Old 01-26-2012, 01:24 AM   #616
Padmei
enamoured
Oddometer: 3,677
Originally Posted by alister102 View Post
That bike is a credit to you- well done. It captures the real essence of cool.
Now a stupid question. Is it comfortable to ride?
Padmei is offline   Reply With Quote
Old 01-26-2012, 05:24 AM   #617
Speed King
Speed King's Avatar
Oddometer: 1,635
That thing is freakin amazing. Congrats- nice, nice job.^
Speed King is offline   Reply With Quote
Old 01-26-2012, 08:10 AM   #618
alister102
alister102's Avatar
Oddometer: 259
Thanks Fellas-
Not as comfortable as it was when I used to take it cross country, but it's not set up for that anymore- just quick blasts down country roads which it's quite comfortable for.
a
alister102 is offline   Reply With Quote
Old 01-30-2012, 03:51 AM   #619
bill42
Old-School BMWs
bill42's Avatar
Oddometer: 362
Thanks Fellas-
a
really sweet build. Can you tell us how you are liking the legibility of the new gauge compared to the stock dual cans?
I am considering this move myself as my speedo seems more off than the typical 5mph.
bill42 screwed with this post 01-30-2012 at 04:46 AM
bill42 is offline   Reply With Quote
Old 01-30-2012, 07:39 AM   #620
alister102
alister102's Avatar
Oddometer: 259
It's really nice having an accurate gauge- mine was off by more than 10 after changing my rear drive. As long as you adjust the angle to be perpendicular to your line of vision it works great, and there is a little leeway there. recommended.
Old 01-30-2012, 10:28 AM   #621
rkatapt
Indo-Kraut
Oddometer: 261
Here's my 75' R90/6...
I really need to get osme better shots of it one day.
My catch can solution. How do you guys get away with just a filter there and no way to catch oil? I ride it pretty hard and it spits oil when it gets hot.
rkatapt is offline   Reply With Quote
Old 01-30-2012, 11:20 AM   #622
xavier296
Alaska n'Back
xavier296's Avatar
Oddometer: 285
Rka,
Looking good, I see a lot of similar parts as my cafe. I love the seat, that is the design I had in mind. I would appreciate a bigger pic so I can take it with me to the upholstery guy.
I bet it is hard to keep the engine clean with no rear fender at all. I gave in and installed one despite that desire to have an empty "triangle."
Mainly I am glad to see a bike other than alister's and the one with the huge fairing. They have beautiful bikes, but we need new blood.
I love it!!
2011 R1200GSA 30th Anniversary
79 R100RS
Build Thread: http://advrider.com/forums/showthread.php?t=732078
I welcome any and all couch surfers if you are traveling through Augusta. I even have a well stocked garage for emergent repairs.
xavier296 is offline   Reply With Quote
Old 01-30-2012, 11:54 AM   #623
rkatapt
Indo-Kraut
Oddometer: 261
Originally Posted by xavier296 View Post
Rka,
I love it!!
Thanks...
I'll see what I can do about a pic. I don't have to many closeups of the bike.
I have thought about a fender, but i liek the way it looks just bare. As you can tell it's more of a rider than a looker and I ride the shit out of it. Probably harder than I should. I like a little dirt on the bike as I've never understood how people keep there bikes so clean.
Here is another one I dug up.
and I couple more while it was still a work in progress.
Old 01-30-2012, 02:04 PM   #624
DiabloADV
Semi-Occasional
Oddometer: 2,301
Why not run the vent hose to the intakes on the carbs and burn that oil away? That's what the stock setup does...
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 01-30-2012, 02:09 PM   #625
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 590
Would that still work using cones? It wouldn't be too much oil getting into the carb due to the shorter distance than the stock setup?
KhaoSanMan is offline   Reply With Quote
Old 01-30-2012, 02:21 PM   #626
DiabloADV
Semi-Occasional
Oddometer: 2,301
Well, a cone setup should still have an extension tube 2-3 inches long between the carb and the filter. Feed the vent hose into that tube? Would need to split the vent hose and go to both carbs I guess.
Old 01-30-2012, 02:38 PM   #627
supershaft
because I can
Oddometer: 9,116
Like I always warn, nine of of ten crankcase breather setups I see posted are a dangerous mess waiting to happen.
Why not run the crank case vent to the carbs like the stock setup? The main reasons are that the oil gunks up the carbs, carbons up the heads and pistons not to mention the intake valve, reduces power, and causes pinging. Most always on a different level from one cylinder to the next thusly exacerbating the issues. I go to great lengths in order to keep oil out of the combustion process. I'll be damned if I am going to turn around and dump it right back in!
Old 01-30-2012, 02:48 PM   #628
DiabloADV
Semi-Occasional
Oddometer: 2,301
Ok...makes sense.
So...what have folks done to manage vent oil when eliminating the stock airbox? I like the shiny can shown above...any other ideas out there?
Old 01-30-2012, 02:58 PM   #629
supershaft
because I can
Oddometer: 9,116
Eliminating the stock airbox? Minus the air pump crap, the crankcase vent crap, and the crap stock filter, I do run a stock airbox! I run mine out the back. That or a catch can are the only two ways that will work in the long haul. You have to be careful in both instances in order to not oil your bike and tire but it can be done! Catch cans have to breath too after all.
Old 01-30-2012, 03:00 PM   #630
DiabloADV
Semi-Occasional
Oddometer: 2,301
What does "out the back" entail? Do you mean running a hose down to the lower frame and have the oil mist just blow away?
Times are GMT -7.   It's 03:54 PM.
