08-13-2007, 07:23 AM
#1501 | |
Rally On
Oddometer: 4,583
#1502 |
Xtankteam™
That's exactly what I am thinking of, an extra set of Xcountry wheels with a nice set of streetish tires on them.
08-13-2007, 07:58 AM
#1503 | |
Genuine Adventurer
Oddometer: 282
![]() To reply to what Xchallenged wrote; I do not agree that a broken frame and cracked engine case is a "miniscule problem", especially if one was on a world tour and this happened in a remote region. |
08-13-2007, 08:01 AM
#1504 |
A nation in despair
Oddometer: 21,040
One year, IIRC, KTM offered the 625 SMC with two sets of wheels included. One set was 17" f & r and the other 18" and 21".
I wish BMW would offer same for a reasonable cost to those of us who bought either the Country or the Challenge so we could convert from one to the other. OTOH, probably BMW thinks it's better if guys like me ADD a Challenge to my Country rather than just a set of wheels. |
08-13-2007, 08:04 AM
#1505 | |
what attitude problem???
Just some dude on the internet,.. |
08-13-2007, 08:05 AM
#1506 |
Ronin
Oddometer: 1,838
TT skidplate.
I had a hard time finding Dynamat (O.K. I didn't try really hard) in my area. So while browsing in the auto parts store, picked up a can of rubberized undercoating and sound eliminator. Was too lazy to do a before/after sound test on the bike...but I will say it is an alternative to the Dynamat. Although I haven't heard what an X with Dynamated skidplate sounds like, the undercoated one didn't bother me at all. Possibly a tad more mechanical noise when at a stop, but when moving tire noise and wind noise was about all I could hear. Rocks pinging off the bottom was quieter too. Stock one had a "ping/ting" noise, now it is a dull thunk. On the trail it took me a bit to figure out what was sounding different...it was the lack of ping, ping from rocks. Think it was $8 for the can of undercoating.
08-13-2007, 09:15 AM
#1507 | |
Two Sheds
Oddometer: 2,052
Skid Plate Noise
Hey: I think all the noise comes from the front of the plate, by the exhust pipe. It's not mounted to anything and just vibrates like a rubber band. I used two cable ties to pull the plate taught. ![]() ![]() A better way would be to make a mounting point, it would make the plate stronger too! But this was a 5 minute fix. This cut out the sound I think you guys are talking about. The tire noise on the road is a different matter. The way I fixed that was to ride as little street possible.
08-13-2007, 10:45 AM
#1508 | |
Genuine Adventurer
Oddometer: 282
FYI: The LC4 SMC was 17" only and came street legal in the US. The KTM that came with two sets of wheels were the RFS 450SMC and 525SMC (both 4 speeds) and were sold that way in the US (only the US, maybe CA, AFAIK). These 450/525SMCs were actually SX MX bikes (4 speeds) with the KTM SM kit. I owned a 450 and raced supermoto two years ago, the steering geometry of the SX MX setup when going down from 21" to 17" front wheel was a compromise compared to the SMR version (SX tuning with 6 speeds) whose rake/trail was matched to the 17" wheel. |
08-13-2007, 08:44 PM
#1509 | |
Oddometer: 1,416
http://www.crutchfield.com/S-MJj62ZKJQFH/ Zollo |
08-13-2007, 11:50 PM
#1510 |
Flogster
Oddometer: 281
Sprockets
Quick question for those in the know.
Some posts here re the change to a 14T front sprocket, is there a reason you did not go with a bigger back sprocket rather, and do BMW sell a 14t or do I need to look elsewhere? Thanks. |
08-14-2007, 12:04 AM
#1511 | |
Oddometer: 366
TT also sells a 14t as well. As for an answer to your question. I do not know since I have not done the swap myself but I look forward to the answer. Doug
'06 R1200GS '07 G650 X-Challenge |
08-14-2007, 12:26 AM
#1512 |
Xtankteam™
Switching from 15 to 14 on the front is easier that replacing the rear sprocket. At least the chain will be long enough, which is always the question when you use a 3 tooth larger rear sprocket.
But ideally I would like a 15 tooth on the front, and a larger rear sprocket, to reduce chain and front sprocket wear. More tooth on the front means a bigger arch around the sprocket and more tooth means means less wear per teeth. |
08-14-2007, 08:08 PM
#1513 |
I have a bike.....
Oddometer: 486
I have been waiting patiently for someone to say they have one, but no longer, it has to be said!
WHERE ARE THE TOURATECH FUEL TANKS FOR THE G650X??? http://www.advrider.com/forums/showt...72350&page=103 Were past the middle of 2007 I would like to buy one now. Anyone have any news or special contacts, or other ways to increase fuel capacity. I guess the HP2 rear tank would fit (Wunderlich) and I have seen the MecaSystems adaptation (speculated) on the right rear. Who has installed the Ohlins shock and where did you buy it from and how much did it cost. Did you notice a difference? |
08-14-2007, 09:20 PM
#1514 |
Suck it Trebek
Oddometer: 567
So I am gonna pick up my X on Thursday and I have a question. Is Touratech the only game in town for a rear rack as of now. I am looking for something in the 8x10 range to strap gear or a fuel pack onto.......
I was thinking the passenger grabs from a country might be a good base to start with and weld some crap on if I can't find anything
"If my calculations are correct, when this baby hits eighty eight miles per hour, you're gonna see some serious shit." - Doc Brown "We sleep soundly in our beds because rough men stand ready in the night to visit violence on those who would do us harm." - Winston Churchill "I do believe that, where there is only a choice between cowardice and violence, I would advise violence..." - Gandhi You can save $5 on a smugmug subscription use coupon KyCiOLxqIwDIk |
08-14-2007, 09:26 PM
#1515 | |
Oddometer: 366
I mounted a pelican 1400 case to my small TT rack and have though about putting a koplin 1 gallon can on top of that. the case works well.
