Old 09-30-2006, 09:02 AM   #46
andmoon
andmoon's Avatar
Oddometer: 3,188
When I got my airhead I was impressed by how quiet the heads were.
Noisey valves are happy valves....when the valves get quiet, it's a good idea to check the clearances.
andmoon is offline   Reply With Quote
Old 10-01-2006, 07:29 AM   #47
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,923
Originally Posted by Recht
Panasonic LC-X1220P
Digikey P-231-ND
Thank you sir!
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 10-01-2006, 02:38 PM   #48
boxertwinuk
GB Rider
Oddometer: 280
Hi Guys,
I've been looking for the Panasonic Battery here in the UK, but can't find an original Panasonic one, this is all I can find http://www.mdsbattery.co.uk/shop/pro...ctGroupID=1608
Can anyone tell me if this would be the same size as the Panasonic and if it'll fit without any problems?
boxertwinuk is offline   Reply With Quote
Old 10-03-2006, 11:25 AM   #49
jdiaz
Oddometer: 32,310
Originally Posted by boxertwinuk
Hi Guys,
The spec sheet says it replaces the Panasonic, but it looks like you'll need to make some terminals.
jdiaz is online now   Reply With Quote
Old 10-03-2006, 12:49 PM   #50
boxertwinuk
GB Rider
Oddometer: 280
Thanks for that.
Old 10-03-2006, 07:42 PM   #51
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,969
For anyone needing to unbolt connecting rods, I found today, Autozone carries a nice set of four 12 points including the 10mm required for this job. Best part, the price of the set sold under the name "OEM Industrial" is $12.99! I just happened into this as Solo Lobo was already kind enough to loan me his more authentic version.
-dubb
R-dubb is offline   Reply With Quote
Old 10-09-2006, 08:49 AM   #52
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I don't know how prevalent this is on airheads, but on my old beetle, it seems to happen about once every 2 years. And it just happened on my airhead and I had to wait about a week for the part.
Oil pressure sending unit. The plastic will crack or something and instant oil leaks. Sometimes bad enough that you are losing too much oil to continue your journey.
If you don't want to carry a spare one with you (which might get old and brittle by the time you need it, YMMV), go to the hardware store and buy a metric bolt. M12 x 1.5 is the type. Saw it off with a hacksaw to about 0.5" which is the depth of the oil pressure unit.
IMPORTANT!!! Make sure you de-burr, file, touch-up the cut you made so that there aren't any burrs. The reason is because usually the bolt you buy at the hardware store is going to be steel which will cut and mar the threads on aluminum engine block. Make sure the bolt will go almost all the way in by hand with minimal resistance.
And make sure you use the crush washer.
Also, on that same note, my stock tool kit did not come with anything that would fit the 24mm oil pressure switch. Might want to add a deep 24mm socket to the tool kit cause you're pretty talented if you can get it with a crescent wrench. (I couldn't.)
datchew is offline   Reply With Quote
Old 10-18-2006, 11:26 AM   #53
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,969
Cleaning & polishing old aluminum
I've got a method I've been using with great results. Thought I'd share.
Three steps:
  1. I clean the old part with any degreaser, really clean, and when dry, spray lightly with LPS electro contact cleaner to remove traces of solvent and other residue. The idea here is to have a uniformly clean surface to apply the next step.
  2. Wet the part with water (very important to avoid streaking). Then with great care (wearing rubber gloves, long sleeves, dust mask and eye protection) apply the phosphoric acid with a nylon paint brush. I brush it around over the whole part for about two or three minutes in a sink, rinse and repeat. Do not splash the rinse water or straight acid on your body---very harmful and toxic---. Rinse thoroughly again, air dry or use compressor. The part should now be very soft white in color. If it is blotchy, you probably didn't do a good job with step one.
  3. Now the fun part. This Flitz shit is amazing. Don't know what's in it. Some secret German formula. Apply with terry cloth just llike your mom's silver polish. An incredible amount of black oxidation will come off in the cloth. I did my carbs inside and out including the slides. After satisfied that you've got the worst of it, polish lightly with a clean bit of cloth and your done. It works wonders without a huge effort!
Before and After:
-dubb
BTW, at datchew's request I made this thread a sticky. Need more material. I'm sure there a million more ideas out there.
Old 10-18-2006, 11:43 AM   #54
elmoreman OP
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,770
I'm so proud...
my baby's all grown up into a sticky!
Some great info on this thread so far, definately one for airhead noobs to digest.
airhead aficionado
elmoreman is offline   Reply With Quote
Old 10-18-2006, 11:49 AM   #55
elmoreman OP
elmoreman's Avatar
Oddometer: 1,770
neutral switch
Some of you might have seen my photos in the last Airmail of a trip to Maine. In one of the photos I'm checking the integrity of my neutral indicator switch replacement. A few tips:
  • you do NOT need to remove the transmission
  • remove the thru bolt holding the spacer in place. This spacer prevents you from getting to the neutral indicator switch easily.
  • knock out the spacer with a drift, being sure to pad any areas that might get digned in the process.
  • file off leading edge of spacer so that it will return to its place more easily, then put it in the freezer for a while so that it might shrink a bit
  • Disconnect leads
  • replace the switch and washer (of course, be sure to drain the tranny oil first)
  • clean and then connect leads
  • gingerly knock the spacer back into place
  • clean thrubolt and add a light layer of grease
  • put it back in
  • ride off happy!
Snowbum covers this more extensively, but this could get you started. I waited a while to do it because not much fluid was leaking and I was a bit scared by the process. Turned out to be pretty simple, actually-just a lot of patience getting the spacer back properly.
airhead aficionado
Old 10-24-2006, 01:57 PM   #56
uptown
No stoppies on an Airhead
uptown's Avatar
Oddometer: 131
A super easy "duh I-should-have-thought-of-this-earlier" tip:
If you have a leaky petcock and don't feel like rebuilding it right away, try turning it to the "other" off position - 180 degrees from your usual off position. It might just keep your boot dry until you can get her back into the workshop!
uptown is offline   Reply With Quote
Old 10-24-2006, 02:08 PM   #57
uptown
uptown's Avatar
Oddometer: 131
Find out about the wealth of online resources for airhead information. Definitely not a complete list, just the ones I frequent the most. YMMV.
Snowbum's website
- put your HTML glasses on and deal with the non-existant navigation - it's worth it. Snowbum’s definitely a “take it apart and see how it works” type of mechanic.
Duane Ausherman's website
- the website is a little easier on the eyes, has some great tips and info. A former BMW dealer owner, and I would say a “if it ain't broken, don’t fix it” type of guy.
Of course, the Airheads website ($20/yr dues) and the Airheads List has the highest concentration of experienced Airheads, IMO. For the life of me I can't follow all of the listproc email threads, so I just search the archives on Micapeak (registration required) instead.
Boxerworks Forum. Not a super active forum, but exclusively for airhead owners. For me this forum seems like it’s a conversation between 10 guys that talk mostly amongst themselves, but are very willing to help out a n00b when they straggle in.
Let me know if there are some others that I am missing!
Old 11-02-2006, 05:25 PM   #58
Bazza
Bazza's Avatar
Oddometer: 53
Brushes
I solder connectors to the spare brushes that I include in my traveling spares kit. With the connectors soldered on I don't have to worry about carrying a soldering iron to repair failed brushes.
I also check the condition of the brushes every time I have the front cover off my righteous scooter. I carry the brushes for the unfortunate riders, those who don't carry spares, that might need spares brushes. I also include a rotor, diode spares and other items for the same reason. I love airheads!
One cannot alway plan on equipment failures. Why are accidents called accidents.
Bazza
1978 R100S
Plano, Texas
Bazza is offline   Reply With Quote
Old 11-02-2006, 06:07 PM   #59
Johann
commuterus tankslapperus
Johann's Avatar
Oddometer: 640
What I've picked up so far on GS paralevers....
1)When changing throttle cables undo jubilee clips holding carbs in place and push bings around horizontal to the ground to gain easy access to remove/fit new cables.
2)When removing/inspecting shaft budget on replacing paralever pivot bearings (only aboutb £10 a go).
3) Start developing a near obsessive interest in the quantity and quality of the swarf collected on the magnet on the gearbox drain plug (swarf per se is normal, soild lumps in swarf=bad)
4)Control cables seem to last about 40K. BMW cables are slightly more expensive than pattern cables bit at least you can guarantee they will be the correct length and be of good quality (don't ask!).
Johann is offline   Reply With Quote
Old 11-21-2006, 09:15 AM   #60
homerj
742 Evergreen Terrace
homerj's Avatar
Oddometer: 5,341
Lace replacement cables along side the current cables and zip tie them together. Cover the ends with duct tape. If a cable snaps mid ride you just have to swap the ends and you're back on the road.
09 570 Rallye Beast
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba…"-Hunter S. Thompson
homerj is offline   Reply With Quote
Times are GMT -7.   It's 02:03 AM.
