Old 09-27-2006, 08:21 PM   #16
xrmattaz
sputum is my bread/butter
xrmattaz's Avatar
Oddometer: 3,177
Send a message via AIM to xrmattaz Send a message via Yahoo to xrmattaz
Wicked "drain and clean tank every season" ??
What season? Can't I just ride the damn thing year round?
'06 Gas Gas TXT 300 Raga
'06 Road Glide
'07 KLR 6fitty Red (sold)
'05 Zook SV650S Yeller "PocketBike" (gone...sniff)
'05 Zook DL1000K Blue (sold)
'00 Kawazaki SUPER Sherpa (sold)
and 80 more (sold)
xrmattaz is offline   Reply With Quote
Old 09-27-2006, 10:48 PM   #17
Mugwest
Friend.
Mugwest's Avatar
Oddometer: 5,208
I can kick in one that i have not seen ref'd before:
clutch adjust at the back of the airhead trans has always been sketchy and frustrating and required multiple trials n' errors before i could get an adjustment that i really liked. The reason is the close quarters between the thin 13mm locknut and the even-thinner 10mm adjust screw-- trying to use normal thickness wrenches here was aways dodgy, usually requiring several attempts to get it right with no clutch slip or drag.
Being an old-skool cyclist as well as moto-rider i'd had an idea in the back of my mind for a while: a thin shop-grade Park bicycle hub 13mm cone wrench. Well recently i finally followed through:
http://www.parktool.com/products/det...&item=SCW%2D13
$10 got me the shop-quality 13mm wrench, and i was even able to buy it locally (Bikes Plus), a double-yay!
This was the ticket-- this thing is thin enough to hold the locknut while any standard 10mm turns the adjust screw. Then a slight turn on the Park wrench and it's set. Perfect.
No more trial-and-error. The Park's even small enough to slip in place in the tool roll or stow in the tray or whereever.
It's the best $10 i've spent recently!
Mugwest is offline   Reply With Quote
Old 09-28-2006, 05:46 AM   #18
Bazza
Bazza's Avatar
Oddometer: 50
Spare Brushes
Solder circular connectors to your spare brushes. Then you don't need to carry a small soldering gun to replace failed brushes. Just attach the leads to the two nuts on the top end of the commentator. Don't forget to disconnect the battery when removing the front cover!
Bazza
1978 R100S
Plano Texas
Bazza screwed with this post 09-28-2006 at 05:35 PM Reason: a idiotic type!
Bazza is offline   Reply With Quote
Old 09-28-2006, 05:55 AM   #19
dragoon
I'm the REAL Dingo Joe
dragoon's Avatar
Oddometer: 22,846
If your bike quits in the rain
9 times out of 10 it's a cracked coil
Everyone should be so lucky as to be able to ride a motorbike through the Himalayas.
- Misery Goat
daveology rule #143 - never ever pass up a chance to hear a band that has a stand up bass -Mutineer
dragoon is online now   Reply With Quote
Old 09-28-2006, 07:26 AM   #20
elmoreman OP
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,761
Laugh
Right on, guys!!
I've already printed out a few things for my file...
elmoreman is offline   Reply With Quote
Old 09-28-2006, 08:51 AM   #21
hetkind
hetkind's Avatar
Location: North East TN - Shiny Side Up Motorcycle Rescue
Oddometer: 78
Send a message via Yahoo to hetkind
[quote=Bazza]Solder circular connectors to your spare brushes. Then you don't need to carry a small soldering gun to replace failed brushes. Just attach the leads to the two nuts on the top end of the commentator. ]
Or you could inspect your brushes every five years or so...there has been a spare set in my parts bin for the last five years, at least.
Been riding airheads 20 years and all I carry as spares is a bulb kit and tire plug kit, and my BMW MOA Anon book, never had to use the book however.
If you keep up your maintenance at home, on road issues are pretty scarce, though I did have my oil pressure sender fail earlier this week, and a headlight relay earlier this season, turn signal relay end of last season.
Do your maintenance and ride with a light heart
Howard
hetkind is offline   Reply With Quote
Old 09-28-2006, 09:58 AM   #22
kbasa
Tinaversal
kbasa's Avatar
Oddometer: 59,302
Send a message via Yahoo to kbasa
Gen light on halfway means the diode board is pooched. When you replace it, replace the mounts (which probably failed and caused the diode board to croak) with solid ones.
If you've got an airhead with the black coated cam chain cover, disconnect the batter, pull the front cover and scrape the black coating off that's under the diode board's grounding bolt. You might as well replace the diode board mounts while you're in there. The upper left one is a bitch. Don't drop the nut off the back into the cam chain!
Lube the final drive/rear wheel interface every time you change a tire. Do the shaft/final drive one every year. Clean all the old spooge off and use Honda Moly 60.
Be sure to check the little rubber nipple where the speedo cable comes out of the trans. If that gets cracked, it'll let water into your transmission.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 09-28-2006, 12:02 PM   #23
rnr
Simple. Fast. Paid for.
rnr's Avatar
Oddometer: 1,000
xrmatt: pain in the drain
(three stooges voice:) oh, a wise guy, eh?
Once a year. I ride year-round too. But once a year i competely drain, clean and dry the tank.
you'll be amazed how much watery gunk accumulates in there, even on an oft-used ride.
The boots stay on.
'08 Buell Ulysses
'97 BMW R1100RT
'93 Kawasaki KLR250
rnr is offline   Reply With Quote
Old 09-28-2006, 02:44 PM   #24
Xorba
Vintage Tourer
Xorba's Avatar
Oddometer: 44
There's a good list of airhead tips, tricks, and explanations that are organized online at:
http://www.slash5.net/htmlorg.html
Xorba is offline   Reply With Quote
Old 09-29-2006, 07:39 AM   #25
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 1,168
Originally Posted by zilla
Wouldn't have a part number handy, would you?
I'll look...but they only have one size lawn tractor battery. You do need to get the one with the post on the correct side.
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 09-29-2006, 07:44 AM   #26
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 1,168
Originally Posted by RatBob
Is there a real advantage to one of those? I've been very favorably impressed with sealed/AGM batteries on my other bikes. Lazy old pharte that I am, I really don't like to check/add water several times a season, so I'll spend a couple of bux not to have to.
$100 vs $22...I'll check the water once in a while.
-- Charles Kuralt
Old 09-29-2006, 08:20 AM   #27
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,975
Originally Posted by tvrla
I've had the Westco batteries that went dead in a year. At twice the cost they weren't a good deal, especially when the Panasonics last me forever.
This is especially gauling when you discover the Westco battery is simply a Panasonic battery.... with a Westco sticker on it.
Dat's da troof.
fwiw,
Lorenzo
Old 09-29-2006, 08:28 AM   #28
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,975
Your BMW dealer doesn't want you to know this....
Post '84 dual outlet Bosche coils will all eventually crack and fail. They're expensive to replace. Really expensive.
Stock HD/Buell dual output coils can be found on e-bay for about $1.oo. They're take offs from folks who've bought into the HD "dual fire ignition" myth. Good on them, I say.
I've had one on my '92 GS/PD for 30k kms now without issue....
fwiw,
Lornce
Old 09-29-2006, 08:37 AM   #29
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,354
Dat's da troof.
fwiw,
Lorenzo
Where did you get that data? The terminals are different. Westco may be using the Panasonics now, but the ones I had four years ago were different.
Old 09-29-2006, 08:38 AM   #30
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,975
[QUOTE=hetkind]
Howard
Hey Howard, what it is?
Should we invite these guys over to Airheads-Chat? You think they're ready? Or would it just tip the balance of "The Revolution"?
Not as tech-useful as the straight up Airheads list, of course, but maybe a lot more "entertaining".... http://www.airheads.org/content/view/21/46/
ciao,
Lorenzo
Times are GMT -7.   It's 03:17 AM.
