Old 07-08-2013, 10:45 AM   #826
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
Originally Posted by Plaka View Post
Get the government involved and you'll have to send in 30 for destructive testing, 15 for qualifications inspection and sell 7 to pay the taxes. That leaves you 3 at a cost of about $2.8~ ea. And you're still short a screw.
Plaka has it right... then you write another contract, ad infinitum ut nauseum! It is a time-proven way for the great American industrial complex to make money off of all of us, over and over....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 07-17-2013, 09:30 PM   #827
Sic Semper Tyrannis
Oddometer: 584
Originally Posted by photorider View Post
I looked for a while for a set of bar risers that would look good on an old Airhead with no luck. Then I remembered that a while back I got a used triple top plate that came with a set of crusty bar clamps and I had an idea...
Pretty happy with the result and my back is thankful on long trips.
As you can see form the pics, I have no fancy tools (not even a vise!) this was done on the kitchen table of my apt. with a hacksaw and some sandpaper. Old cables worked just fine.
Wow that is great.
Love to see what you'd pull off with a mill!
I have one and it is sweet for projects like this.
Sic Semper Tyrannis is offline   Reply With Quote
Old 07-25-2013, 12:36 PM   #828
Plaka
Brevis illi vita est
Oddometer: 4,588
That's very nice hand work!. I have done exactly the same thing, using as much of the lower clamp as possible. About 1" rise. problem is, I used studs rather than bolts. I just don't like threading in and out of aluminum any more than I have too. But I couldn't go up to an M8, not enough metal. To get an M6 long enough I had to go to fully threaded. I don't trust long all-thread anythings unless the alignment is exact. Any small side loads or twists and they will crack eventually. Pure tension/compression only. I'm running them, cautiously, for now. Eventually I will get them skimmed for match and parrallelism in a mill.
I ran into clearance problems on the /7 with the instruments. They don';t go up when the bar does. So the clutch cable is mightly tight on the speedo cable at the back of the pod. Will see how that goes.
Old 07-25-2013, 12:38 PM   #829
Plaka
Oddometer: 4,588
Jiffy easy flip lever throttle lock.
Before I launch into some big write up, has this one been covered?
Old 07-26-2013, 10:16 AM   #830
Gripsteruser
Service Monkey
Oddometer: 753
Haven't seen this issue here (and I've read all the postings !)
1988 R100GS. Lost all ignition around 37,000 mi.
Roadside wrestling didn't reveal the cause exactly because the problem went away as I moved wires in troubleshooting and hasn't returned but I noted that the wiring harness sags enough to rest on top of the engine case and is slack.
Vibration was wearing flat spots in the wire insulation of the wires in the harness touching the engine top.
Some plastic flex conduit was applied around the wire harness as a preventative. I recheck it periodically for more flat spots. (Best fix would be to secure it better and I proably will soon.)
I'm sure that in the event of insulation wear thru that the wire harness would blow to protect any applicable fuses.
(Saw this is the BMWMOA magazine a long time ago but it bears repeating for those with older bikes. Wire harness destruction would be a Bad Thing.)
Gripsteruser is offline   Reply With Quote
Old 07-26-2013, 07:25 PM   #831
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
[QUOTE=
Wire harness destruction would be a Bad Thing.)[/QUOTE]
Quite the opposite. The fuzes are there to protect the harness and devices it's hooked up to.
DoktorT is offline   Reply With Quote
Old 07-26-2013, 08:50 PM   #832
Gripsteruser
Service Monkey
Oddometer: 753
You'd like to think so but Murphy rules.
Old 08-18-2013, 08:17 AM   #833
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,416
Originally Posted by boxerboy81 View Post
Here are the usual options for the R100RS fairing. I'm unsure if this applies at all to the RT.
#1 is my preferred option. Cheap, 30 second install and removal, reusuable, sturdy and they do the job looking like they should be there. They're an autoupholstery fastener available from car shops and just push straight in. I've used them for years.
#2 is a common choice. Nut and bolt. Tedious, takes forever to install/remove, can crack the screen, but doesn't need the copper rivets.
#3 is oem. Tedious little sucker unless you really know how, or have the right tool. Not cheap for what they are, and from BMW dealers/suppliers only I'm guessing.
The copper rivet can be installed and flared on the bike using a countersunk bolt/nut like shown. Easy as pie.
Here's a 3 minute video showing how long it takes to fit, remove and replace the R100RS screen using the #1 choice from the picture.
https://www.youtube.com/watch?v=atWO...ature=youtu.be
boxerboy81 screwed with this post 08-19-2013 at 04:46 AM
boxerboy81 is online now   Reply With Quote
Old 08-19-2013, 09:49 AM   #834
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,715
FYI -
McMaster Carr makes a really decent box of black pop rivets (plastic breakways just like OEM), but they're about 10x easier to install, and less 1/4 of the price of OEM.
I've used both, the MC's are much better.
And can be installed easily with any typical pop rivet gun (cheap) and some experience using one.
http://www.mcmaster.com/#90219a330/=o4th0n
2011 Duct Tape Roll
1997 Cycle Therapy mini pump
1988 Aerostich Fleece collar scarf
1992 BMW K100 transmission housing
2014 Box of General Tso's Chicken with Xtra spice
Zodiac screwed with this post 08-19-2013 at 10:05 AM
Zodiac is offline   Reply With Quote
Old 08-19-2013, 12:04 PM   #835
shearboy2004
KIWIINUSA
shearboy2004's Avatar
Oddometer: 4,393
Been hunting around for bulbs for tach and voltmeter on my 88 R100GS .
Found Mercedes uses them too so picked 4 up for $7.89
Mercedes part number 78180
88 R100GS
75 Norton Commando Roadster
98 DR450
07 Sherco 510 called Holy Shit .450 Sherco called Bling .
13 Sherco 300i called The Bee's Knees .
shearboy2004 is offline   Reply With Quote
Old 08-19-2013, 01:08 PM   #836
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
just installed Boxerboys #1 solution and it works and looks great.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 08-19-2013, 01:12 PM   #837
Flying-D
Just Passing Through
Flying-D's Avatar
Oddometer: 2,615
What is Boxerboys #1 solution?
It's really all just stuff...and in the end, none of it means shit.
Flying-D is offline   Reply With Quote
Old 08-19-2013, 01:59 PM   #838
Zebedee
Zebedee's Avatar
Oddometer: 799
... here's a bit of a clue for 'ya.
Try using the scroll wheel on the mouse, or even the up arrow on the keyboard.
The answer is a couple of posts up ON THIS BLOODY PAGE ...
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 08-19-2013, 02:00 PM   #839
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Here. Post 833.
Old 08-19-2013, 07:35 PM   #840
Flying-D
Flying-D's Avatar
Oddometer: 2,615
Sheesh! Even more !
Times are GMT -7.   It's 07:28 AM.
