:41 AM   #4082
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,797
I guess that's a matter of perception and where your expectations are. I have the heated filament type, been on the bike for 3 years, work great and at times get too hot even when on the low setting. That's why asking advice on what works sometimes (I said sometimes) is silly. Accesories, tires, oil to use, try different stuff and you'll find what works for you. If you're not willing to try different things, you're setting yourself up for dissappointment. There isn't always an instant answer, one size fits all remedy.
Now go ride!
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 02-25-2013, 08:32 AM   #4083
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,909
This comment made me look up the stats for Tulsa, OK.
Interesting stuff. We avg 60.8 deg annually, but we have about as many <32 deg days as we have >90 deg days (each is over sixty days). Calling Tulsa weather "mild" is a gross understatement.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 02-25-2013, 09:53 AM   #4084
Aprilia
Oddometer: 702
My drive way is at 7000ft so average temps are 45.8F. While we get more snow than most anywhere we have lots of sunshine (its Arizona!) so riding year round is generally not a problem. Head south (downhill) 2hrs and temps are always 30-35F warmer anytime of year.
Aprilia is offline   Reply With Quote
Old 02-25-2013, 10:08 AM   #4085
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,049
This was an uncommon year, we actually had a couple of days at freezing..(brrr) as far as Aprilia goes, I spent a number of my younger years in Durango, CO, at about the same elevation. Are you anywhere close to Cloudcroft? Oh, I just looked, Flagstaff! Used to drive through all the time on the way to SoCal. I love that area!
Old 02-25-2013, 11:08 AM   #4086
riderIN
Oddometer: 234
Shinko 700
Originally Posted by XpressCS View Post
I just got a pair of Shinko 700's coming in the mail if anyone's interested in seeing how i like them. I ride a LOT of dirt roads, so I figured they'd be perfect since it's also my commuter.
Yep,please let us know.
I've been thinking to get them as well.
riderIN is offline   Reply With Quote
Old 03-11-2013, 11:08 AM   #4087
pirate gonzo
pirate gonzo's Avatar
Oddometer: 84
What Headlight Bulbs?
I am running PIAA 530 LED fog lamps and want something to match the whiteness of them. My headlight is more yellow.
What do you guys run for Headlight bulbs?
pirate gonzo is offline   Reply With Quote
Old 03-11-2013, 12:36 PM   #4088
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,328
My gen 2 low beam is 35 watt 4300k Hid.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 03-17-2013, 12:54 PM   #4089
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 596
Hi everyone, I'm new to this thread so i'll just make a list of what I have and post pics soon! I have an '02. I also don't know alot of the fancy part names for some things but bare with me
- Oversized front brake disk
- Acerbis rally pro handguards with extension for wind protection
- Gen 1 tall windscreen
- Braided steel brake and clutch lines
- Aluminum bash plate
- 12V adapter
- Heated grips
- Some sort of awsome rubber grips. not sure which kind they are but they're great for reducing vibrations
- Gen 2 front fender (looks awsome on the gen 1)
- New fork boots (more durable than stock)
- Highway pegs/engine guard
- Metal rad fan (not sure if it's better than stock plastic)
- MSR foot pegs
- Bigfoot kickstand plate
- HT centre stand
- Dirt Racks luggage rack
- Custom panniers ( aluminum, having them made by a welder )
- Joe rocket tank bag
- LED rear brake light
- Front fork brace (awsome, love it)
- Aftermarket no-maintenance battery
- Magnetic oil drain plug
- Dual Star oil cap (the one that you need a tire wrench to open)
- 16T front sprocket
- Aftermarket exhaust (not sure which kind, just came with the bike)
- License plate moved higher
- Rear master cylinder guard
- Paint job ( '02s are green, mine in black and sexy red)
- New seat (I'm making it myself using the stock seat pan)
- Bar risers (came with the bike, don't know how high)
I think that's it, not sure. That's just off the top of my head.
Mods I have planned :
- Wheatwhacker or whatever the name is mod
- Carb vent T mod
- Check if the doo has been done
- Switch air filters
- Make a plastic dash to mount GPS and other gadgets
- Finish my seat
- Replace crappy magnetic joe rocket tank bag with wolfman expandable strap on bag
- Figure out a new bulb for front headlight
- Get cheap axillary lights and mount to forks
- Double up my clutch and brake lines and zip tie to current ones
- Get different, brighter signal lights
- Get license plate light
- New paint job
- New 12V adapter
- New rear tire (any suggestions? I want a cheap 70/30 street)
- Cruise control
- Plate welded to opening of center stand (gives you a second bash plate pretty much)
- Have side engine guards made similar to SW Motech ones
- Vapour dash
I think that's it. I'm preparing for a trip from Winnipeg, Manitoba to St. John's, Newfoundland. Basically 14000 km there and back. If you guys could look over my list and give me feedback that would be awsome!
Thanks.
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR screwed with this post 03-17-2013 at 10:02 PM
KamikazeKLR is offline   Reply With Quote
Old 03-17-2013, 01:08 PM   #4090
KustomizingKid
Oddometer: 678
Just installed my fully rebuilt carb, KlX needle, and KLX choke lever... Very pleased with the results.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 03-17-2013, 05:16 PM   #4091
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,455
Once complete there might be a few stock parts left, but not much
Your list is very complete. My $0.02 is to put an HID on it, at $40-60 you get a lot of value. Curious what the benefit is to weld your bash plate and centerstand together?
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 03-17-2013, 06:55 PM   #4092
Aprilia
Oddometer: 702
Thanks.
Its a nice list of farkles but most are just that...farkles. Where's the basic maintenance items...pull rear suspension for lube, head bearings, fork fluid, coolant flush, brake fluid flush etc etc. I've put over 60K km in 2 yrs on my KLR with just regular old maintenance...and a upgraded Doo/Lever. Never had a problem...
Old 03-17-2013, 09:55 PM   #4093
KamikazeKLR
Shorty on the 650
Oddometer: 596
You dont weld the centre stand to the bash plate, sorry I didn't explain that very well. You weld a seperate plate on the square shaped opening of the stand so when it's up it becomes a second bash plate by itself for underneath the middle of the bike instead of the front. I hope that clears that up.
- Mel
Long Way Back
Old 03-17-2013, 09:56 PM   #4094
KamikazeKLR
Shorty on the 650
Oddometer: 596
Will do. Alot of the reg maint I didnt bother adding there because half of that has already been done and this is a mod thread, not a maint thread. But thanks for reminding me, I'll make sure those get done.
- Mel
Long Way Back
Old 03-17-2013, 10:20 PM   #4095
SkiBumBrian
DualSport Crazy !!
Oddometer: 1,049
+1. Farkles are one thing, maintenance and performance mods another. I have like... ZERO farkles but a crazy list of upgrades. I am thinking of another KLR to weigh down for trips....
Times are GMT -7.   It's 06:53 AM.
