Old 02-05-2011, 08:38 PM   #766
binskies
binskies's Avatar
Oddometer: 130
My "new to me" KLR
This is how she looked when I bought her
The ding on the tank isn't as big as it looks in the pic. I can't wait to start doing some dual-sport riding.
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW! What a ride!"
binskies is offline   Reply With Quote
Old 02-06-2011, 06:00 AM   #767
mikejet
KlrKid
mikejet's Avatar
Oddometer: 87
KLR Mods
Hey all, Here`s a list of what i`ve done ( so far ) on my 2008 Green Machine
remove clutch switch
remove side stand switch
relocated rear blinkers
mercedes breather valve
open up airbox
stainless steel oil filter
eagle mike doohickey and torsion spring
added headlight off switch
12 volt power outlet
heated gear outlet
Trax panniers and mounts ( Heavy Duty Man )
4" tube carrier ( front of frame )
Aluminum skid plate
tank bag
1.5 handle bar risers
Roo knobbies ( nice! )
Cee Bailey headlight protector
Custom fab`d spare tire / crutch carrier ( changing flats )
Rear master cylinder guard
Yuasa sealed battery
MikeJet: When life throws you a curve - Hit the Throttle
Current Stable: 2011 Kawasaki Concours - 2001 Harley Road King
1978 BMW R100S
mikejet is offline   Reply With Quote
Old 02-06-2011, 08:40 AM   #768
MotoBoss
Tundra Thumper
MotoBoss's Avatar
Oddometer: 2,226
I can't remember or count all the changes or mods!
Still digg'n the '98................
DONATE TO ADVRider
sidestandup.com ridedualsport.com
motoboss-terlingua-bound.blogspot.com
MSF Rider Coach-Rider's Edge Instructor-Track Coach
MotoBoss is offline   Reply With Quote
Old 02-06-2011, 05:11 PM   #769
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
Wicked
I really thought I had put my bikes in here, but after looking I haven't put either one in. I save you the boring details on my 89' and go straight to the 08. there is too much done for me to remember it all or to list it. If you see something you want to know about just ask. here the high point
  • 705 kit
  • stgII head
  • fmf header w/ leo pipe
  • woody's supe lace wheel set
  • yz250 forks dail in by motocd.com
  • long travel rear shock with 10" of travel and 11" front
  • custom dubble wall skid plate
  • custom side panels
  • H-T elite pannier racks
  • heated grips
  • fat bars
windshield mount
the elite racks pull the panniers in tight with the frame 7" tetons
tail system with 5" panniers
with new suspension set up completely bottomed it has 2" clearance
home made rad guard
plenty of ground clearance
johnwesley is offline   Reply With Quote
Old 02-06-2011, 06:30 PM   #770
bete
Oddometer: 427
Hey John, thats a sweet set up KLR. I'm getting ready to do a big bore because mine is suckin the oil, Do you think theres a big diferance between the 685 and the 705? did you go with larger valves and porting? stock cams? thanks, bete.
bete is offline   Reply With Quote
Old 02-06-2011, 06:59 PM   #771
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
actually there is a difference and it is felt in the lower end and midrange performance. Seems to be the same up top. I had the 685 and STGII head before going to the 705 kit.
the heads are ported with polished combustion chamber with over size valves. I have not tried cams yet, but wouldn't mind moving the peak torque up 500 rpms. My issue is that no one I have talked with has enough experience with the cams to give me clear advice on what grinds to look for. I would like the same curve just moved up about 500 rpms which would also give me a few extra ponies up top. I am sitting at 45 rwhp right now and it runs nice. It pulls a 17 tooth front well fully loaded
Old 02-07-2011, 02:37 PM   #772
pzs
pzs's Avatar
Oddometer: 142
why 18 inch front wheel?
What is the benifit to fitting an 18 or 19 inch front wheel on the KLR.
This seems to be a popular mod on this bike, more so that in any other big singles forums I can see, I
pzs is offline   Reply With Quote
Old 02-07-2011, 03:37 PM   #773
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,423
The Pig in fighting trim
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 02-11-2011, 07:55 PM   #774
MetalBender
none
MetalBender's Avatar
Oddometer: 554
Question
Today I got the 705 kit and stage 2 hot cams ordered. Exhaust and jet kit are done. Looking forward to the results.
Is there a way to advance the stator? An offset key or cdi that will pick up quicker?
This is all I've found so far. http://ignitech.cz/english/aindex.htm
MetalBender is offline   Reply With Quote
Old 02-15-2011, 05:59 PM   #775
ETrider
ETrider's Avatar
Oddometer: 350
The KLR 250 fairing mod. Sometimes less is more.
'05 KLR 650
'10 Giant Yukon
ETrider is offline   Reply With Quote
Old 02-15-2011, 06:34 PM   #776
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 1,965
08 KLR swing arm on an 05.....
Ok guys.... posted this over on KLR World....I will post it here... Although I am not the first....Here it is..
MISC 009 by sky_soldier_82nd, on Flickr
MISC 008 by sky_soldier_82nd, on Flickr
Was a pretty streaight forward swap... I think it turned out pretty good...
wparkinson is offline   Reply With Quote
Old 02-15-2011, 06:45 PM   #777
nigelcorn
Wannabe.
nigelcorn's Avatar
Oddometer: 740
Hmm, I haven't heard of this one yet. What is the benefit of putting the '08 swingarm on the previous gen?
nigelcorn is offline   Reply With Quote
Old 02-15-2011, 07:29 PM   #778
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 1,965
Well... for one... Better rear brake... Cleaner look... Who cares.. I got bored...LOL
Old 02-15-2011, 07:36 PM   #779
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
it should also be more rigid as is a d shaped arm as compared to the square
Old 02-15-2011, 07:43 PM   #780
wparkinson
Gear Whore
wparkinson's Avatar
Oddometer: 1,965
How about this?
KLX 650R radiators on the KLR....
KLX radiator on KLR 007 by sky_soldier_82nd, on Flickr
KLX radiator on KLR 008 by sky_soldier_82nd, on Flickr
KLX radiator on KLR 009 by sky_soldier_82nd, on Flickr
KLX radiator on KLR 010 by sky_soldier_82nd, on Flickr
KLX radiator on KLR 018 by sky_soldier_82nd, on Flickr
Overflow 001 by sky_soldier_82nd, on Flickr
Overflow 007 by sky_soldier_82nd, on Flickr
What ya think?
Times are GMT -7.   It's 02:17 AM.
