08-29-2006, 01:34 PM
#46 | ||
Pastafarian
Oddometer: 61
I believe our suppliers have done their homework and are offering quality do-dads which may or may not enhance our riding experience depending upon our personal views. Some of us are running stockers, some of us have every acc'y in the known universe. The rest of us are somewhere between. Quote:
#2? Jeeze, that opens a debate don't it? My vote would be for another known failure issue; the questionable quality of the subframe fasteners. They're easy to upgrade, why take a chance? #2.1 - Replace shift pedal before it fails #2.2 - Disable "safety" interlocks before they fail #3.0 - Premium air filter #3.1 - Premium brake pads #4.0 - Replace fork oil These few mods provide you with a reliable ride you can have confidence in to get you home safely. For me the next most important addition after the skid plate was the double-wide toothed foot pegs. When I hit the Rough, I stand, and when I stand I stand on my balls (we're talkin' feet here); much better control and feel than standing on your insteps. Double-wide pegs offer more support and grip than that rubber trash or single-wides. YMMV. Anything to avoid? Eldon doesn't like centerstands nor fork braces; lotsa guys swear by 'em. Everybody has something in mind to avoid and probably a valid reason for it. At my next chain/sprocket renewal I'm going back to a 15t CS sprocket (from a 14t) and drop the final gearing with a 47t rear. Reason; the larger radii of the larger sprockets are easier on the chain due to (hope the physics guys don't laugh too loud) decreased angular velocity. Your views? Best, Steve
I have abandoned my search for Truth, and am now looking for a good Fantasy. |
08-29-2006, 01:51 PM
#47 | |
Pongo pygmaeus
Oddometer: 826
Yea, so much for the mantra that the KLR is inexpensive. Cheap entry fee, but the farkle lure takes down many a budget. Is an outfitted $7k KLR better than a…F650, LC_, XR? I think that's the question: WHAT WILL YOU ULTIMATELY SPEND AND WHAT BIKE DO YOU GET FOR THE $$$$$ ?
08-29-2006, 02:17 PM
#48 | |
wannabe
Oddometer: 4,126
I have spent more on gear and farkles than the KLR, and I bought it new
08-29-2006, 03:30 PM
#49 | |
Off the wagon
Oddometer: 4,868
'08Husky TE 610 '07 R12GSA '07 KTM 950sm '92 GOLD WING '77 HUSKY 390 CR '72 Honda xl 250 '71 Honda sl 125 '79 HUSKY390cr '75 Can Am 250 MX-2 '70 Honda CT 70 '05 R12GS.....R.I.P. (rest in pieces) |
08-29-2006, 04:04 PM
#50 | |
Oddometer: 42,794
2nd gear with a 14 tooth front puts my KLR right in the sweet spot for prolonged deep sand riding. I've got a load and a half of mods on my bike, I bought the first Big Gun pipe ever sold for the KLR, I had my Dad ship me a Laser ProDuro before they were available in the US. I have frittered away tons of time and money on my 2 KLRs. Dust the doohickey, richen up the carb a tad, replace rear subframe and front brake reservoir hardware. Those are what I would call important preventive mods, the rest is all personal preference. Here's my preference list: My 00 KLR 650 Modded (cut) Airbox K&N filter w/ Filterskin Renthal 666 Desert Bend bars filled with urethane Vista Cruise Cruise control Enduro Engineering handguards w/ spoilers Pro Gel grips Countdown Roll Chart Holder K-9 Fork Brace 55/100W HD Headlamp Bulb Happy Trails Highway pegs IMS gearshift lever IMS Pro Series footpegs RAM mounted eMap GPS 12 v weatherproof cigarette lighter outlet Progressive Suspension Larry Roessler Series fork Springs Progressive Suspension 420 Series rear shock Moose Bash plate (custom ground for access to counterbalancer bolt) Eagle Machine balancer chain tensioner idler lever Galfer braided front brake line Galfer oversized front wave rotor Russell braided rear brake line Big Gun head pipe Laser ProDuro Exhaust can Wolfman Explorer Tankbag Kawasaki Tailbag Aerostich Tank Panniers DID Gold X-Ring 106 link chain Custom Nylock chain adjuster nuts "T" modded carb Dual Star self-locking axle nuts Moose fender bag (with MSR rain pants inside) Kawasaki exhaust luggage protector (broken now) Walmart Battery of Eternal Charge Big Cee Ultra Blue rear subframe kit 14T Sunstar front sprocket Corbin flat seat Thanks CA Stu |
08-29-2006, 06:28 PM
#51 | |
eX-nOOb
Oddometer: 131
It's the journey, not the destination. |
08-29-2006, 07:26 PM
#52 | |
Fla Mountains...yep!
Oddometer: 1,383
08-29-2006, 07:44 PM
#53 |
Oddometer: 120
Mods
Skid Plate
Master Cylinder guard Fork Brace Side Luggage guards Rad guards Handlebar Bark Buster type guards, and new front brake lever from fall!! Magnetic drain plug Regular oil changes Regular Doohickey adjustment Mirror dampeners, not good! Consider other options!!!! Pro grip grips |
08-29-2006, 10:58 PM
#54 |
cruzincariboucountry
Oddometer: 300
My 02 uses a bit of oil on the highway, want to make sure i'm not sending it thru the carb. Mods?....
offroad pipe jetted L-mod airbox air filter & (screen removed) progressive springs frt and rr 420 shock rear stainless front brake line acerbis hand guards homemade shifter chopped off rear fender sidestand interlock bypassed D606 rear tire (absolutely disappears on the highway) need to replace soon with ???Mefo, Kenda 270, TKC 80, has anyone heard of or tried Maxxis? Thanks. |
08-29-2006, 11:57 PM
#55 |
Semper Fi
Oddometer: 389
I use the kenda 270's, great tire, but I only get about 3k and then it's toast.
2002 KLR 650 1986 GL1200 combat couch 1999 KE 100 1978 RD 400 " I'm flat out like a lizard drinking " |
08-30-2006, 12:19 AM
#56 | |
Oddometer: 42,794
Thanks CA Stu |
08-30-2006, 05:37 AM
#57 | |
Oddometer: 4,560
Today is the tomorrow you worried about yesterday |
08-30-2006, 05:49 AM
#58 | |
Pass the gas.
Oddometer: 112
A couple of my riding friends have run the Maxxis 6006. They weren't particularly impressed but said you could do worse. One went to a K270 afterwards, the other to a Cheng Shin 858. |
08-30-2006, 06:17 AM
#59 |
anyone try spider grips on there bars with bark busters? did you have to trim the grips or are they the right size?
08-30-2006, 12:03 PM
#60 |
user
Oddometer: 48
I'm trying to install an odyssey battery on my klr and am having difficulties findind a way to secure the battery in place. Dual star claims slight mods are required to make the install and am either dumb or stupid as I can not see how or what materials I should use to hold the battery in the air box compaertment. Any suggestions?
Other KLR Mods supertrapp pipe w dynojet kit, and thumb scew adjustment skid plate heat grips rally pro guards IMS footpegs Happy Trails Panniers subframe upgrade kit doohickey master cylinder guard and rear brake bracket Scorpion AT tires. A little squirrely in the sand and mud but they'll get you through and still roll for around 10 grand Still am debating the seat issue and after reading this thread am thinking about getting the corbin flat seat. The way I see it my klr with after market still cost less than a F650 and has all the tools I need to ride internationally. Both on and off road... greenfreak screwed with this post 08-30-2006 at 12:07 PM Reason: adding photo |
