Old 10-22-2008, 05:20 PM   #61
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
Originally Posted by M1Jeep
From the front it looks good. Can you please post some side-view pics? What year Dakar f650gs did this come from? TIA!
Thats from a 2001 Dakar price new is like 180 or so they pop up on ehbay once and a while.
Klaatu barada nikto
onaXR is offline   Reply With Quote
Old 10-23-2008, 10:34 AM   #62
sgoat
sgoat's Avatar
Oddometer: 24
Originally Posted by TheDudeAbides
An intersting solution, I might look into that.
What kind of hardware are you using to mount yours? I can't tell from the picture. I'm looking for something that can allow a "quick change" removal. Would like to go with Dzuz fasteners, but haven't figured out how to make that work yet. I've already replaced the stock nylon bolts (which I stripped out) with stainless.
Still using the plastic (breakaway) hardware, but used rubber grommets and washers to stand the shield off of the fairing about 1/2". This helps to relieve the negative pressure behind the screen. I taped off the screen with masking tape, traced the top off the screen down about 2 1/2", and used a dremel tool with a cut-off wheel (go slow)to make the cut. Came out suprisingly well even for a klutz like me. Finished off with some 400 grit sandpaper. Good luck!
"A closed mouth gathers no feet"
sgoat is offline   Reply With Quote
Old 10-23-2008, 12:27 PM   #63
Aussie Trev
aka DRTrev
Aussie Trev's Avatar
Oddometer: 5,829
Here's mine...made in Melbourne Australia...
Attachment 196450
2011 Triumph Tiger 800XC
1982 PE175Z
Full member......Quorn Schnitzel Club
"Just having a crack"
Aussie Trev screwed with this post 11-28-2008 at 09:51 PM
Aussie Trev is offline   Reply With Quote
Old 10-23-2008, 04:53 PM   #64
rallyhound
Macho stud guy
rallyhound's Avatar
Oddometer: 872
When it's all said and done, More will be said.
You dont have to wish me luck for me to know that I need it.
rallyhound is offline   Reply With Quote
Old 10-23-2008, 05:13 PM   #65
doc_ricketts
Thumper jockey
doc_ricketts's Avatar
Oddometer: 5,440
MRA with a homemade lucite extension
"Get yourself to the hills and be uplifted, assuming you got some good knobbies"
doc_ricketts is offline   Reply With Quote
Old 10-23-2008, 06:07 PM   #66
RDsDR
RDsDR's Avatar
Oddometer: 32
Smoked MRA
08 DR650
07 CRF250X
RDsDR is offline   Reply With Quote
Old 10-23-2008, 07:41 PM   #67
neepuk
Such a drag...
neepuk's Avatar
Oddometer: 1,626
Cee Bailey's XR650l screen modified to fit the DR...
neepuk is offline   Reply With Quote
Old 10-23-2008, 07:48 PM   #68
jtb
jtb's Avatar
Oddometer: 2,172
Originally Posted by onaXR
I cant believe no one has posted the BMW Dakar screen on a dr.. Fits like it was made for it.
I like that!
"Motorcyclist are always going to be frowned a pond..." an inmate in the AUS group
SOFT TO THE CORE OUTBACK NSW & SA RIDE REPORT JULY 2014
jtb is offline   Reply With Quote
Old 10-23-2008, 07:54 PM   #69
jtb
jtb's Avatar
Oddometer: 2,172
What's the bell for?
Old 10-23-2008, 07:59 PM   #70
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,402
Question Tank panniers ??
Originally Posted by sgoat
My 07' came with a Cee Bailey which I didn't much care for. I cut the height down by about 2 1/2" and put a piece of Saeng edging that I had on it. Result, buffetting nearly eliminated and it doesn't flex like it did at the stock hgt. It's a keeper!
(Sorry for the quick break in the windscreen thread)
Hey sgoat ...
Which tank panniers are those ??? and are the front straps stock or did you add them ??? Any chance of some additional pictures from the side (will also show the windscreen) also pics of the mounting straps...
Thanks ...
Honda
GsVs is offline   Reply With Quote
Old 10-23-2008, 08:26 PM   #71
Wander4Days
Where am I?
Wander4Days's Avatar
Oddometer: 134
I like the looks of that one too. How tall are you? Do you get any buffeting? Have you used any other brand of windscreen to compare this one to? I had the regular Cee Bailey's, which was OK, but it didn't have that "lip" on the top edge of the screen. Any info would be appreciated. Do you have anymore pics of it on your bike?
I am 6'0 and it worked out well- i would get a little buffeting if I sat up close at high speed. I haven't ridden another screen to compare but it was just a good medium size to give some protection but stay out of the way for offroad- here's a couple more pics i scrounged up- not sure if they show much more...
Wander4Days is offline   Reply With Quote
Old 10-23-2008, 08:55 PM   #72
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,991
gen 1 FZ1 stock screen
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-23-2008, 09:25 PM   #73
GillaFunk
I use profanities
GillaFunk's Avatar
Oddometer: 4,142
bla bla bla bla bla
EVERYTHING I need to know I learned from Porn
2011 Gear-Up; "سميرة" (Samira)
2013 DR800; "The Dirty-Hooker Too"
2007 FJR1300; "Sally Jupiter"
2003 1150GSA; the 2 Wheeled Submarine
GillaFunk is offline   Reply With Quote
Old 10-24-2008, 03:39 AM   #74
mtntrails
Oddometer: 461
So, on a Slipstreamer Spitfire, are the two rods that connect at the handlebars and at the windshield the only mounting points? Is there a lower mounting point that I am not seeing?
I'm thinking about one of these for my DRZ.
mtntrails is offline   Reply With Quote
Old 10-24-2008, 04:47 AM   #75
onaXR
Druid
onaXR's Avatar
Oddometer: 2,086
makes women and small children smile.....
Klaatu barada nikto
Times are GMT -7.   It's 01:50 AM.
