Old 10-16-2013, 08:29 AM   #871
luxlogs
luxlogs's Avatar
Oddometer: 302
Originally Posted by Plaka View Post
What I need is the width of the clamp and the diameter that has to be clamped. if you clip the tie, just lay it out on the table and measure from one end to the other. Clip well away from the litte lock thing. Need the dimension to the 1/16" if possible. If it looks like the clamp can be wider, note that. Narrower generally cuts into the rubber.
Dia of clamp at Trans 10.5"
width of clamp at Trans 4/16
Hope this Helps
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
luxlogs is offline   Reply With Quote
Old 10-16-2013, 09:45 AM   #872
Plaka
Brevis illi vita est
Oddometer: 4,611
Hope this Helps
Is 10.5" the length of the clipped clamp or the measured Diameter of the rubber? Pretty big diameter!.
4/16" = 1/4", right?
Old 10-17-2013, 07:23 AM   #873
luxlogs
luxlogs's Avatar
Oddometer: 302
Tied a washer to a string, wrapped string around rubber boot at trans. Brought end of string thru washer and drew tight. Pinched string below washer and pulled string out. Measurement from washer to fingers 10.5".
Yes 4/16 is 1/4
Repeated at rear of boot since I was already out there. 12" but clamp is only 3/16 wide here.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
Old 10-17-2013, 07:36 AM   #874
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,979
10.5/3.14=3.34
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 10-17-2013, 07:41 AM   #875
Plaka
Oddometer: 4,611
Yes 4/16 is 1/4
Ah..that would be circumference.
Old 10-17-2013, 08:43 AM   #876
Gripsteruser
Service Monkey
Oddometer: 859
That would be the most valid measurement. The forward portion of the rear boot fits over an oval opening in the swingarm.
Gripsteruser is offline   Reply With Quote
Old 10-19-2013, 06:25 AM   #877
luxlogs
luxlogs's Avatar
Oddometer: 302
Originally Posted by Stagehand View Post
10.5/3.14=3.34
Forgot about Pi or is it Pie? Sorry learned about that in the 70's in a haze of blue smoke. Ha learned, thats funny didn't learn shit.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
Old 10-19-2013, 07:02 AM   #878
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,970
It is Pi. Although the Greek letter is more correct. 3.141592653 is about the max I can remember even with short term memory. I meet a young fella once that recited Pi to 40 digits for me. He said he hadn't done it in several years but if he brushed up a little could probably do 80 or more. I listened very intently and then pronounced every digit correct.
---Albert Einstein
disston is online now   Reply With Quote
Old 10-19-2013, 09:19 AM   #879
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
The ancient Hebrew/Egyption Royal cubit in inches as determined by Newton=20.612.
A primary ancient geometric construction is 3 to the 8th power = 6561.
20612/6561=Pi
Linking the ancient cubit to the English inch to an accuracy for Pi not exceeded prior to NASA.
DoktorT is offline   Reply With Quote
Old 10-20-2013, 04:59 AM   #880
luxlogs
luxlogs's Avatar
Oddometer: 302
20612/6561=Pi
The level of intelligent beings never fail to amaze me on this forum.
ABC # 11808
74 911S
87 TW200
82 R65LS
92 R100GS
Old 10-20-2013, 03:59 PM   #881
Plaka
Oddometer: 4,611
Reading Kant and Understanding Kant are very different propositions.
Old 10-21-2013, 06:45 AM   #882
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
Very true, but the individual that seeks out Kant as reading material at least deserves the credit for attempting to understand.
Kai Ju is offline   Reply With Quote
Old 10-21-2013, 09:00 AM   #883
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,970
I have a couple of Kant books on the shelf. Have never even tried to read them. They are decoration.
---Albert Einstein
Old 10-21-2013, 09:35 AM   #884
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
About 2 pages of Kant was enough for me.The info on Pi I gave requires no more than compass and straight edge to demonstrate and a bit of grade school algebra to comprehend fully, though it was the result of several decades of research and study of metrology ancient and modern. Nothing at all like metaphysics which is crawling with a few charlatans, not unlike this forum.
DoktorT screwed with this post 10-21-2013 at 09:47 AM
Old 10-21-2013, 12:00 PM   #885
Plaka
Oddometer: 4,611
Not necessarily. They may have no interest whatsoever. But one should be careful to have the book right side up when doing the look-at-me thing...
Times are GMT -7.   It's 06:21 PM.
