Old 04-10-2014, 07:02 AM   #931
RagerToo
vroom vroom
Oddometer: 303
front brake hose grommets
34 years and I guess my front brake hoses were 'used too much when they were new'. (The bike is new to me only a bit over a year+. 50k. And a shout to Max's, ordered stuff on Sat. last, got my goods Wed. afternoon, USPS.)
The grommets are tight, well yeah. I put a spot of Kroil on them and proceeded. Shiver me timbers there's the outside groove and there's the inside groove, and I suppose I could have ground a small screwdriver soft and smooth to not mung up the grommet.
Then I remember I had a couple of brass typewriter tools. One has a rounded "seal pic" end on both ends and the other looks just like a rounded down screwdriver on one end.
Installed the grommet in the mounting horseshoe and shoved the new hose end in and carefully pushed the inner lip into the hose end groove, a bit at a time. And alls well.
Noticed the left fork tube (top) is just touching the orig RS headlight mount at lock. Gotta bend it out of the way a touch, or something. I already had adjusted it. Pulled the throttle apart and re-lubed that piece of art.
'80 R100RS but nekkid
Some folks still insist on going to a gun fight with a popsicle stick sharpened on the driveway.
RagerToo is offline   Reply With Quote
Old 04-22-2014, 10:11 AM   #932
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 590
I just got a new ignition for my GS, an Alpha system from Risk.
I've never timed my bikes before, and I will need to learn. I'm also working on my VW Bug so I need to be able to set the timing for that as well.
My questions is, what is the recommended timing light/dwell meter that you guys suggest I get? I have a friend with a good light, but I figure with al my airhead motors and my brother's and father's it makes sense to get a good light.
KhaoSanMan is offline   Reply With Quote
Old 04-22-2014, 10:43 AM   #933
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,543
Brand is not too important. Better made units will cost more, usually. You want a unit that uses a magnetic pick up. This is the clamp that fits around the plug wire to pick up the signal. Most modern lights will have this but if you buy a used unit on Ebay or something you may get a light that has a spring that fits on top of the spark plug and the signal wire clamps onto this.
Sorry about the size of the image. I have no control of that feature.
This is a standard type timing light. Notice the pick up that is the pink clamp. This unit also does not have an advance control feature, something on more expensive units and that you do not need. Harbor Freight has timing lights for less than $50.
The timing light is hooked to the vehicle battery to get power. There is another type that uses batteries in the light and doesn't cost much more.
I've been thinking of getting one of these. I've seen them for sale at Amazon.com
You mention a "dwell meter". This is something different. It is only used for ignitions with ignition points not electronic.
---Albert Einstein
disston is online now   Reply With Quote
Old 04-22-2014, 11:24 AM   #934
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 590
Thank you Disston!
I bet the Harbor Freight light will be more than sufficient for my needs, I just wanted to check if there might be any major issues with them or if there was a preferred light to that one.
Old 04-22-2014, 11:27 AM   #935
Les_Garten
Les_Garten's Avatar
Oddometer: 732
Originally Posted by KhaoSanMan View Post
Thank you Disston!
Just a thought, but if you get a computerized timing light you can measure exactly how many degrees you are set at. FYI.
<<This is my Airhead, there are many like it, but this one is mine>>
My "Orange Snappy Club" Membership Photo
Les_Garten is offline   Reply With Quote
Old 04-22-2014, 11:40 AM   #936
RagerToo
vroom vroom
Oddometer: 303
Do you find that, I assume, what you have, is accurate?
I have a 25-30 yr old light, with a pot/ dial for advance. Probably a no-name by now, it was from when they were first coming out. I've never relied on the advance readings to be accurate. Mostly used to just find a mark that was way out of spec. I'm not even sure I've timed my bike with it yet.
Old 04-22-2014, 12:07 PM   #937
Les_Garten
Les_Garten's Avatar
Oddometer: 732
This is like the one I have and it is very handy.
Usually go around $75-$125 on Fleabay. I've had mine about 25 years or so.
Old 04-22-2014, 11:38 PM   #938
RagerToo
vroom vroom
Oddometer: 303
Aha! Shweet. I have my bike, a fully computerized (ford) Contour and my service truck, a plain, vanilla '91 Super Duty (F450), 7.3L NA diesel.
The next thing I'll need a light for will be my 8000lb Hyster project. (oh ghod)
Old 04-25-2014, 04:21 AM   #939
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,536
After decades of timing lights and wires to clip to batteries, getting one of these cheap things is the best thing I've done for timing.
Timing advance worked best on the old big box tunescopes - you could dial up the degrees on the screen and know it was pretty accurate, the ones with the dial on the end I wouldn't trust....but push button electronic like the Snap-On are real good.
motu is offline   Reply With Quote
Old 04-25-2014, 07:00 AM   #940
RagerToo
vroom vroom
Oddometer: 303
A friend _has_ one of those _tunescopes_. SUN brand if I'm not mistaken. Big ole' dial on it, has it mostly as a display, I doubt he's ever used it.
Old 04-25-2014, 09:19 AM   #941
larrylarry75
Aye Chihuahua
larrylarry75's Avatar
Oddometer: 329
electrical power upgrade?
Hi People,
I've just adopted a '92 Bumblebee and the PO said the power system had been upgraded for a higher capacity. How do you check for something like that? It has factory heated grips and that seems to be it in the way of accessories. There's a power outlet for running a heated vest or maybe gloves? My vest heats up so I know it's working. I'm just learning my way around this beastie and I'd really appreciate your input.
Thanks,
LL75
larrylarry75 screwed with this post 04-25-2014 at 10:09 AM
larrylarry75 is offline   Reply With Quote
Old 04-29-2014, 12:27 AM   #942
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,519
Originally Posted by larrylarry75 View Post
Hi People,
Thanks,
LL75
After you disconnect the battery earth at the battery, pull the front cover and check if the alternator looks new. The question probably belongs in it's own thread as this one is more for telling "tips & tricks".
boxerboy81 is offline   Reply With Quote
Old 05-03-2014, 03:48 AM   #943
Skyshadow
Skyshadow's Avatar
Oddometer: 637
didn't want to start a new thread...but have a good tip. Every year or two, undo the exhaust fins and reapply antiseize to the threads. My G/S had been out in the weather quite a bit and got some rust here and there. The fin nuts? they spun right off just recently.
no sense risking damaged threads.
Skyshadow is offline   Reply With Quote
Old 05-03-2014, 05:46 AM   #944
Flying-D
Just Passing Through
Flying-D's Avatar
Oddometer: 2,665
I think that's pretty much always been recommended as an annual thing...
It's really all just stuff...and in the end, none of it means shit.
Flying-D is offline   Reply With Quote
Old 05-03-2014, 08:21 AM   #945
Skyshadow
Skyshadow's Avatar
Oddometer: 637
I heard it occasionally....but more often talk about cutting the nut off or replacing damaged threads prevailed so probably not as common as it should
Times are GMT -7.   It's 06:12 AM.
