Old 02-28-2007, 07:59 AM   #76
ROSKO
The Dirty Knacker
ROSKO's Avatar
Oddometer: 413
I haven't seen this one mentioned yet....
Buy an EXTRA clutch cable and zip-tie it into place along your existing cable. Cover the end w/ a bit of saran wrap then a bit of tape to keep the crap out. This way if you ever snap a cable far from home (or civilization) you can just swap in the new cable.
ROSKO is offline   Reply With Quote
Old 03-01-2007, 05:18 PM   #77
MotoMax
Caffine shakes anyone?
MotoMax's Avatar
Oddometer: 453
Not sure if this was mentioned yet. . .
I didn't get through this entire thread yet. . . but I really neat trick is, instead of having to back the ground screw from the battery all the way out everytime you need to kill the power, just clip a notch in the cable end big enough for the bolt. That way you can loosen it and pull the cable and make for easier intallation. Hope this helps. . - MotoMax
"A shot of espresso is worth another 100 miles. . . . " - Moto
Airhead # 9189
MotoMax is offline   Reply With Quote
Old 03-11-2007, 08:44 PM   #78
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,210
When replacing the carbs how do you know when they're level? I'm not sure it makes a whole lot of difference, but I like getting them even and in the same position every time. At least it'll keep the same tension on the cables so they don't need re-adjusting. Use a short (about 9") level and hold it to the bottom of the float bowl in front, adjusting the carb till the bubble is centered. Sure is quicker than eyeballing them to see if they look right.
I'm not real fond of notching the ground attachment eye. I like having all the grounding surface I can get, and I also prefer not to touch the trans ground mount/breather bolt at all. I just disconnect at the battery instead. I know, it takes a little bit longer than loosening the trans grounding bolt, but there aren't many threads in there and it's a real pain to fix when they go.
Along that same line, if the threads do strip out, there's a trans cover mounting bolt a few inches closer to the battery. But it's a counter-sunk allen head. You'll need to get a longer one - the length of the head - about ten mm - and enough washers to fill the hole. Attach the ground there. I've heard of guys running the ground to a point on the frame where all the other grounds attach, but don't think that's a great idea. The reason is that the starter motor puts a heavier drain on the battery than anything else on the bike. The ground needs to be as close to the starter as possible with the fewest connections to travel through.
Wirespokes screwed with this post 03-11-2007 at 08:57 PM
Old 03-12-2007, 03:47 AM   #79
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Originally Posted by jtwind
7) Service the air filter, i.e., put a new one. DO NOT blow out air filter with compressed air, do not leave a K&N filter in at all.
i just caught this comment on the k&n air filter. my 1-month old pd has, in fact, a k&n filter installed. should i lose it and why?
i'm still on the steep learning curve with my airhead and i noticed that my plugs are on the whitish side than i'd like. no amount of tweaking, cleaning, etc. on the carbs would make them the light coffee-brown color i want. the air filter is well-oiled (I made sure of that when i took delivery of the bike), and I still get this same, lean-burning color on my plugs. is the k&n too open? anyone know and can share any bad experiences in using them?
opposedcyljunkie is offline   Reply With Quote
Old 03-12-2007, 05:40 AM   #80
RandyB
Oddometer: 5,072
Some have had to rejet to larger jets with the K&N. Contact Bing. You may need to clean your idle jets too.
RandyB is offline   Reply With Quote
Old 03-12-2007, 05:52 AM   #81
Wirespokes
Wirespokes's Avatar
Oddometer: 8,210
The K&N tends to either not fit correctly or shrinks so it doesn't seal properly, allowing dirty dusty air through. We're talking about the rectangular style on the '81 and newer airheads.
Old 03-12-2007, 06:05 AM   #82
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
yes, i would think that the k&n i have is the same, standard one used since '81.
i did check mine and it seals alright, as far i can see. should i lose it and use the original bmw air filter? i had a strong feeling that these original carb jetting were designed for the original paper filter.
Old 03-12-2007, 06:29 AM   #83
Wirespokes
Wirespokes's Avatar
Oddometer: 8,210
I have no experience with the flat airhead K&Ns. But there are guys who feel very strongly about them saying to ditch them NOW! If it's sealing, I'd keep an eye on it to make sure it stays that way. Monitor it.
An easy solution to the jetting issue would be to try lifting the slide needle a notch. In other words, move the clip down the needle one notch.
Old 03-12-2007, 05:27 PM   #84
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
I've tried that and it ran way too rich. It's currently on its stock setting of 3rd notch from the top. And it's running a bit lean in the whole throttle range. That's why I'm looking at the air filter as the culprit.
Old 03-13-2007, 12:44 AM   #85
Wirespokes
Wirespokes's Avatar
Oddometer: 8,210
The needle should only affect throttle openings from 1/4 to 3/4. It does sound like it's getting a lot more air to affect it throughout the range.
Old 03-18-2007, 08:26 PM   #86
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
my next investigation would be the carb-to-head hose, leaking exhaust joints, and the round top of the carb which gets loose over time and causes air leaks.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
Old 03-20-2007, 09:41 AM   #87
face scrape 2001
face scrape 2001's Avatar
Oddometer: 85
Thumb alcohol is your friend
Originally Posted by rnr
(three stooges voice:) oh, a wise guy, eh?
Once a year. I ride year-round too. But once a year i competely drain, clean and dry the tank.
you'll be amazed how much watery gunk accumulates in there, even on an oft-used ride.
Maaate, all ya gotta do is chuck a litre of methylated spirits in the tank,, (no, don't ) it soaks up the water, it mixes with the petrol nicely and gives your m/c a bit more ooomph too. once a year is enough it seems for me.
face scrape 2001 is offline   Reply With Quote
Old 03-20-2007, 10:25 AM   #88
face scrape 2001
Oddometer: 85
[QUOTE=opposedcyljunkie]i just caught this comment on the k&n air filter. my 1-month old pd has, in fact, a k&n filter installed. should i lose it and why?
"Debunking the K&N Myth - Why OEM is Better"
is an article on a Nissan car Club site : http://forums.nicoclub.com/zeropost?...ply&id=1863139
which I've read closely, and the OEM stuff comes up trumps. BMW use Purolator, and the rate quite well on this survey/test .
I have also noticed it myself, I had a sponge re-useable air filter for a while, and i cleaned it sometimes, but I did notice that the size of the grit stuck in the oil inside the aircleaner box was much bigger than when I had the paper filter. I went back to using the original air cleaner, they work!
The article goes to eight pages, has various graphs is written by an enthusiast and doesn't try and sell anything except curiosity about OEM and aftermarket shit comparison.
OOOPs, I cut and pasted it here, maybe it'll get deleted, but if not, hey. but I did notice that the graphs did not come through.
For decades, the aftermarket hot rod, racing and tuning communities have relied on oiled-media filters to free up that extra few horsepower. In fact, it's often one of the FIRST modifications many automotive enthusiasts do to their car.
This report shows, with empirical data and sound reasoning, why OEM filters perform better in a variety of areas.
Special thanks to Arlen Spicer and all others involved in making this information available.
A note from the author:
The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature. Gentlemen and Ladies, Marketing and the lure of profit is VERY POWERFUL! It is amazing how many people believe that better airflow = more power! Unless you have modifications out the wazoo, a more porous filter will just dirty your oil! Some will say " I have used aftermarket brand X for XXX # years with no problems. The PROBLEM is you spent a chunk of change on a product that not only DID NOT increase your horsepower, but also let in a lot of dirt while doing it! Now how much is a lot? ANY MORE THAN NECESSARY is TOO MUCH!
Others are persuaded by the claims of aftermarket manufacturers that their filters filter dirt "better than any other filter on the market." Sounds very enticing. To small timers like you and me, spending $1500 to test a filter sounds like a lot. But if you were a filter manufacturer and you believed your filter could filter dirt better than any other media on the market, wouldn't you want to prove it? Guess what. Test your filter vs. the OE paper. It will cost you $3000 and for that price you will have the data that you can use in your advertisements. Your investment will be returned a thousand fold! EASIER than shooting fish in a barrel! So why don't these manufacturers do this? Hmmm? Probably not because they would feel guilty about taking more market share.
Now I am not saying that ALL aftermarket filters are useless. A paper filter does not do well if directly wetted or muddy. It may collapse. This is why many off-road filters are foam. It is a compromise between filtering efficiency and protection from a collapsed filter. Now how many of our vehicles collapse their filters from mud and water?
However, if a filter is using "better airflow" as their marketing tool, remember this....Does it flow better? At very high airflow volumes, probably. BUT, our engines CAN'T flow that much air unless super-modified, so what is the point? The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give. And this remains true until the filter is dirty enough to be recognizeable. At that point performance will decline somewhat. Replace the filter and get on with it.
Hopefully the results of this test will do 2 things. Shed some light on the misleading marketing claims of some aftermarket manufacturers and/or give us new insight on products already on the market that are superior to our OE filter.
SCOPE:
This report presents the results of an ISO 5011 test of several air filters designed for the GM Duramax Diesel. The test was independently performed under controlled conditions using a $285,000 machine at Testand Corp of Rhode Island (manufacturer of the machine).
Arlen Spicer, a GM Duramax Diesel owner/enthusiast organized the test. Testand offered to perform the tests at no charge. (These tests typically cost approx $1700.00 per filter). Ken (and employee of Testand), a Diesel enthusiast and owner of a Ford Power Stroke Diesel, shared Arlen’s interest in performing an accurate unbiased test of different types and brands of diesel engine air filters.
The filters used in the test were purchased retail and donated by Arlen and other individual Duramax Diesel owners. The detailed reports from the test have been compiled and are presented in the following pages. The final pages of this report present the behind the test.
ISO 5011 Test:
The ISO 5011 Standard (formerly SAE J726) defines a precise filter test using precision measurements under controlled conditions. Temperature & humidity of the test dust and air used in the test are strictly monitored and controlled. As Arlen learned in attempting his own tests, there are many variables that can adversely affect filter test results. A small temperature change or a small change in humidity can cause the mass of a paper filter to change by several grams.
To obtain an accurate measure of filter efficiency, it’s critical to know the EXACT amount of test dust being fed into the filter during the test. By following the ISO 5011 standard, a filter tested in Germany can be compared directly compared to another filter tested 5 years later in Rhode Island. The ISO 5011 filter test data for each filter is contained in two test reports; Capacity-Efficiency and Flow Restriction.
Capacity and Efficiency:
The Capacity and Efficiency test report presents the test results of feeding an initially clean filter with PTI Course Test Dust (dirt) at a constant rate and airflow. The course test dust has a specific distribution of particle sizes ranging from less than 2.5 microns to greater than 80 microns (see table below).
Every filter is initially tested at 350 CFM and the Initial Restriction or differential pressure across the filter is recorded in IN-H20 (Inches of Water). The filter is then tested by feeding test dust at a nominal rate of 9.8 grams per minute with a constant airflow of 350 CFM. The test is continued until the flow restriction exceeds the Initial Restriction + 10 IN-H20.
At this point the test is terminated and the amount of dust passed through the filter (Accumulative Gain) is measured. Dirt passing through the filter is captured in the Test Station’s Post Filter. The exact amount of dirt passed is determined by measuring the before and after weight of the Post Filter.
Similarly, the amount of dirt retained by the Filter under test - Accumulative Capacity – is measured by taking the difference between the before and after weights of the Filter. From these results the overall % Efficiency of the filter is calculated. This test also indicates how long a Filter will last before replacement is required (or cleaning for reusable filters).
Flow Restriction:
This report presents flow restriction of a clean filter resulting from an increasing airflow. The differential pressure restriction across the filter is reported in inches of water (IN H2O) versus Air Flow in cubic feet per minute CFM.
Data from these reports has been compiled and presented in the following bar graphs, plots and data tables.
Filtering Efficiency:
Filtering efficiency is a measure of the filter's overall ability to capture dirt.
Accumulative Capacity:
“Accumulative Capacity” is a measure of dirt holding/loading capacity before reaching the maximum restriction limit.
Accumulative Gain:
"Accumulative Gain" is the total amount of dirt that passed through the filter during the test.
(Note: The Purolator was reported to have a seal malfunction during the test and passed more dirt than it would have with a good seal.)
Initial Restriction:
Initial Restriction is the Filter under test’s resistance to flow at 350 CFM.
Dirt Passed Versus Total Test Time
This graph shows each the duration of each filter’s test versus dirt passed (Accumulative Gain).
In the chart above it’s important to note the different test durations for each filter. The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction.
In 60 minutes the AC Filter accumulated 574gms of dirt and passed only 0.4gms. After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms.
Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt. See the data tables for a complete summary of these comparisons.
Dust Loading:
The dust loading curves show graphically how each filter responded to a constant 9.8 gms/min dust flow before reaching the maximum restriction limit.
It’s interesting to note the shape of these Dust Loading Curves. The AC and Baldwin filters each had near linear responses until reaching maximum restriction. Restriction for these filters increased at a constant rate versus the 9.8 gms/min dust feed rate.
The other filters, most notably the oiled reusable types, had an exponential loading response before reaching maximum restriction. These filters had a lower initial restriction, but they became exponentially more restrictive under a constant flow of dirt.
This runs counter to the "myth" that oiled media filters actually "work better" as they get dirtier.
Also notice the length of the curves as it shows the relative test time for each filter (time to max restriction).
Restriction to Flow:
The Restriction to Flow curves graphically show how each “clean” filter responded to a steadily increasing flow of air up to 350 CFM.
The Flow Restriction response curves for each filter have the same basic shape. However, note how the AC Filter, which passed the smallest amount of dirt and had the highest dirt capacity and efficiency, also had the highest relative restriction to flow. The less efficient filters correspondingly had less restriction to flow.
This illustrates the apparent trade-offs between optimizing a filter for dirt capturing ability and maximum airflow.
face scrape 2001 screwed with this post 03-20-2007 at 10:34 AM
Old 03-20-2007, 03:43 PM   #89
Beemerboff
Oddometer: 2,331
Pissed
Back to the carb question - are the springs above the slides still fitted ?
Not all bikes had them ,so someone may have left them off, but they help to richen the mixture in transition.
And do you have the correct needles - I spent a lot of time on the carb on my BSA B44 VS before discovering that I had been supplied with the wrong needle - the symptoms were the same as yours and the correct needle fixed things instantly .
Dont know how to check the bing ones though
Beemerboff is online now   Reply With Quote
Old 03-20-2007, 08:21 PM   #90
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
i pressume your questions are for me.
yes, the springs are there. my needles are the correct, original ones but i noticed some pitting on the upper area. could be affecting fuel flow? anyway, new needles are on their way.
as for the lean running, i will check furhter for air leaks this weekend. air leaks can only come from a few areas...
OCJ
92 R100GS-PD Euro
07 R1200GS
Times are GMT -7.   It's 12:16 AM.
